change of drive belt,now hardly moving?
stevekingchef
PostPosted: 16:34 - 19 Oct 2011    Post subject: change of drive belt,now hardly moving? Reply with quote
Hi guys
Well I managed to get variator off,put on new belt all back together.
Charged battery the scooter started.oh joy I said.
Took it up the road for a spin and well it hardly moves.
Acceleration is less than half what it was only got to 30mph .
Its a 250cc that used to sit at 70.
Any ideas before I pull it all off and throw a strop in the garage?
Steve
at106
PostPosted: 16:49 - 19 Oct 2011    Post subject: Reply with quote
Did you get any oil or grease on the belt or the pulleys?
If you can tension the belt is it correctly tensioned if not is the belt the correct length?
sickpup
Old Timer
PostPosted: 21:18 - 19 Oct 2011    Post subject: Reply with quote
The rollers probably have flat spots.
cb1rocket
PostPosted: 23:08 - 19 Oct 2011    Post subject: Reply with quote
wrong sized belt? Rollers should of been replaced as well.
stevekingchef
PostPosted: 11:33 - 20 Oct 2011    Post subject: Reply with quote
Hi guys
Cheers for replies.
I will hopefully have a look today.
The scooter is awful to work on.
The previous owners managed to square off round and grind every bolt.
I think it could be when I put the belt on I pulled the clutch roller(the rear one) out fully to put belt on ,now I guess I should have pulled the belt so it sits stretching belt more?closer to the outside?if that makes sense?
Many thanks again guys
Steve
at106
PostPosted: 15:06 - 20 Oct 2011    Post subject: Reply with quote
stevekingchef wrote:
Hi guys
Cheers for replies.
Steve
Pulling the clutch out would make no difference as once the engine starts the belt rotates and automatically moves out at the back and in at the front as this is how the scooters gearing works.
When you check tonight make sure theres no oil or grease on the belt or pulleys. Also check the rollers for flat spots and make sure they are correctly fitted.
bub2006
PostPosted: 16:37 - 20 Oct 2011    Post subject: Reply with quote
I had this once bbefore on a scooter. The rollers weren't seated right. Hope this helps
cb1rocket
PostPosted: 21:45 - 20 Oct 2011    Post subject: Reply with quote
check also that the front pulley nut is done up tight!
nighthawk250
PostPosted: 23:02 - 20 Oct 2011    Post subject: Reply with quote
A spacer in the wrong place in the variator/crankshaft,
The last post was made 14 years, 171 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 58.11 Kb
