Ticking on the engine.
McFlufferson
PostPosted: 21:07 - 18 Oct 2011    Post subject: Ticking on the engine. Reply with quote
There's a ticking in my engine which goes faster as I rev up. But only if the bike is moving. It sounds something like I'd expect if there were something trapped in the fan, but it ticks whether the fan is actively running or not. Unless it could be something in the fan and the fan is moving with the wind passing through the front of the bike? I am so useless with anything mechanical. The best I can manage is an oil change and charge the battery. I'm a little concerned as it only started after I gave it its first blast on the motorway. (Edit. Obviously not -its- first. But its first with me on it.. )
It's a honda vf500 f2 if that makes any difference. It's also in need of carb tuning - could that have anything to do with it?
Think that you'll stay loyal to a loving bike? So did I. Only rich men can afford to stay loyal. The poorer of us will whore ourselves out to any two wheeled monstrosity that will take us.
The Artist
PostPosted: 21:09 - 18 Oct 2011    Post subject: Reply with quote
You can narrow it down by doing simple tests.
e.g. does it do it in every gear?
does it do it when moving but the clutch is pulled in?
Under braking?
If it only does it when moving then it is most likely the drive chain, so the chain, sprockets, wheels. At worst the output shaft in the gearbox.
McFlufferson
PostPosted: 21:12 - 18 Oct 2011    Post subject: Reply with quote
Hm. Thanks. I shall have to check and listen out for the differences tomorrow.
Does at worst mean it could explode in my face and grant me a very personal encounter with tarmac?
PostPosted: 21:15 - 18 Oct 2011    Post subject: Reply with quote
Difficult to say without more information. I'd say it's unlikely though.
The Artist
PostPosted: 21:19 - 18 Oct 2011    Post subject: Reply with quote
Most of the time, the louder the noise gets, the worse the problem. But I had a tappety valve once and then it went pop and my engine destroyed itself from the inside out. Luckily I was only doing 30mph and managed to pull the clutch in before I came off.
McFlufferson
PostPosted: 21:55 - 18 Oct 2011    Post subject: Reply with quote
*nod* The volume of the ticking hasn't increased, but I think the the amount has.
Thanks for the info. I'll take it out tomorrow and concentrate on it. See if I can figure out some specifics. The performance of the bike definitely hasn't dropped. It's still going strong.
McFlufferson
PostPosted: 22:46 - 18 Oct 2011    Post subject: Reply with quote
Unfortunately VF500s suffered that worry through guilt by association. The cam problems were actually all on the 750 models.
The only real reliability issues that the 500s suffered was that you had to keep a solid eye on the oil and make sure you did a full change at least every 5000 miles.
(I did a lot of reading on the bike when I got it to see what I could expect.)
McFlufferson
PostPosted: 13:27 - 19 Oct 2011    Post subject: Reply with quote
Ok. So. Just took it for a ride.
20 minutes maybe up gentle roads and slow-ish traffic and it started ticking. I was in third and couldn't really change because of the flow. Though I tried pulling the clutch and letting it roll a few times and sure enough the ticking dropped off.
So then I went up to the main dual carriage way in town and as I entered, revved, and knocked it up to second, it seemed to knock itself back in to neutral. But I kind of suspect it was just me not lifting hard enough because this is the first time it's notably done that.
But, in to second and it picked up nicely so I gave it the plate of beans. Up to 80 and back down to 50 in time for the cameras. Then the ticking really started. I rode it further at 50-60 with the stops for lights and eventually the ticking got louder.
It seemed loudest in the first first five gears, but a little in 6th, and the ticking either didn't drop off or was taking a really long time to drop off when I pulled the clutch in. Eventually by the time I was riding back home, it was even ticking at the lights with the clutch in. Though I didn't listen to see if it was ticking in neutral (kind of a pain to get in to neutral at lights so I gave that up).. hold on.. No. No ticking in netural. But man, does it ever need that carb tune. Anyone know how to do this yourself? I can't afford to garage it right now..
The Artist
PostPosted: 13:31 - 19 Oct 2011    Post subject: Reply with quote
When you pull the clutch in and it stops, I assume you are letting the engine go back to idle. This makes me think it is the engine more than anything else. Especially if it does it at a standstill.
Camchain/top end most likely.
McFlufferson
PostPosted: 13:33 - 19 Oct 2011    Post subject: Reply with quote
Yeah right back to idle.
If it's camchain or top end that's pretty serious, yeah?
The Artist
PostPosted: 13:44 - 19 Oct 2011    Post subject: Reply with quote
Well it could be the camchain tensioner, the chain itself, the valves, the tappets.
I don't know much about your particular engine so you may have to wait till someone who does can reply for you.
I don't like tapping though. Like I said, when it happened to me my engine went pop.
McFlufferson
PostPosted: 13:51 - 19 Oct 2011    Post subject: Reply with quote
Hm. Yeah. Well I guess when I can get the money together I'll have to take it in to the garage to get it looked at. Least if he can just look and tell me what's wrong so I know what not to do (like ride it..).
Thanks a lot of the info. Appreciated.
McFlufferson
PostPosted: 16:52 - 19 Oct 2011    Post subject: Reply with quote
o.o since new, eh. That's dedication.
Yeah. It's well worth looking after, if only to keep. It's a wonderful bike. Unfortunately lack of funds makes it a little difficult. But I keep a check on things and I don't rag it too hard. Hoping that will help some.
McFlufferson
PostPosted: 19:35 - 19 Oct 2011    Post subject: Reply with quote
Hm. Yeah. Thanks. I'll look in to it when I've got the time. I haven't got anything but the standard oil light.
temeluchus
PostPosted: 00:29 - 20 Oct 2011    Post subject: Reply with quote
the oil feed problems are related to the 700/750 models. The vf750 was an utter turd of a motorcycle. They effed around with different banjo bolts for the top ends to stop them eating the cams. The gearboxes still exploded in any case.
the 500s dont have any particular issues as far as I know.
may just be valve clearances time. Whats the mileage?
McFlufferson
PostPosted: 00:30 - 20 Oct 2011    Post subject: Reply with quote
Coming up to 35k. But I've only had the bike since beginning of August and I don't know the service history.
temeluchus
PostPosted: 00:35 - 20 Oct 2011    Post subject: Reply with quote
I THINK the vf500 is a bolt and locknut jobber so shouldnt be hard to adjust
The last post was made 14 years, 179 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.67 - MySQL Queries: 13 - Page Size: 107.6 Kb
