Honda H100s Tuning - Team Mad Dog inspired
cb1rocket
PostPosted: 22:46 - 12 Oct 2011    Post subject: Honda H100s Tuning - Team Mad Dog inspired Reply with quote
Hi all
Does anyone know much about the H100 and H100s (also S2) in regards to tuning. I want to be able to achieve somewhere along half the power as they have quoted.
link is here https://www.teammaddogracing.com/H100s.html
I made a start by getting a CR125 reed block assembly and already found out that the fixing hole centres are too far apart!
Can anyone shed some light on any idea of parts from other Honda's of that era that I can fit and adapt for a bigger carb.
I'm lucky enough to have my hands on a mircron expansion chamber!
Please no replys saying don't bother and get a bigger bike comments. I have CB1 for performance and I hold a full license
PostPosted: 23:03 - 12 Oct 2011    Post subject: Reply with quote
Biggest problem is gearing. They are low geared as standard (although think you can change one sprocket marginally now) and easily rev way past peak power on stock gearing. So any gain in power can't be used that much.
Other than that the main bearings will probably have a greatly shortened life.
There used to be a Micron pipe available for it and you should be able to port it out to get more go
cb1rocket
PostPosted: 23:10 - 12 Oct 2011    Post subject: Reply with quote
got micron pipe and a choice of 16 and 17 front sprockets, which both of them fit. The 16 is just right for a stock motor, but the 17 is too overgeared so will be useful for when the power is upped
PostPosted: 23:39 - 12 Oct 2011    Post subject: Reply with quote
What are the sprockets from?
A marginally bigger carb can be got from an MBX or MTX80. They are a fairly similar engine.
PostPosted: 23:47 - 12 Oct 2011    Post subject: Reply with quote
I once got a very second hand and unreliable piece of info that an MTX125 reed valve block would fit.
An H100 goes pretty fucking fast as it is for a 98cc air cooled commuter bike though. I considered tuning mine then discarded the idea because it's entertaining enough as standard.
cb1rocket
PostPosted: 09:51 - 13 Oct 2011    Post subject: Reply with quote
front sprockets are direct replacement from wemoto. My first finding of one that would fit came from a pitbike.
I have been looking at 26mm carbs instead of a whooping 32mm carb.
The main biggest problem tends to be the 'neck' of the reed inlet manifold. I know for a fact that the 26mm carb will bolt on to the existing reed block as the hole centres for that are def correct at 48mm ctr - ctr. I would like to open up the reed inlet somehow.
I do know the bike is pretty much difficult to tune without some machining/welding work - but i'm still tempted!!
pepperami
PostPosted: 10:00 - 13 Oct 2011    Post subject: Reply with quote
What about changing the rear sprocket? as you can get a smaller difference in ratio by changing from say for example 42 teeth to 44 teeth.
changing up one tooth on the front sprocket can be a big jump for such a little motor, but changing a couple of teeth on the rear sprocket might give you a better but small increase in top-speed?
PostPosted: 10:30 - 13 Oct 2011    Post subject: Reply with quote
Think a 32mm carb would be a massive overkill and cause problems. Carb that size would only start giving an advantage when you get towards high 20s hp and doubt the H100 could give that (or at least not without the life span of a hand grenade with the pin pulled out).
pepperami - with gearing the H100 is stupidly low geared. Peak power (6500rpm) in top gear is at 50mph while they will indicate about 60mph (over 8000rpm). If you can raise the gearing enough you would probably get mid to high 60s mph from them with no engine tuning. However the rear sprocket is tiny while until recently nobody listed a suitable larger front sprocket.
PostPosted: 11:12 - 13 Oct 2011    Post subject: Reply with quote
Rob Fzs wrote:
20hp is pretty epic from 100cc though haha
I believe the 85cc motocross bikes can be making around 25hp when in a decent state of tune!
cb1rocket
PostPosted: 11:37 - 13 Oct 2011    Post subject: Reply with quote
yes they did quote that full throttle is for 20 secs only, or you holed the piston!
PostPosted: 11:51 - 13 Oct 2011    Post subject: Reply with quote
Carb on its own doesn't really give you power. It just provides the fuel / air that other things use to give you power.
Like the diet for a tour de France cyclist. Gives them the energy they need, but if I ate it then it would just put more fat on me and make it harder to get off the sofa.
What it will do is make the bike a pig to ride at low revs. Whack the throttle open and it will just go to sleep (large carb with a low air speed through it just doesn't work properly).
A 28mm carb is easily big enough for well over 20hp (and 20hp would be very hopeful for an air cooled stretched moped engine), while a 32mm carb has an area over 25% bigger.
The carb alone shouldn't make it hole a piston. Most likely cause of that would be detonation, although it might well be that the pressure drop through a carb of that size is so small that it can't effectively draw fuel from the float bowl and runs lean at high rpm.
The last post was made 15 years, 10 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.09 - MySQL Queries: 13 - Page Size: 79.57 Kb
