| Marc_Buck |
 Marc_Buck Could Be A Chat Bot
| Ninja |
 Ninja Caption Abuser
| Frost |
 Frost World Chat Champion
| dainesefreak |
 dainesefreak World Chat Champion
| iCraig |
 iCraig World Chat Champion
 Posted: 11:04 - 07 Sep 2004 Post subject: Re: GS500 vs GPZ500 |
| Marc_Buck wrote: | I have preety much narrowed my search down to these two bikes due to the low cost.
Can anyone tell me how much bhp these two bikes push?
Top speed, 0-60, handling and do they like to be opened up?
CraigZZR owned/owns a GS500 right? can you give me any advise on it mate?
Ta |
Well I do still own a GS500, till tomorow anyway.
All I can say about them is there a bloody good bike to have.
I've had 2 now and there nice and cheap and quite nippy.
I can get 65MPG quite easily and keep up with bigger bikes to.
0-60 is takes about 5-6 seconds and handling is quite good and precise up to about 70MPH, after that the inherent old design of the GS500's chassis comes out and the bike begins to loose its composure, but not everyone rides GS500's like me .
One thing I do love about the GS is its light and really flickable.
And also servicing is peanuts as its aircooled, tyres last for ever, I get 10,000 from a rear BT45 and 15,000 from the BT45 on the front!
Oh and the GS produces about 51BHP but mine is an older one and produces more like 45BHP, but its still good for an indicated 115MPH.
I also will be the owner of a GPZ500S tomorow, and I will be able to give you more info when I've ridden one longer.
At the moment I have only other peoples views to go on but I know the GPZ produces about 60BHP and is basically the same as the GS in most other ways but the fairing adds comforts and better high speeds cruising handling.
I assume MPG will be the same too and servicing will be slighty higher due to it being water cooled.
I always get asked why I like 500's, and its because there so cheap to run compared to most other bigger bikes.
You won't be dissapointed if you go for either, but as always you may get bored after abit but doesn't that happen with most bikes after a while?
My 500 FAQ for you to read which covers most things is here too: https://www.bikechatforums.com/viewtopic.php?p=281300#281300
Hope that Helps
Craig |
| Marc_Buck |
 Posted: 11:10 - 07 Sep 2004 Post subject: |
great  ____________________ 94 fzr600r |
 Posted: 13:26 - 07 Sep 2004 Post subject: |
The GPZ does not have any problems riding at constant speed (we have had 2 of them). There is a very noticeable kick in the power at about 7000rpm, but keep it below that and it will happily do over 60mpg (the current one averages 61mpg for me in all use).
GPZ brakes are not that great, but then the GP has almost the same braking system so I suspect they are about equal there.
The GPZ liquid cooling is only a problem due to some idiot of Kawasaki putting the coolant pipes to the head between the cams, so you need to remove the pipes to adjust the valves. The pipes are sealed with a rubber O ring, so by Murphys law the O ring will be knackered when you need to reuse it.
I have had over 125mph indicated from a GPZ500, probably with a touch more to come.
| iCraig |
| JonB |
 JonB Afraid of Mileage
 Posted: 17:23 - 07 Sep 2004 Post subject: |
Well I am thinking of getting the GS500F version because it is trying to be a GSXR, but has affordable insurance, so I have my heart set on this bike. Can't really contribute anymore than that. ____________________ Be careful whose advice you buy, but, be patient with those who supply it. Advice is a form of nostalgia, dispensing it is a way of fishing the past from the disposal, wiping it off, painting over the ugly parts and recycling it for more than it?s worth. |
| mrchips |
 mrchips World Chat Champion
 Posted: 02:00 - 08 Sep 2004 Post subject: |
I did an 850 mile run on a GPZ500s last weekend and owned one for 4 years (35k miles), perfectly comfortable, efficient fairing, liquid cooling, rarely returns less than 50mpg (unless mercilessly thrashed, which they will handle very well), 4 gallon tank, enough of a powerband at the top-end to make life interesting if you want to (they really pick up their skirts and shift at about 8k rpm) and don't have the same corrosion issues that come as standard fitment with suzukis.
Downsides, quite a low seat (but I am over 6' and find them comfy enough), front brake woefully inadequate but OK with braided hoses, fussy about tyres (will not tolerate cheap ones, but great on BT45s which are probably an ideal mix of longevity and grip anyway), 'autocorrode' rear shock due to overly short rear mudguard and a healthy appetite for unitrak bushes.
The coolant o-rings Kickstart mentioned cost no more than a couple of quid, you don't need to go into the rocker cover all that often anyway, just buy new ones before you do so, I reckon the benefits of liquid cooling outweigh the disadvantages.
I would go for the GPZ over a GS any day of the week unless it was a real cheap one (500 or less) in which case the simplicity of the GS engine means it is less likley to have any 'timebombs' in it. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| iCraig |
 Posted: 17:38 - 08 Sep 2004 Post subject: |
Well I picked the GPZ up this afternoon and I can now give my valid opinion on it.
The GPZ is a lovely machine, has good torque and lovely power from about 2000RPM, and it somewhat picks up its skirt from about 7000RPM and flies!
Handling is very sure footed and quick with it being a 16" front wheel.
So far I am not too confident in the Continental tyres that are on it at the moment and they will be replaced with BT45 soon anyway.
And the fairing does a good job at keeping the wind off and its just big enough to hide behind on the motorway, though a taller screen is on order for it.
Oh and there are some pictures of it here https://www.bikechatforums.com/viewtopic.php?p=300312#300312 |
 Posted: 01:09 - 10 Sep 2004 Post subject: |
Take the Contis off and throw them in the bin before they have you off! I bought a pair for my GPZ once and threw them in the bin with 3mm of tread still on them. The profile is entirely wrong for the bike, far too steep, they are only 20 quid cheaper a pair than the bridgestones.
Another quirky point that happens when you fit a new BT45 on the front. After about 100 miles, the front-end starts tracking along white lines in a disconcerting manner. Don't panic, it wont do anything funny and passes after another 50 miles. You know if you have been riding it hard because you wear the sides off them before the middle (dual compound) ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 22 years, 51 days ago. Instead of replying here, would creating a new thread be more useful? |
