Still vibrates.
Bojje
PostPosted: 11:59 - 08 Sep 2004    Post subject: Still vibrates. Reply with quote
Maybe some of you guys remember a thread a few weeks ago regarding my new bought mito.
I've changed the engine oil, but the problem is that it's the wrong oil (Castrol GPS for 4 stroke engines) But people said that it will work fine. I think that I'll buy Castrol MTX which is made for 2t engines. The two stroke oil that I bought was supposed to be the best, Castrol TTS.
Well, anyways I changed the oil and the bike worked better I think, but it was harder to find the netrual, if you guys know what I mean. Maybe it's the oil, I'm not sure.
And regarding the vibrations, someone told me that I should take off the spark plug and then pour two stroke oil in the cylinder head, around 6-7 drops. Could this be the reason why the bike vibrates? He said that the oil on the spark plug/cylinder head is dry since it has been standing for 7 years, but again I don't know.
It could also be the engine mounts since the previous owner changed the engine and god knows how good he put it back.
Or it could be my bottom end bearings since It's equipped with a 160 cc polini kit. I have no idea. But the bike vibrates too much.
It could also be the balancer shaft, but I have no idea how to check it or how to fix it. Someone also said something about a crankcase, I have no idea what that is.
I haven't got any experiences of 125 cc two stroke sportbikes but my Mito seems like it's slow. I didn't rev it much though, around 6 k rpms. It pulls but not that much as I thought it should.
But maybe it needs more reving. Or it could be something wrong with it, for instance the power valve or something that doesn't open.
The problem is that we don't know how a mito works, we haven't heard one and I'm like the only one with a Mito in my city (Gothenburg). I'm in a difficult situation.
Any help is needed.
Thanks
roozor
PostPosted: 12:22 - 08 Sep 2004    Post subject: Reply with quote
1st step is definatly to get decent expensive 2stroke oil, especialy if u have a highly tuned performance 2stroke, eg: nsr, rs , mito.
Could be wheel bearings, suspension or 1st thing 1st, check the handlebars, if their loose and such.
Bojje
PostPosted: 17:18 - 08 Sep 2004    Post subject: Reply with quote
The two stroke oil that I have is Castrol TTS, very good and expensive. The engine oil that I'm going to get is also a good oil made for 2 stroke engines.
So that can't be the problem, but I've noticed when the bike is in idle the fron tyre vibrates like hell but the rear doesn't. Maybe there are some loose screws.
Robby
Dirty Old Man
PostPosted: 18:12 - 08 Sep 2004    Post subject: Reply with quote
You mentioned changing the oil and using 2 stroke oil.
2 stroke oil goes in a transparent bottle, normally under the seat or fuel tank. You never change it, just keep the bottle topped up.
You change the gearbox oil occasionally - this is like changing the oil on a car, you undo the sump plug, drain the contents, refill with 4 stroke oil.
2 stroke oil for the engine, 4 stroke oil the gearbox.
It will feel slow below 6krpm, they peak up around 8k. Its a 2 stroke, thrash it.
125s vibrate, and if its got a 160 kit its going to vibrate more. Live with it.
Make sure you have some 2 stroke oil in the bottle before riding it. If you've been riding it with no oil in the bottle, you've ruined the engine.
Bojje
PostPosted: 20:01 - 08 Sep 2004    Post subject: Reply with quote
Well my friend, I think that you're wrong since there are 2 stroke engine oils for gearboxes/engines, so why would 4 stroke engine oil suit 2 stroke engines? This one: https://www.proformanceusa.com/castrol/castrol_mtx_transmission.htm
And yes, I've filled the regular 2 stroke oil under the tank... For this I used Castrol TTS: https://www.castrolauto.com/products/productpage.asp?product_category=5&product_id=34
This bike is really vibrating... the windshield and the tachometres and the front wheel vibrates, you can see it. Especially when you give it a little gas up to say around 3-4000 rpms. Over that it doesn't vibrate that much.
mr jamez
PostPosted: 20:20 - 08 Sep 2004    Post subject: Reply with quote
so when the bike is parked up, with the engine running, the front wheel etc is all wobbling? Or is this while riding the bike? if so the engine will not cause the front wheel to wobble, I would suspect a dodgy front wheel bearing or perhaps the wheel is loose!
Bojje
PostPosted: 21:06 - 08 Sep 2004    Post subject: Reply with quote
Yes, that could be it but I'm not sure. You can also feel the vibrations with your ass.
Major_Grooves
The Doctor
PostPosted: 21:13 - 08 Sep 2004    Post subject: Reply with quote
Same thing, different name, make money from people who don't know difference. Probably.
About me|@Major_Grooves|My company|Digg|Flickr
Bojje
PostPosted: 22:14 - 08 Sep 2004    Post subject: Reply with quote
I can only tell you that when I changed the oil a few days ago, I poured Castrol GPS 4 stroke oil the gearbox felt strange. Really hard when you press it in neutral, like if it's in 1st gear. Feels wrong.
tatters
Exxon Valdez
PostPosted: 22:54 - 08 Sep 2004    Post subject: Reply with quote
looks like on that site you can,t get "R2 Superbike" in the USA which is a better injector/pre-mix 2 stroke oil Confused
Jrod
Page 3 Girl
PostPosted: 02:14 - 09 Sep 2004    Post subject: Reply with quote
Just enjoy the vibrations. Wink Laughing
PostPosted: 11:30 - 09 Sep 2004    Post subject: Reply with quote
Cagiva just say to use Agip Super F1 15W50 oil, which I think is a normal 4 stroke engine oil. Some companies do make specific oils for 2 stroke gearboxes which is probably what you have got. However I don't know if it is a suitable weight for the Mito.
I would check that all the engine mounts are tight as these could well cause vibration. Also the balance shaft could be set up wrongly. Best to download a copy of the manual and check. However the big bore kit could well cause vibration as the piston is likely to be heavier than the standard one.
Performance wise it is a highly tuned 2 stroke. At low revs it will nto have much go at all. Warm it up properly and then rev it hard and it will go well. Our old Cagiva Freccia (same engine as an early Mito) only started to make power at 9500rpm.
Bojje
PostPosted: 23:26 - 09 Sep 2004    Post subject: Reply with quote
People have said that I should use 10w40 for the engine oil. Is that wrong?
And yes, I have a manual downloaded from the internet, but it's for the older Cagiva... But as far as I know the engine is nearly the same.
In the manual it says 15w50
mchaggis
PostPosted: 00:28 - 10 Sep 2004    Post subject: Reply with quote
There's not a load of difference between 15-50 and 10-40, or none that I noticed when I had to use 15-50 in an emergency. There is a large range of oils you can use, whilst they are different from each other, they all do essentially the same job. Stick with what the manual says would be the best thing imho.
Bojje
PostPosted: 15:14 - 10 Sep 2004    Post subject: Reply with quote
The engine from the older mito and the new one that I've got (Year 95) with 7 speed gearbox can't be the same right?
The last post was made 22 years, 46 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 90.81 Kb
