| jamesrs250 |
 jamesrs250 Nova Slayer
| unitynotsocri... |
 unitynotsocri... Banned
 Posted: 17:58 - 21 Oct 2011 Post subject: |
They should line up at two cycles of the 4 stroke cycle.usually at TDC or top dead centre.what you do is check when the inlet valve is closed and move the crank/flywheel slowly till they line up.They will line up 'twice' because of the ratio between the camshaft cog and the crankshaft cog.If you replace a camshaft cog 180 degrees out what happens is the valves smash against the pistons.
inlet and exhaust 'valve timings' are not symetrical.The chain and cogs are but to get better performance/tuning the 'cam profile' is different for each side of the valves,i.e.inlet and exhaust.
if it gets too confusing then get a CG.they have pushrods to operate the valves but very oddly only use ONE cam for both inlet and exhaust.this restricts the engine tuning but greatly helps with economy/reliability.
BCF members ,please correct if i'm wrong,i've just had my pain killers and some Vietnamese agent Orange cobbler fish! ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| jamesrs250 |
| unitynotsocri... |
 Posted: 18:27 - 21 Oct 2011 Post subject: |
because the top cog has twice as many teeth as the bottom cog ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| jamesrs250 |
| unitynotsocri... |
 Posted: 19:11 - 21 Oct 2011 Post subject: |
one of the beauties of strokers is the relativey cheap repair costs and the ease of tuning,as well as not having to f*** about with timing chains and valves,although modern strokers are pretty sophisticated pieces of kit thesedays,but thin on the ground with new models, ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| jamesrs250 |
| unitynotsocri... |
 Posted: 17:16 - 22 Oct 2011 Post subject: |
one of my favourite methods to cure knacked or oil burning small singles is to put some slick 50 in the oil.Its supposed to be used as a preventitive for car engines ,which have DRY clutches.i would'nt reccommend it on more powerfull bikes as it may not be very good for clutch plates that work really hard.It coats the hottest surfaces with PTFE,in practice it makes an engine smoother and counteracts the wear in the barrel/rings.
first used it years ago on an old 900 cc vw polo that had 107k on it.before using it the polo would slow down badly on hills and use a litre of oil for every 120 miles.After using it it was fine for another 15k then completly knacked. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
The last post was made 14 years, 253 days ago. Instead of replying here, would creating a new thread be more useful? |
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.58 - MySQL Queries: 13 - Page Size: 59.59 Kb
