Oil to use on a Kwacker GT550 - Synthetic, Magnetic, Super .
weewards
PostPosted: 15:36 - 20 Oct 2011    Post subject: Oil to use on a Kwacker GT550 - Synthetic, Magnetic, Super . Reply with quote
What is the best oil to use in my GT550, its just back on the road after an 18 year break and is currently using standard 10w40 oil but should I be using something more exotic or will that actually do harm???
I'm confused Confused
PostPosted: 15:39 - 20 Oct 2011    Post subject: Reply with quote
10w40 semi synth or fully synth if you prefer... it was designed to be run on that Thumbs Up
nowhere.elysium
The Pork Lord
PostPosted: 15:44 - 20 Oct 2011    Post subject: Reply with quote
Not designed to be run on fully synth, as far as I'm aware. Stick with semi-synth 10w40.
D'you have a workshop manual for it? That'll tell you in pretty unambiguous terms.
PostPosted: 15:51 - 20 Oct 2011    Post subject: Reply with quote
I always use semi, was just stating he could use that if he preferred. No real need as its not a high spec engine to begin with?
PostPosted: 15:53 - 20 Oct 2011    Post subject: Reply with quote
GT550 is old enough to be designed to run on a very basic engine oil. Get the right viscosity and change it regularly.
MickC
PostPosted: 18:08 - 20 Oct 2011    Post subject: Reply with quote
If its anything like the early eighties Honda 750/900 (what year is yours?) then you definitely want to stick to standard oils even the semi-synthetic stuff will effect things like the clutch (there's stuff in there that will cause it to slip) and the fully-syn stuff is right out for them.
I change mine every 1000 miles (don't leave it more than 1500 - old engines need more protection) - you don't have to do the oil filter each time, do mine every 3000 or so.
XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1
weasley
PostPosted: 18:57 - 20 Oct 2011    Post subject: Reply with quote
Without seeing the manual recommendation, I'd say a 10W-40 semi would be more than adequate, or as Keith says, a regular mineral oil will do the trick.
Semi or full synthetic oils do not automatically contain stuff that makes clutches slip.
hmmmnz
PostPosted: 20:20 - 20 Oct 2011    Post subject: Reply with quote
the cheapest halford oil you can find, or if you can find even cheaper oil else where buy that,
magnetech isn't really good for any bike with a wet clutch
fully synth is just a waste of money and probably to thin any way,
a nice thick oil is what is needed, 15w40 will be fine, 20w50 what ever is the cheapest, far better to have cheap oil and do more regular changes
the humans are dead
I kick arse for the lord
weewards
PostPosted: 22:49 - 20 Oct 2011    Post subject: Thanks to all Reply with quote
Hi, the manual says 10W40 & does not mention synthetic or mineral so I assume because of its age (1991) that mineral would be best but I just wondered if synthetic would have advantages but it would seem not
Thank you to all for your suggestions. Smile
temeluchus
PostPosted: 01:51 - 21 Oct 2011    Post subject: Reply with quote
its an old engine, designed with basic oil in mind.
the cheapest end of car oil will likely be better than what it was designed to use originally.
expensive oil would be a waste of money.
any mineral 15/40 or 10/40 will be fine.
weasley
PostPosted: 11:32 - 21 Oct 2011    Post subject: Reply with quote
The benefits of synthetic will likely be lost in the noise. A synthetic WILL give benefits, but probably not worth the extra money for what is, if you'll excuse me, a rather agricultural engine (meant in the best possible way, that many couriers can't be wrong!).
The last post was made 14 years, 264 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 3.12 - MySQL Queries: 13 - Page Size: 69.44 Kb
