| splattimer |
 splattimer L Plate Warrior
 ..... Quote Me Happy
| splattimer |
| Alex_B |
 Alex_B Brolly Dolly
 Posted: 14:39 - 28 Oct 2011 Post subject: |
General consensus is: It will do what you need, but not for 3-4 years
They seem to have a bad rep but I only know what I read (never had one) and that is they are bad.
Underpowered, fall apart pretty quick and all that horrible shit.
Saying that, if all you want is 50 mph then it might be OK but for £800 you could get a decent CG125 or similar.
TL;DR will be along shortly to extol the virtues of not spending on a bike and doing the tests
If you want to stay on a 125 for 4 years though then that is a different kettle of fish altogether... ____________________ My Lane Position is always AWESOME!! |
| Rogerborg |
 Rogerborg nimbA
 Posted: 14:43 - 28 Oct 2011 Post subject: |
Hi, I have an HN125-8 sitting in the garage. Not all Chinese-branded bikes are the same, and the HN is generally well regarded by its owners.
See https://www.reviewcentre.co.uk and https://www.huoniao-owners.co.uk/forum
Pros:
It's simple, economical, there's not a lot to go wrong with it, parts are readily available, and it's very easy to ride. The DSA list it as an A2 bike, so there's no problem using it for passing a test. The build quality on my 2008 model is surprisingly good, nothing's gone wrong with it that I didn't deliberately "improve" myself until it stopped working. Putting it back to stock always gets it running sweetly again.
Overall I've really enjoyed owning it.
Cons:
It's not as easy to insure as the Lexmoto Vixen - that's exactly the same bike, just with a different badge on it, as is the Haotian Vixen HT125-8.
The RHS exhaust hangar is prone to snapping from pressure from the brake return spring. Keep an eye on it, replace for £20 or get a Honda CM125 original from a breaker.
The kickstand cut-out switch wiring runs via a connector block that's placed right under the bike and is prone to corroding. Grease it up, re-wire in a straight run, or just take the switch off.
Exhaust studs can be prone to snapping - this is a problem on a lot of the FMI156/157 copy-engines. Keep and eye on them and replace with stainless steel if necessary. Mine have been fine, I should add.
tl;dr version - if you're going to go Chinese-branded, try to find a slightly used Lexmoto Vixen, pay about £400 for it, then ACF-50 all over.
But when all's said and done, if you're looking for reliability, an older Japanese-branded or built bike is more likely to do the job.
The Hyosung GT 125 is another candidate. Korean made, decent quality, but can be had for near-Chinese prices. ____________________ Biking is 1/20th as dangerous as horse riding.
| blade023 |
 blade023 Trackday Trickster
| P.addy |
 P.addy Red Rocket
| JoeDougieDoug... |
 JoeDougieDoug... World Chat Champion
| Paris2 |
 Paris2 Nearly there...
| Rogerborg |
 Rogerborg nimbA
 Posted: 16:38 - 28 Oct 2011 Post subject: Re: Newbie needs advice on Chinese bike |
| Paris2 wrote: | In general NO chinese bikes are reliable. |
That's not being general, it's being absolute.
| Paris2 wrote: | There are plenty of 125cc Honda's that you will be able to get for £800, which are reliable and will last 4 years (if treated well of course). |
Agreed.
| Paris2 wrote: | Parts for the usual Jap brands will be plentiful and cheaper too. |
All of the parts on the HN125-8 are Honda cloned. The running gear is CM125, the engine is a clone of the CG125.
Everything, including engine internals, is available next day from https://www.ChineseMotorcyclePartsOnline.co.uk, from one of the importers, or from eBay. Parts are not a problem for that bike. ____________________ Biking is 1/20th as dangerous as horse riding.
| splattimer |
| Rogerborg |
 Rogerborg nimbA
 Posted: 11:12 - 29 Oct 2011 Post subject: |
It's a tricky one. Something to bear in mind is that any new bike will depreciate sharply. Granted, you can't lose much (in absolute value) on an £800 bike, but you'll lose less on an older £800 Japanese branded bike.
I got my HN125-8 because I essentially wanted a bike shaped pile of bits to tinker with. I was actually hoping that it would develop a bunch of problems: it's sorely disappointed me by being boringly reliable.
A haven't updated it for ages, but I recorded my experiences over at https://bikeinabox.blogspot.com for posterity. Sadly, I think the HN now comes pre-built, so you don't have the initial fun of unboxing it and bolting it together.  ____________________ Biking is 1/20th as dangerous as horse riding.
The last post was made 14 years, 164 days ago. Instead of replying here, would creating a new thread be more useful? |
