Raise the back of XT600e
spanner-zn
PostPosted: 09:32 - 21 Oct 2011    Post subject: Raise the back of XT600e Reply with quote
I want to raise the back monoshock of my XT600e by 50mm. Any suggestions?
PostPosted: 09:50 - 21 Oct 2011    Post subject: Re: Raise the back of XT600e Reply with quote
What's the purpose?
Does it have a linkage?
You could consider getting a longer shock.
spanner-zn
PostPosted: 09:56 - 21 Oct 2011    Post subject: Reply with quote
For more ground clearance. Can't see any linkages.
PostPosted: 09:57 - 21 Oct 2011    Post subject: Reply with quote
Longer shock it is then. However google seems to think you have a linkage, so you could just fit different dog bones to raise the rear.
PostPosted: 09:58 - 21 Oct 2011    Post subject: Reply with quote
Given the choice, I'd try and go with a longer shock anyway for more ground clearance - technically a 50mm longer shock won't give you quite so much extra groundclerance, but will give you a plusher ride.
You could probably buil up a block around the pivot point to give it a new pivot point either side - but personally I'd look in to longer shocks first.
The last post was made 14 years, 157 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 42.09 Kb
