2004 honda cbr 125r headlights
kenny
PostPosted: 13:17 - 10 Oct 2011    Post subject: 2004 honda cbr 125r headlights Reply with quote
just got a honda cbr125 for my daily commuter bike but the headlights seem to be a bit on the dull side had a look about on the internet to see if there are any brighter bulbs aviable but not with much look. does anybody know if there are some sort of special fit or are they a halagen fit i.e h4, h7
any info thanks
kenny
KeNNy 100cc peugot speedfight 125cc Honda NSR125R 650cc suzuki SV650R 125cc suzuki GZ125 600cc yamaha YZF-R6
spyuggy
PostPosted: 20:54 - 10 Oct 2011    Post subject: Reply with quote
Is your battery in good nick?
Is your alternator charging properly?
Your lights may be maladjusted, I would check these out first, as the bulbs should be standard and should be bright enough.
Good Luck with it.
Treat each day as if it was your last, because one day you will be right.
Matthew_Lee
PostPosted: 21:30 - 10 Oct 2011    Post subject: Reply with quote
I've been having a similar problem also.
With the bike being a 125 there's not a great deal you can do as far as upgrading the lighting... If the bulb which is installed currently is a BA20D globe type... you could try upgrading to a 45/40w bulb...
or alternatley buy a BA20D halogen bulb 35/35...
but you must make sure that, if you're putting a halogen bulb in, the headlight unit is not plastic because the bulb will get too hot.
If it's a metal unit with a glass lense, you will be fine.
I'm debating a full new headlight assembly to handle halogen bulbs,
Just like yourself, i commute a lot in the dark.
hope this helps
Noxious89123
PostPosted: 23:09 - 10 Oct 2011    Post subject: Reply with quote
CBR125 headlight is all plastic.
PostPosted: 07:34 - 11 Oct 2011    Post subject: Reply with quote
This.
Hotter/brighter bulbs just screw with the casing Thumbs Down
When my friend crashed my CBR, I just stuck those twin dominator type headlights on, 10 times better IMO, but dont go trashing your bike just yet Laughing
Noxious89123
PostPosted: 20:42 - 11 Oct 2011    Post subject: Reply with quote
I think you just have to accept the limitation of a 125cc bikes electrical system. If you think they're bad, you should see the candle powered crap some much older bikes use Laughing
I found the standard headlight and bulbs good enough to ride along unlit a roads flat out (so what, 75mph maybe? Laughing ).
The last post was made 15 years, 13 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 49.56 Kb
