| penis020 |
 penis020 Renault 5 Driver
| KangyRew |
 KangyRew Derestricted Danger
| jimbothe |
 jimbothe World Chat Champion
| Chris750 |
 Chris750 Brolly Dolly
| penis020 |
| penis020 |
 Posted: 20:22 - 19 Oct 2011 Post subject: |
Beam kicks up to the off-side is a strange one, because it implies that it dips to the left which is correct. Is it a UK bike or an import?
Fork seals are easy on conventional forks, usually just remove the top nut and drain the oil, pull the spring out, un-do the bolt in the leg bottom, remove the seal circlip then use the leg as a slide-hammer to knock out the seal. Fit new seal, re-fit circlip , fill correct amount of oil and re-fit spring & cap.
Can you borrow a pair of foot-pegs? Or make a cowl for the seat? Doesn't need to be tidy, just hack something from plastic, just as long as it's not possible to sit on it, then there's no need for pegs. ____________________ a.k.a 'Geri'
 Posted: 20:27 - 19 Oct 2011 Post subject: Re: mot refusal are these big jobs to fix |
| betnow1234 wrote: | the list headland aim to low |
Easy fix
| betnow1234 wrote: | headlamp aim beam image kick up to offside |
Problem here is that the UK models had totally different headlights (and fairings to match). Possibly there is another bike that uses the same headlight that will dip the right way (maybe BMW C1). Otherwise you are stuck putting tape on the headlight to stop it dazzling people.
| betnow1234 wrote: | wheel alignment incorrect which adversely affects the handing |
Depends what is out of like. The Rear wheel can't be adjusted to change the angle (although it is possible to mount the wheel badly so it is very wonky), being a single sided swinging arm with an eccentric adjuster. Hopefully the problem is just the forks being twisted in the yokes, in which case slackening off a few of the pinch bolts and bouncing the front suspension up and down should put them parallel again.
Also could be it has had a bump and has bent something such as the front wheel spindle.
| betnow1234 wrote: | nearside front shock absorber seal failed and leaking oil |
Seal will be a bit of a pain to replace. USD fork.
| betnow1234 wrote: | rear brake hose is likely to be fouled or trapped by moving parts |
Depends what it is fouling. Possibly the lose chain mentioned as well, in which case easy.
| betnow1234 wrote: | drive chain fouling another component |
As above.
| betnow1234 wrote: | drive chain excessively loose |
Adjust it!
| betnow1234 wrote: | nearside rear forest missing offside rear footrest missing |
You need pillion footrests if it has a pillion seat. AF1 ones are not that common these days but RS125 ones will fit on easily.
| penis020 |
 Posted: 20:49 - 19 Oct 2011 Post subject: |
If there was no seat at all, that should be good enough. You could just tape the hole over. Ask the tester. ____________________ a.k.a 'Geri'
| penis020 |
| penis020 |
| MarJay |
 MarJay But it's British!
| penis020 |
| BigGun1 |
 BigGun1 Derestricted Danger
| penis020 |
| penis020 |
 Posted: 21:42 - 20 Oct 2011 Post subject: |
Yes, they are USD forks. ____________________ a.k.a 'Geri'
 Posted: 23:32 - 20 Oct 2011 Post subject: |
Something odd going on there as those wheels are from an Aprilia AF1 Sintesi rather than a Futura (brake disk is as well), and the forks are the older type (from a Sintesi or early Futura), yet with that bodywork I think it should have the later forks. Also the front mudguard has been changed (doesn't suit either the early or late forks).
| penis020 |
The last post was made 14 years, 262 days ago. Instead of replying here, would creating a new thread be more useful? |
