Cam Chain Tensioner Adjustment on ZZR600
Mrjoolz
PostPosted: 09:01 - 12 Oct 2011    Post subject: Cam Chain Tensioner Adjustment on ZZR600 Reply with quote
Hi,
Getting slight rattle from bike around 4-5K RPM, and sounds like a bunch of keys rattling on top yoke, but I dont have many keys on keyring. just ignition an Disc Lock.
I thought it could be CCT ! Could this be the case ? 15,000 miles bike has done.
Can I adjust this myself ? Is it easier. I have checked manual but it explains about removing it not adjusting that I can see.
thoughts please ?!
Ta
Joolz
Previous Bikes: TZR125, KMX125, RGV250, RD350YPVS, GXSR750H, GSXR600SRAD, R1 (2000), GSXR1000 (K1), ZZR600, CBR1100XX Super Blackbird
Current Bike: Suzuki GSX1300R Hyabusa.....
MaybeGuy
PostPosted: 09:06 - 12 Oct 2011    Post subject: Reply with quote
See, this is what happens when people read forums too much.
Mrjoolz
PostPosted: 09:16 - 12 Oct 2011    Post subject: Reply with quote
So you mean its nothing to worry about ! Wink
yen_powell
PostPosted: 10:04 - 12 Oct 2011    Post subject: Reply with quote
He could mean that in general bikes haven't had manually adjustable cam chain tensioners since the early 80s. But there are aftermarket versions available for certain bikes that have a reputation for frailty in that department.
XT1200Z and a DR350 in bits
Mrjoolz
PostPosted: 10:07 - 12 Oct 2011    Post subject: Reply with quote
Ahhhh I see, (said the blind man)
Embarassed
thanks
MaybeGuy
PostPosted: 10:08 - 12 Oct 2011    Post subject: Reply with quote
Or that any time anyone describes any sort of rattle, its instantly assumed its the cct. Its probably a bolt rattling around in your fairing
Mrjoolz
PostPosted: 10:09 - 12 Oct 2011    Post subject: Reply with quote
Embarassed
thanks
jjdugen
PostPosted: 10:13 - 12 Oct 2011    Post subject: Reply with quote
The ZZR's can make a sort of metallic rattling at around the RPM you described. Its the fresh air gizmo on top of the rocker cover. This has two reed valves under the chrome oblong covers where the two pipes join into the venturi thing. One of the petals will be slightly bent. You can junk them and join the two pipes together to quieten it down, it also gets rid of the raspy noise in the airbox.
The last post was made 15 years, 8 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 56.25 Kb
