| felicity |
 felicity Scooby Slapper
| felicity |
| unitynotsocri... |
 unitynotsocri... Banned
 Posted: 14:38 - 23 Oct 2011 Post subject: |
you need to put some bricks or a block of wood under the swing arm to raise the rear wheel just above the ground.if its still sticks abit then use a BLUNT rod or screw driver and gently tap it through.Check your wheel bearings and clean the brake while your there. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| felicity |
| unitynotsocri... |
 Posted: 14:54 - 23 Oct 2011 Post subject: |
dont know what to suggest.i once saw a lad use a tin of lighter gas,he sprayed it all on the axle to freeze it a little,not good for the planet but easier to get hold of than liquid nitrogen,although very dangerous. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| felicity |
The last post was made 14 years, 140 days ago. Instead of replying here, would creating a new thread be more useful? |
