Poor runing at high speed - Suzuki Bandit 600
birbal
PostPosted: 20:19 - 01 Nov 2011    Post subject: Poor runing at high speed - Suzuki Bandit 600 Reply with quote
Hi everyone!
First of all I would like to mention that my mechanical skills and knowledge are not so great. I’m specialized in electronics.
So the problem is Suzuki GSF 600S Bandit 2001 K2. At the end of August 2011 I have changed the entire exhaust system (I don’t know if is relevant to my problem): new downpipes, new link pipe and new Beowulf silencer. After this operation I could feel the difference, in speed, power and of course different sound.
About three weeks ago it started to lose power at high speed (above 40-50 mph) and also there is a weird sound but I can’t figure where it came from and also I don’t know if I can describe it (maybe I will try to make a video in a few days, if I can record the difference). The thing is that when I start the bike in the morning, everything is absolutely fine...no weird sound, no difference in power. After about 3-4 miles of riding it starting to lose power if I keep it over 40mph, over 5-6k and the sounds appear. I mean I’m still able to drive it but is not normal...it doesn’t have that ‘thrill’ anymore.
What I’ve done so far:
- Check and clean the air filter
- Check and clean the spark plugs that are in very good condition
- Tight all the bolts on downpipes
- Check the oil level
The problem is still there and I don’t understand when the engine is cold, everything is perfect...after 2-3 miles, is not so great.
Does anyone have any idea?
Thanks!
Bezzer
PostPosted: 00:19 - 02 Nov 2011    Post subject: Reply with quote
Is the exhaust the only thing "non standard" , have you changed the air filter as well to a K&N or whatever also ??.
A Bandit is usually OK and copes with either an aftermarket can or air filter but will be a bit lean if both are done, a freer flowing set of downpipes.link and endcan can be a bit much as well .
Leanish running usually sounds and feels "crisper" at first then you can suffer a bit with it running too hot, if it's way too lean you'll damage valves etc.
Have a look at your plugs again to check their condition which should give you a pointer, with you changing the whole exhaust system may have been too much and it needs rejetting. A dyno run would let you know for sure.
If you're happy with fuelling then it could be on the electrical side, HT leads,caps,coils etc breaking down when everything gets hotter.
birbal
PostPosted: 05:08 - 02 Nov 2011    Post subject: Reply with quote
AS far as I know, the exhaust is the only thing non standard. Also the air filter was K&N and I treat it with K&N air filter cleaner/recharger kit even that it was pretty clean. So there wasn't any change in the air filter.
I think I will go very soon for a dyno run to see where is the problem.
temeluchus
PostPosted: 06:25 - 02 Nov 2011    Post subject: Reply with quote
Poor running when the machine warms up usually means you are running rich.
Often caused by one or more of the following:
Blocked air filter
incorrect float height
dirty float needle/seat
worn float needle/seat
worn emulsion tube
faulty float
one of these is a likely culprit.
Bezzer
PostPosted: 11:20 - 02 Nov 2011    Post subject: Reply with quote
birbal wrote:
[AS far as I know, the exhaust is the only thing non standard. Also the air filter was K&N and I treat it with K&N air filter cleaner/recharger kit even that it was pretty clean. So there wasn't any change in the air filter.
Dyno run will be wise, as I said exhaust and an aftermarket filter ,which you do have, will certainly make it run lean.
birbal
PostPosted: 13:22 - 03 Nov 2011    Post subject: Reply with quote
I had today the Dyno run and like you said is running rich. There is a lot of fuel but no so much air, and the AFR ratio is far below the normal limit. I will leave it next week in service coz adjustments on carbs are far beyond my mechanical knowledge.
Thanks everyone for your ideas!
Bezzer
PostPosted: 14:06 - 03 Nov 2011    Post subject: Reply with quote
Nice one Thumbs Up , at least you aren't damaging it as such running rich, weird though full exhaust and a K&N should allow a fair bit more air in, most have to rejet to if they do that. K&N isn't overoiled is it??.
temeluchus
PostPosted: 00:28 - 04 Nov 2011    Post subject: Reply with quote
Its probably shit in the float valve or a worn out needle.
The last post was made 14 years, 345 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.87 - MySQL Queries: 13 - Page Size: 58.26 Kb
