What revs do you sit at?
GrantT
PostPosted: 12:56 - 17 Oct 2011    Post subject: What revs do you sit at? Reply with quote
So, coming from the world of big diesel engined cars which chug along at 1500rpm in near enough silence from the inside the noise of a revvy 600 is taking some getting used to!
I seem to be in the habit of going up through the gears and cruising along at about 3000rpm like I would in a car, but I guess this is too low really as its a bit slow to pick up.
To the actual question.... where do you sit rev wise when riding along normally, say commuting to work, rather than when you balls out screaming down country roads Question
PostPosted: 13:27 - 17 Oct 2011    Post subject: Reply with quote
Most of the time don't care too much. Sit in a gear which gives me enough go for what I am doing / want to do. If that means 10k then so be it.
As long as the engine is warm isn't in the red too much then it should be fine.
1500rpm is pretty much just idle speed and I wouldn't expect any go there at all.
Ericck
PostPosted: 17:54 - 17 Oct 2011    Post subject: Reply with quote
Hmmmmmmmmmmmm,
How many revs, saw another thread what speed for roundabouts.
Maybe it just me and I have been riding for many years but when riding I am not really looking at the speedo (unless camera etc) or the revs. The engine noise, where I am and what is around me is dictating my speed and revs.
As above says what ever gives enough go. Lots of traffic means lower gear and keep it in the mid range so I can get out the way quick. Long straight then pootle along in top and low revs if not in a rush.
IMHO looking at the clocks isn't the right way its more of a feel thing. What do others think?
Current Bike: 2004 Suzuki Bandit 600S
Previous Bikes: Yamaha FS1E, Mobylette Moped Thingy, Suzuki GS125, Kawasaki Zephyr 550, Kawasaki Zephyr 750, Kawasaki ER500, Suzuki Bandit 600, Honda CBR600F, Triumph Street Triple 675, Suzuki V Strom 650, Suzuki Bandit 1200, Suzuki SV650N, Honda CB500F.
Dan_Davies
PostPosted: 18:04 - 17 Oct 2011    Post subject: Reply with quote
i'd go with sound i listen to the bike if it sounds like it's revving its tits off i change up, If its feeling a bit sluggish may change down. I'd say its more feeling than looking at what the speedo says Thumbs Up
current ride: 07 suzuki sv650s
ex rides : lifan mirage 125
LordShaftesbu...
PostPosted: 18:33 - 17 Oct 2011    Post subject: Reply with quote
Bimbling into work it's about 5k, but I drop down 2-3 gears to make any maneuvres like overtaking. Then I'm up at the rev limiter.
Have you been up at 10-12k rpm yet? It takes some getting used to but the engine's designed for it. I know it took me a good while to use all the power of my 675.
Slacker24seve...
PostPosted: 18:49 - 17 Oct 2011    Post subject: Reply with quote
I'll sit at xK in top on the motorway. Otherwise I try and keep it above 7k as thats where Hornets get interesting.
I generally take the attitude of if in doubt, go a gear lower. Should something go wrong you've either got more go should you need to give it the beans to get out of a situation or you've got more engine braking should you need to avoid one. Cool
Banger rallies are ace
Stiffler
PostPosted: 18:52 - 17 Oct 2011    Post subject: Reply with quote
How long is a piece of string? Highly dependant on the bike and type of commute surely...
My commute is nearly all motorway (6 of 7 miles) and on my ZX-6R the revs are usually around 8000-9000... On normal roads probably 6kish? Never really paid that much attention.
On my little 125 my commute moves to A roads and the bike sits around 5000 while "cruising" or as close to 9k the rest of the time...
Current Bikes - Kawasaki ZX-6R (636) | BMW G650GS
LordShaftesbu...
PostPosted: 18:56 - 17 Oct 2011    Post subject: Reply with quote
That's my strategy too, just have to be careful with the throttle position. But what's with the algebra? Wink
blurredman
PostPosted: 19:00 - 17 Oct 2011    Post subject: Reply with quote
3 - 4K.
I don't go under that otherweise the bike labours.
Current: 1973 MZ ES250/2 - 18k, 1979 Suzuki TS185ER - 10k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (295cc) - 40k, 1989 MZ ETZ251 - 52k.
Louise
PostPosted: 19:13 - 17 Oct 2011    Post subject: Reply with quote
Mine sits at 6k doing 70 if im just bimbling along.
whitedevil
PostPosted: 19:14 - 17 Oct 2011    Post subject: Reply with quote
The only time I care about rev watching is when i'm about out of fuel, then its usually lows revs and cruise at 60mph@5k till I get to a garage.
