my ktm 125 exe project.
Damien-Rs
PostPosted: 19:58 - 25 Oct 2011    Post subject: my ktm 125 exe project. Reply with quote
hi there, i have a ktm 125 exe which im looking to get many new parts and fit them. i'm wondering whether a set of 99-00 ktm 125 sx plastics would fit?, also are bike-it raider headlight any good?, and after a decent digital speedo, i have seen the trail tech vector which im wondering how good/reliable they are?, also looking to get new wheels for the bike, does any one know of any good sites to buy cheap supermoto wheels?, im also on the look out for a strong universal side stand to fit the bike. i have got a standard downpipe with a standard 2009 exc silencer, but they do not slot together, are they ment to? instead ive had to get a steel connector made from the exhaust company down the road so that fits perfect now. one problem which i am a bit worried about whats causing it, is it has a bog in first then it hits the powerband, i'm not sure whether this could be caused by the jetting, the powervalve or anything else.
Many Thanks
Damien
dangerousdave
PostPosted: 21:20 - 25 Oct 2011    Post subject: Reply with quote
Hi Damien
Good luck with the project. I've always liked the ktm 125's as they have a great power to weight ratio.
Engine bogging could be a few things. First to check is that exhaust though. As they are not fitting together it sounds like you could have the wrong pipe and silencer combo. Also check for any leaks on the joining section of the pipe/silencer, or any leaks around the cylinder joint.
Apart from that then check/clean/replace the air filter, followed by a check of the spark plug colour to check the air/fuel mixture.
1988 Kawasaki KMX 200
Previous: Yamaha YZF1000, ZZR600, KMX200, DT50, KX80, CG125, PF50
Damien-Rs
PostPosted: 21:27 - 25 Oct 2011    Post subject: Reply with quote
ive checked the plug and its fine, the exhaust system seals together perfect now, i use 100ml oil to 5 litres of petrol, i will check the air filter tomorrow, what should i be looking out for?, i was wondering if it could possibly be a clogged powervalve/ needs adjusting??
Many Thanks
Damien.
dangerousdave
PostPosted: 22:11 - 25 Oct 2011    Post subject: Reply with quote
with the air filter, have it out and give it a good clean. wash it out with petrol and dry it with a rag/tissue. If there are any rips or holes in it at all, replace it. Then put a small amount of light oil on it and make sure it is evenly distributed all over the filter. It should not be dripping wet with oil when it goes back in the bike, give it a wipe down if necessary.
The powervalve can get gummed up easily on these bikes and do need fairly regular inspection to keep them operating smoothly. The problem happens more frequently if low-quality oil is used, as this leaves more deposits all over the cylinder and exhaust.
You can probably check the operation of the valve without doing a complete strip down of the cylinder.
When was the silencer last re-packed? When the packing gets full of exhaust gunge the low-end power will suffer. Same as if it has no packing at all.
What about the condition of the exhaust expansion chamber? Over time exhaust deposits build up in the chamber and slowly strangle they engine. Same if the pipe has any dents in it. They can be cleaned out using either a blowtorch, or using caustic soda.
Another thing to check is the condition of the piston and rings as they require fairly regular replacement on these tuned engines. When they are on the way out the performance of the engine drops. It is better to be safe than sorry when it comes to this sort of maintenance as if the piston rings suddenly fail they'll ruin the cylinder bore. If you don't know when they were last replaced then it makes sense to find out what condition they are in.
Damien-Rs This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
dangerousdave
PostPosted: 22:34 - 25 Oct 2011    Post subject: Reply with quote
Any air leaks will reduce the efficiency of the engine, yes. Its worth checking the carb rubbers and inlet manifold for cracks. Check all the fasteners are tight. Same with the exhaust, a leak at the cylinder head/exhaust join could leave you with a hole in the power delivery.
Damien-Rs
PostPosted: 22:37 - 25 Oct 2011    Post subject: Reply with quote
okay, well tomorrow i will check a few things then order a top end gasket set and check out the piston ect and possibly order a new air filter.
Many Thanks
Damien.
Supermotard37...
PostPosted: 00:31 - 26 Oct 2011    Post subject: Reply with quote
Hey damien, i also have a 01 ktm125 exc and im after a stand for it so if you get lucky let me know where i can get one and as for the bogging remove your carb and clean your jets its a peice of piss on these bikes and thats should solve your problem oh and enjoy your bike im loving mine there so good for wheelies Laughing Thumbs Up
Fuck off..!! "You absolute contraception malfunction"
Damien-Rs
PostPosted: 09:06 - 26 Oct 2011    Post subject: Reply with quote
awesome, i havent rode the bike yet, i bought the bike from someone who lives pretty close to me. my step dad rode it and said its bogging in first then hitting the power band late, he thought it could need a upjet where as the bike is standard and should have standard jetting. yeah sure mate, if i find a stand i'll let you know. i have found a few universal enduro side stands on ebay but havent a clue how strong they are.
Many Thanks
Damien.
Supermotard37...
PostPosted: 19:17 - 26 Oct 2011    Post subject: Reply with quote
Hey,damien i happend to visit the ktm store in market deeping...and they have stands for the ktm 125 exc 01 all of the components comes to about £80, also i asked about sm wheels and he said ktm lc4 wheels should just go straight on providing you have the bracket for the front calliper and spacers for it to fit he was rather good and seemed to know his shit unlike most mechanics who just blow hot air out of there arse Thumbs Up there website is....
www.gear4motorcycles.co.uk/
if you need any help with your bike id be glad to tryn help Thumbs Up
Damien-Rs
PostPosted: 19:31 - 26 Oct 2011    Post subject: Reply with quote
Thanks Mate, thats helpful now i know where to look, are you ordering a stand from there for yours? just thought ide ask as you wer after one. Smile
Many Thanks
Damien.
Supermotard37...
PostPosted: 23:17 - 26 Oct 2011    Post subject: Reply with quote
yeah man im gonna order a stand soon or next payday but ile pm and tell you if its all good ive also got to get a new exhaust gasket as well because mine if fookerd Laughing Thumbs Up
Damien-Rs
PostPosted: 09:23 - 27 Oct 2011    Post subject: Reply with quote
Sounds good pal Smile bet she's a little loud with blown exhaust gasket Wink and yeah just comment and tell me if the stands are any good Thumbs Up
Many Thanks
Damien.
also could anyone tell me if a trail tech kickstand for a ktm 250-525 exc would fit my bike??
Damien-Rs
PostPosted: 13:19 - 27 Nov 2011    Post subject: Reply with quote
does anyone know whether a set of wheels off a 2006 ktm 125 exc will fit my bike? and will the front work okay with the mechanical speedo? or will i need digital?
Many thanks
Damien.
HD
PostPosted: 18:40 - 07 Dec 2011    Post subject: Reply with quote
Not this shit again.
The last post was made 14 years, 351 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> Offroad & Supermoto All times are GMT
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 89.36 Kb
