Tinny tapping sound when decelerating?
EazyDuz
PostPosted: 16:33 - 30 Oct 2011    Post subject: Tinny tapping sound when decelerating? Reply with quote
I dont think it sounded like this before but not sure if its normal or not.
GZ125, when i slow down from about 30mph or more, i can hear a tinny tapping sound. The sound stops if i pull the clutch in. It only does it when slowing down never when im accelerating.
Tappets are correct, chain correctly tightened. Is this normal?
andy_uk
PostPosted: 17:36 - 30 Oct 2011    Post subject: Reply with quote
If the bike's ticking over can you still hear it?
As it disappears when you pull the clutch in I would guess that it's more engine related than gearbox etc.
You can narrow it down by putting a long screwdriver to your ear (blunt end!) and putting the other end on various (non moving) bits of the engine.
Or you could get one of these which are a little easier to use Smile
Aprilia Classic 125, GS500E, ER5-A1, ER5-C4, ER6 & an XJ6 project frame...
EazyDuz
PostPosted: 17:54 - 30 Oct 2011    Post subject: Reply with quote
No it doesnt happen when just ticking over, just at a certain speed as it slows down.
spyuggy
PostPosted: 22:54 - 31 Oct 2011    Post subject: Reply with quote
I would check your clutch basket and see if the dogs are slack.
Also look at the Centre bolt, to see if it is torqued up properly
Treat each day as if it was your last, because one day you will be right.
EazyDuz
PostPosted: 23:46 - 31 Oct 2011    Post subject: Reply with quote
I have no idea where to find those?
Bezzer
PostPosted: 14:32 - 01 Nov 2011    Post subject: Reply with quote
Never heard a clutch make the sound the OP is describing, you usually get a "rumble" from the clutch such as on a lot of Hondas and it goes when you pull the clutch in and never causes any other problem, on others it's always there.
Check the exhaust header/collar to make sure it isn't loose that can tap on and off load but other than that it's as suggested earlier go over it with a stethoscope/screwdriver to the ear to try and narrow it down more, rev it and see if you can hear something.
EazyDuz
PostPosted: 15:01 - 01 Nov 2011    Post subject: Reply with quote
It sounds absolutely fine when i rev it in neutral. Maybe it always has made that noise and im just being paranoid im not sure.
The last post was made 14 years, 362 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 51.34 Kb
