Starting problems Aerox 50cc
Diesel
PostPosted: 22:11 - 28 Oct 2011    Post subject: Starting problems Aerox 50cc Reply with quote
Hi, there i have a 54 aerox with an 07 engine, i was running it to work and after work finished i tried starting it and it didnt start there is petrol going to the spark plug theres compression but there was quite a bit of petrol but it didnt star first of and it always does so any help again appreciated
at106
PostPosted: 10:12 - 29 Oct 2011    Post subject: Reply with quote
Has it got a spark? If not try fitting a new plug and charge the battery.
Diesel
PostPosted: 14:08 - 29 Oct 2011    Post subject: Reply with quote
yer theres spark
at106
PostPosted: 16:59 - 29 Oct 2011    Post subject: Reply with quote
When you removed the spark plug was it very wet? Ifso dry the spark plug, leave it out the engine and turn the engine over a few times, this should remove any excess fuel from the cylinder.
Diesel
PostPosted: 21:16 - 31 Oct 2011    Post subject: Reply with quote
hi, thanks for the reply, i have done this but there still loads in the cylinder
at106
PostPosted: 22:19 - 31 Oct 2011    Post subject: Reply with quote
Are you sure it's definitely fuel?
Diesel
PostPosted: 19:08 - 01 Nov 2011    Post subject: Reply with quote
yer 100%
at106
PostPosted: 19:58 - 01 Nov 2011    Post subject: Reply with quote
Diesel wrote:
yer 100%
If theres lots of fuel in the cyclinder and turning the engine over doesnt shift it leave the spark plug out for a while and it should evaporate.
If not turn the fuel tap off or remove the fuel vacumn pipe and remove the spark plug then turn the engine over.
The last post was made 14 years, 360 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.11 - MySQL Queries: 13 - Page Size: 52.35 Kb
