| monty16v |
 monty16v Two Stroke Sniffer
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 16:32 - 12 Oct 2011 Post subject: |
Did you re-use the old circlips?
What plug are you using? Is it all standard? If not, whats your main jet size? ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Kickstart |
 Kickstart The Oracle
 Posted: 16:41 - 12 Oct 2011 Post subject: |
Is the oil line in place? Or could it be blocked, snapped, have air bubbles?
What was the ring end gap set to?
Has it used any water? Not unknown for the water pump to leak into the crankcases on the RS and cause problems for the barrel.
Reusing circlips is a REALLY bad idea (or worse, some of the non original ones have tails that can snap off, although probably only a major issue when thrashed).
Anything that could cause it to run lean? Missing air filter, damaged inlet manifold. Worn main bearing seals?
| Frost |
 Frost World Chat Champion
| monty16v |
 Posted: 16:56 - 12 Oct 2011 Post subject: |
| mattsprattuk wrote: | Did you re-use the old circlips?
What plug are you using? Is it all standard? If not, whats your main jet size? |
no used new circlips that came with vertex piston kit
plug is NGK BR10EG
standard apart from exhaust really
not sure main jet size its a 34mm carb
| Kickstart wrote: | Hi
Keith |
oil line is in place yes
i never set ring end gap just fitted new rings and piston
doesnt seem to have used any coolant
the inlet manifold is slightly perished and cracked, but i checked the inside of it and it is not split on inside, there must be 2 layers on them
the only other thing i can think of is that stupid cone filter the previous owner has fitted, although the bike ran it the whole time he had it, and the whole time i had it on the first piston so over 2000miles at least, so surely it couldnt have caused my new piston to fail inside 200miles ? ____________________ OffTheClockMotorSport |
| Kickstart |
 Posted: 16:59 - 12 Oct 2011 Post subject: |
Cone filter probably leans the mixture out and so should be rejetted. However as stock an older one with the 34mm carb would be fairly safely rich as standard. If a later one fitted with the older carb then god knows how it has been jetted.
You should have a piston which matches the bore size (there are a couple of different size bores used with a tiny difference between them)
| monty16v |
| MaybeGuy |
 Posted: 17:15 - 12 Oct 2011 Post subject: |
From that, I vote power valve/piston collision if it is in fact standard.
And to second guess Kickstart is a bad idea. (FYI a barrel can be rebored and replated) ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| P.addy |
 P.addy Red Rocket
 Posted: 17:17 - 12 Oct 2011 Post subject: |
Don't skimp on parts when rebuilding a 2 stroke.
I personally wouldn't have anything that had been used.
It cost me £150 for a barrel, piston, all the bearings and rings/clips.
£25 for a full gasket set.
So £175, all new Mitaka kit, ran perfectly after that... I ran mine in a decent amount before opening it up at all though. |
| Kickstart |
 Posted: 17:19 - 12 Oct 2011 Post subject: |
In theory you should have measured the bore to get the right piston (in practice I suspect most don't). Ring end gap should be checked to ensure there is enough clearance. However with a 2nd hand barrel you are never going to be certain that it hasn't been replated and that the stamp for the size is meaningful (and not unknown for cast iron liners to be fitted).
Getting a 2 stroke set up on a dyno can be difficult. Most places won't know what they are doing with a slide carb or a 2 stroke these days and plenty won't want to risk their expensive exhaust probes on a 2 stroke.
I would check the carb jetting (and given you were taking it easy, the needle jet needs checking carefully), but I would be surprised if it caused an issue in low speed / running in use.
I am assuming it wasn't over heating.
| monty16v |
 Posted: 18:27 - 12 Oct 2011 Post subject: |
| mattsprattuk wrote: | From that, I vote power valve/piston collision if it is in fact standard.
And to second guess Kickstart is a bad idea. (FYI a barrel can be rebored and replated) |
i didnt think the powervalve could drop in enough to hit the piston on these engines (i could be wrong) unless the blade shaft snapped and the remaining piece fell in
i know a barrel can be replated, they cant be bored out, unless you have a steel liner
| ##Paddy## wrote: | Don't skimp on parts when rebuilding a 2 stroke.
i wouldnt put any mitaka parts on it, they are cheap chinese dirt if you ask me,
the only 2nd hand parts were a barrel in VGC(£100) and a cylinder head.
The piston, gaskets, and small end bearing i put in were £110ish alone
Keith |
yeah there is a few guys near me that are pretty handy at the jetting.
bike wasnt over heating mate no.
i will maybe whip the head off tommoro and have a look, will post again then when i know a bit more ____________________ OffTheClockMotorSport |
| P.addy |
 P.addy Red Rocket
| MaybeGuy |
 Posted: 18:32 - 12 Oct 2011 Post subject: |
It's a common failure on RS engines. (or maybe just the 250s, not sure about the 125)
Of course they can be bored out. The rebore is then replated. Nikasil doesn't just make its own hole. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Kickstart |
There is a positive stop for the power valve.
Although the barrels shouldn't be rebored it has happened . Not that the resulting mess will last any length of time. If replated the size stamped on the bottom is quite likely to not match the actual size.
Cast iron liners are pretty common though.
The Mitaka barrels do seem to be fairly good, and are FAR cheaper than original Rotax barrels. Not heard any reliability issues with them (although some supply them with better rings) although possibly very slightly worse performance.
| dudders7 |
 dudders7 Scooby Slapper
 Posted: 20:11 - 12 Oct 2011 Post subject: |
Just a thought, sounds exactly like one I had. Rebuilt engine, all new parts. Ran it gently occasional burst of acceleration and after about 100 miles i was doing about 45mph and the rear wheel locked up.. whilst on a bend. Managed to stop the bike without hitting anything. Put bike in neutral pushed it forward, fine not chain or sprockets, next engine, turned over fine and started up, strange I think and get on bike and carry on, 3 miles later same thing. I was ready this time, anyway wont bore with all the details, got it home, head off, no scoring or anything. Figured out in the end piston was the wrong way round. Turned it round put everything back together, worked fine, did another 2000 miles then sold it. So just check the piston is the right way round... easy mistake if there is no arrow on the piston. Good luck ____________________ Riding in the sun in Australia on a 04 Worked ZX10R along with a fleet of other crazy toys |
| monty16v |
| monty16v |
| P.addy |
 P.addy Red Rocket
| monty16v |
The last post was made 14 years, 356 days ago. Instead of replying here, would creating a new thread be more useful? |
