Z-rated tyres on 125 bikes?
pepperami
PostPosted: 20:42 - 24 Oct 2011    Post subject: Z-rated tyres on 125 bikes? Reply with quote
Ok yet again I want to pick the mighty BCF`s brains Thumbs Up
As you are all aware I have a Sachs xtc 125 sitting in the garage slowly being made into a reasonable bike???
The tyre on the back is a 150/60 ZR17 Pilot Sport, and a damm fine tyre it is too.
However it needs replacing as it has cracks in it from when it sat for years without moving.
So I`m thinking to myself, does a 125 really need a Z-rated tyre?
What are the alternatives?
I seek your wisdom mighty BCF
Fizzer Thou
PostPosted: 21:04 - 24 Oct 2011    Post subject: Reply with quote
The extra expense of using a high performance radial tyre that is capable of over 130 mph is a bit lost on a 125.
How much do you want to spend on a replacement 'H' (up to 130 mph) rated tyre?
Pirelli make a 150/60H17 for £95 here https://www.fwr.co.uk/pirellit.htm
Always have a 'Plan B'
PostPosted: 21:09 - 24 Oct 2011    Post subject: Reply with quote
No reason for it to be a Z rated tyre, but Aprilia and Cagiva have both also used Z rated radials on 125s.
I would say find a suitable tyre and just make sure the speed and load ratings are adequate for the performance / weight of the 125. If it is a Z rated tyre then so be it.
tatters
Exxon Valdez
PostPosted: 21:14 - 24 Oct 2011    Post subject: Reply with quote
Higher speed rated tyres for larger bikes will also take far longer to warm up.
pepperami
PostPosted: 21:31 - 24 Oct 2011    Post subject: Reply with quote
Thank you much Thumbs Up !
Nexus Icon
PostPosted: 08:08 - 25 Oct 2011    Post subject: Reply with quote
Small caveat here; If bikes are anything like cars then you need to match the speed rating on the tyre that the bike came with from the factory, regardless of how ridiculous it might seem. Insurance companies are well known for not paying out if the incorrect tyre has been fitted, even if the speed rating of the new tyre exceeds the maximum speed of the vehicle.
Google should help you find the standard fitment from new.
Greetings from Shitsville!
PostPosted: 19:00 - 25 Oct 2011    Post subject: Reply with quote
In the UK I don't think that is true.
Nexus Icon
PostPosted: 19:13 - 25 Oct 2011    Post subject: Reply with quote
For bikes, you mean?
It's certainly true for cars. I know from personal experience.
pepperami
PostPosted: 19:29 - 25 Oct 2011    Post subject: Reply with quote
Right I`ve just got the manual and according to the data the rear tyre should be a 150/60 17r 66WTL / 150/70-17 M/C 69 HTL
So what is that in real money?
PostPosted: 19:44 - 25 Oct 2011    Post subject: Reply with quote
Don't think it is for either (although an insurance company trying to pull a fast one wouldn't surprise me).
Germany is stricter and does require that the tyre rating match the max speed of the vehicle.
Nexus Icon
PostPosted: 19:52 - 25 Oct 2011    Post subject: Reply with quote
150 is the width of the tyre in mm
60 (70) is the percentage of the width and designates the tye wall height in mm.
17 is the wheel diameter in inches
66(69) is the load rating of the sidewall in kilograms
r= Radial tyre
W = 260-270kph
M/C generally means motorcycle designated tyre
H = 200-210kph
TL usually means Tubeless.
I'm guessing as an m/c tyre can be crossply then the load and speed ratings are different. Other than that I can't explain why you have two alternatives.
Nexus Icon
PostPosted: 19:56 - 25 Oct 2011    Post subject: Reply with quote
I'll be bloody annoyed if it's not true for cars. Unfortunately it was about 15yrs ago now but I was refused a payout because the speed rating on the tyres on the car I'd just bought and insured didn't match the factory spec tyre.
I mean, I was bloody annoyed thinking it was true and I'll be even more annoyed if it isn't! Saying that, the speed rating of the fitted tyres was lower than factory spec if that makes a difference.
Either way, it's certainly something I'd advise people to be wary of.
PostPosted: 20:11 - 25 Oct 2011    Post subject: Reply with quote
As far as I know in the UK there is no such legal requirement, or even for the tyres to match the supposed max speed of the vehicle. Although go tanking along at 130 on T rated tyres wouldn't be viewed well (if you survived)! Load ratings are possibly easier to exceed by mistake.
Might be worth confirming with someone with more legal knowledge (eg, TC).
pepperami
PostPosted: 14:54 - 26 Oct 2011    Post subject: Reply with quote
Smile On an XTC? now that I`d like to see Smile Thumbs Up
Bezzer
PostPosted: 15:32 - 26 Oct 2011    Post subject: Reply with quote
Think you'll find in UK law a tyre just has to match the weight rating of the vehicle and just a speed rating of 70mph, the legal maximum speed limit for cars/bikes etc. There are a few exceptions for vehicles with a lower maximum speed.
We should think ourselves lucky, in Germany you can only fit manufacturers approved tyres so you might have a choice of only 2 or 3 if you're lucky, also every vehicle must have snow tyres fitted from November to March buggering up the majority of bikes which don't have anything listed as OE replacement.
pepperami
PostPosted: 16:39 - 31 Oct 2011    Post subject: Reply with quote
Just got back from the fitters.
I ended up getting a "Dunlop Sportsmax Qualifier" ? 150/60 Zr
Allegedly they had nothing to match the profile that was`nt Z rated??
Anyway I took it and I cant feel any wiggles or squirms coming from the rear end so I can only assume all is ok ?
I paid a bit more than I intended, but it`s done now and it`s one less thing to worry about when riding this particilar little bike Thumbs Up
tahrey
PostPosted: 20:53 - 02 Nov 2011    Post subject: Reply with quote
Can't the German fitters get away with a lower speed tyre (particularly winter ones) so long as they put a sticker in a prominent place on the dash warning what the car's new maximum safe speed is? I'm sure I've seen them before...
(EG the German wording for "Do not exceed 190km/h!"... i.e. 118mph... chance'd be a fine thing, eh?)
Not really helpful here I know, I'd set a "no bump" switch if there was one, but if it contributes to the global sum of vague and unconfirmed knowledge...
The last post was made 14 years, 328 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 97.21 Kb
