This isnt good. Hyosung GT125R problem.
Rncv
PostPosted: 18:54 - 11 Oct 2011    Post subject: This isnt good. Hyosung GT125R problem. Reply with quote
Okay guys, i posted a topic a while ago about the bike not riding right and it feeling like the wheel is misaligned when its not :/...
Anywhos, i tried to take off the front sprocket cover and my dodgy spanners were just rounding the heads... So off to B&Q and 30 minutes later i have a handy socket set Wink
Anywhos.....
This is my find! What do i do now? how does this effect the bike??
https://i51.tinypic.com/nxqt8m.jpg
neil.
PostPosted: 19:01 - 11 Oct 2011    Post subject: Reply with quote
Not sure - is that just a tabbed lock-washer where it's deliberately bent (looks like it and it's supposed to stop the nut from undoing itself)? Use a cold chisel (or large flat bladed screwdriver if you're feeling naughty but be careful with it) and hammer to bend that tab back then you can undo the nut. Your chain looks filthy by the way and the sprocket looks pretty well worn out too. I'd replace them as a set.
iooi
PostPosted: 19:02 - 11 Oct 2011    Post subject: Reply with quote
Well chain needs a good clean and lube.
Not quite sure due to angle of pic, but it lloks like a new sprocket is required as it appears to be a bit hooked on the teeth.
I would simply get a new chain and sprocket set. Thumbs Up
And give that area a good clean Laughing
Rncv
PostPosted: 19:19 - 11 Oct 2011    Post subject: Reply with quote
New chain and sprockets are on the way! hopefully be here within the next couple of days.
The last post was made 15 years, 19 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.26 - MySQL Queries: 13 - Page Size: 39.48 Kb