GPZ500 sold ~ CBR600FS-2 sold ~ ZX6R sold ~ Street Triple R
The Artist
PostPosted: 19:17 - 17 Oct 2011    Post subject: Reply with quote
It depends. If I want to go faster, I usually sit at a higher rev than if I wanted to go slower.
Louise
PostPosted: 19:27 - 17 Oct 2011    Post subject: Reply with quote
Had to do this last night. Lost my petrol cap going to Thorpe Park Embarassed because im a numpty for not putting it back on!! Got lost coming home, I knew I was close to reserve and no garage in site.
Sat at 4-5K revs for ages Thumbs Down
Slacker24seve...
PostPosted: 20:03 - 17 Oct 2011    Post subject: Reply with quote
Since I downgeared it I'm not entirely sure what I do at motorway speeds. Despite having a naked bike, its rare that I will bimble along at 70. I generally sit at an indicated 105 which taking into account the downgearing and speedo inaccuracy is probably 90-ish. Hopefully just short of bannable speeds.
My CBR400 needs a fistful of revs to go anywhere. Part of the fun though.
trikeschick
PostPosted: 21:24 - 17 Oct 2011    Post subject: Reply with quote
My Hornet loves 400 to 500 rpm but I think it sits lower when bumming about town whereas will be higher on the motorway. Now I have more experience on it, to be honest I tend not to look at the clocks, just a quick glance to set a pace for speed limits but even then am trying to 'get a feel' for it instead.
"Light travels faster than the speed of sound, which is why some people appear bright until they speak"
Paulington
PostPosted: 00:52 - 18 Oct 2011    Post subject: Reply with quote
Depends where I am riding, the speed limit and such, it also varies massively by motorcycle.
On the GSX-R, 6000 RPM in 6th gear is 100mph, so on an empty motorway I can cruise at that, in 30mph zones I tend to sit in 3rd gear at around 2000 RPM and in most speed limits besides 70mph limits I just sit at 2000 RPM in whichever gear is 2000 RPM, the GSX-R has a nice gearing due to it's high top speed which helps a lot.
Also, if I am being uber-lazy, I put it in 3nd gear and never change gear, moped with a clutch. Third gear will pull away from a standstill no problem and go on to top speed of 140mph or so, in fact, I can sit at 100mph in first gear but it is a little bit buzzy, so third is best. Laughing!
Idle speed on the GSX-R is around 1500 RPM and it has enough torque to sit at 2000 RPM in any gear no problem, it even accelerates well from there but really begins to launch at around 4000 RPM and then just screams up.
It will take you a while to get used to being able to rev it and rev it and rev it, but bikes are happy to be buried into the redline (avoid the limiter, please!) again and again, it's what they are built for, so do it! Laughing!
You, as above, will gain the skill of not bothering to look at your speedo/tachometer, I can tell what gear/revs/speed I am at by how fast I 'feel' I am going and the noise of the engine and as has been mentioned above, what dicates what RPM I sit at is the road conditions, if I know I am in a situation where I may need some power to overtake soon/surrounded by cars on the motorway so want to get through a small gap etc then I will drop a couple cogs and hover at 6000 RPM or so because the GSX-R is a rocket then, goes like a scalded cat, but otherwise I just sit in top gear and chill.
With a 600cc, you will have to sit at a higher RPM as they lack torque in the lower RPM which means it won't 'pick up' when you turn the throttle, on the CBR600RR I rode I sat at around 4000 RPM in 3rd gear at 30mph but if I wanted to accelerate hard I had to drop a cog as it didn't have the torque to suddenly pick up.
TL;DR: It all depends on the road conditions, as long as you are being safe/doing around the speed limit (above or below) etc etc then just ride at what feels comfortable, but as you get to know your bike, you will get to know what is right for you and it. Thumbs Up!
GrantT
PostPosted: 08:37 - 18 Oct 2011    Post subject: Reply with quote
Thanks for your input everyone, wore ear plugs today and that helped a little with my rev aversion!
GrantT
PostPosted: 08:50 - 18 Oct 2011    Post subject: Reply with quote
Oh yes! It all goes a bit mad at about 9/10k!
PostPosted: 09:53 - 18 Oct 2011    Post subject: Reply with quote
Revs are good. Lack of revs is bad Wink .
The amount of umph you have is down to the torque at the back wheel. To get that you either need high gearing with lots of torque at low rpm or a low gearing and a lot less torque at high rpm. As changing gear is easy having lots of torque at low rpm is a bit of a waste.
The last post was made 14 years, 268 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.27 Sec - Server Load: 1.71 - MySQL Queries: 13 - Page Size: 114.57 Kb
