Honda SP1 Gear..."Stick-POLE-Thingy!! URGENT.
CHALKIE.
PostPosted: 18:18 - 10 Oct 2011    Post subject: Honda SP1 Gear..."Stick-POLE-Thingy!! URGENT. Reply with quote
Coming home from work tonight,I flicked up from 3rd-4th and my gear "thing",came off. Shocked Shocked
This bolt had come undone:
https://i121.photobucket.com/albums/o221/chalkiesp2/IMAG0304-1.jpg
Question is; Should it be attached to a nut,the other side?
I managed to get home and tighten it with toolage,I'm wondering if I'm missing a nut?
https://i121.photobucket.com/albums/o221/chalkiesp2/IMAG0305.jpg
I need to use the bike tomorrow. HELP.
NC30:>NC35:>SP-2:>K6:>SP-1.
1275GT Mini:>Renault 5 GTT:>Integra DC2:>DC5.
PostPosted: 18:25 - 10 Oct 2011    Post subject: Re: Honda SP1 Gear..."Stick-POLE-Thingy!! URGENT. Reply with quote
If it's threaded behind it, you shouldn't a nut, but could always stick one on if it won't hit anything.
Or some locktite etc.
I've had various of them work off over time, so just something to keep an eye out for and consider if you notice your shifting feeling a bit sloppy.
CHALKIE.
PostPosted: 18:41 - 10 Oct 2011    Post subject: Re: Honda SP1 Gear..."Stick-POLE-Thingy!! URGENT. Reply with quote
Thank you. Karma
yen_powell
PostPosted: 19:40 - 10 Oct 2011    Post subject: Reply with quote
Is there not the same thing at the other end of the rod to compare?
XT1200Z and a DR350 in bits
Noxious89123
PostPosted: 20:44 - 11 Oct 2011    Post subject: Reply with quote
Shouldn't there be a rubber boot over it too? All my bikes have had them all greased up inside a little rubber cover.
Fizzer Thou
PostPosted: 14:54 - 12 Oct 2011    Post subject: Reply with quote
I have the same arrangement on my Harris rearsets.I bought some rose joint rubbers from Yamaha for these rearsets part number 2H9-18154-00.When the same bolt loosened off when I first bought the bike second hand,the rubber boot held the bolt in place so that I did not lose it.
Always have a 'Plan B'
Blackwolf
Burgerfist
PostPosted: 15:32 - 12 Oct 2011    Post subject: Reply with quote
FYI, as whats been said its a rose joint.. The Hondas are not too bad but becasue of the vibey-ness of the SP they do have a habbit of loosening things off the bike. Some weaker threadlock will do the job well.
I personally never bothered with the rubber boot, just put some threadlock on and was done.
Hope your enjoying the bike, I miss mine Sad
CHALKIE.
PostPosted: 18:02 - 12 Oct 2011    Post subject: Reply with quote
Thanks for ALL the advice guys. A dab of loctite and a tighten seems to have worked. Very Happy
Indeed I am mate.So much more rewarding to ride than my old K6. Wink
Blackwolf
Burgerfist
PostPosted: 18:06 - 12 Oct 2011    Post subject: Reply with quote
Are you forgetting the noise...
THE NOISE!! Induction roar.. Hearing the gear driven cams spin up.. with thunder coming out its arse.. PURE heaven!! Mr. Green
CHALKIE.
PostPosted: 18:12 - 12 Oct 2011    Post subject: Reply with quote
The V-twin roar,more than makes up for it. Dance!
The last post was made 15 years, 3 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 74.85 Kb
