Plug On Compressor?
johnsmith222
PostPosted: 02:14 - 02 Nov 2011    Post subject: Plug On Compressor? Reply with quote
Hi guys.
Can I put a plug on the end of my compressor to power it from the mains?
If so, what size fuse will I need and how do I tell which wire goes to live and which goes to neutral?
It is the cigarette lighter type plug that is on it atm.
I think I might not be able to do it because it's a 12v compressor.
Thanks for any help.
Shaft
PostPosted: 02:26 - 02 Nov 2011    Post subject: Reply with quote
I'll give you a clue.
Your compressor is designed to run on 12 volts.
Mains electricity is 240 volts.
Guess what will happen when you plug it into the mains Wink
Martay
PostPosted: 02:30 - 02 Nov 2011    Post subject: Reply with quote
I bet it would make a fantastic noise right before it implodes!! Laughing
Eat well, poo hard Very Happy
Drives: Cavalier 2.0 16v
Shaft
PostPosted: 02:33 - 02 Nov 2011    Post subject: Reply with quote
^^^ it would be a fun thing to do, but I think I'd want to turn it on with a very long stick Laughing
johnsmith222
PostPosted: 02:34 - 02 Nov 2011    Post subject: Reply with quote
My pal works for his electrician dad and wired it up to a plug. Thought there was a reason it didn't work.
I think it might be fucked now. Laughing
I'll attach the wires to a 12v battery and see what it does. If it works, I'll just wire on one of the plugs that come on optimate chargers.
He has good intentions. He robbed me 1.5mm cable to wire in some plug sockets. Everywhere online says use 2.5mm minimum. I'll just use the 1.5 for lighting.
It sounded like it went alight, without actually going on fire. I think the fuse saved it. Laughing
Shaft
PostPosted: 02:47 - 02 Nov 2011    Post subject: Reply with quote
Sounds like either your mate's Dad is a really shite electrician, or your mate needs to pay more attention, before he burns someone's house down!
Using the plug from an Optimate won't help you, it's the transformer in the Optimate that converts mains power to 12v.
So, if you want to plug your compressor into the mains, what you need is a transformer, not just a mains plug.
johnsmith222
PostPosted: 03:04 - 02 Nov 2011    Post subject: Reply with quote
The dad really knows his stuff. His son is still learning and making mistakes.
Sorry, I meant the little square/oval socket type thing that I'd put on the end of the compressor, then I'd plug it into the charging lead for the optimate on my bike.
The only issue is the inline fuse might be too low. Can't mind what amp it was but easy to change out if needed.
Either that or I'll just get one of the big handpumps. Razz
Im-a-Ridah
PostPosted: 05:33 - 02 Nov 2011    Post subject: Reply with quote
Might not appear to do anything much at all, which is far more dangerous.
So long as on the back of the "socket type thing" it says 12V output and it has a current rating in mA or A which is higher than that written on the compressor.
Just to repeat what others have said, it cannot* be wired directly into the mains power without a transformer (which the "socket type thing" may be).
*excluding more exotic options
Personally I'd say go with the foot pump Wink
johnsmith222
PostPosted: 06:15 - 02 Nov 2011    Post subject: Reply with quote
I was referring to wiring on one of these blocks.
https://www.xrv.org.uk/forums/attachment.php?attachmentid=7588
As my bike has a charging lead from an optimate charger attached to the battery. It means the pump could be plugged straight into that.
sickpup
Old Timer
PostPosted: 10:12 - 02 Nov 2011    Post subject: Reply with quote
I sincerely hope you never breed.
t121anf
PostPosted: 10:16 - 02 Nov 2011    Post subject: Reply with quote
just buy one of these
https://www.ebay.co.uk/itm/KAMPA-240V-12V-TRANSFORMER-RECTIFIER-/170708337525?pt=UK_Campervan_Caravan_Accessories&hash=item27bf028375
PostPosted: 10:22 - 02 Nov 2011    Post subject: Reply with quote
From the ad...
PLEASE NOTE - This will not run most air compressors, water pumps or three way fridges.
ElliotReidMD
PostPosted: 11:39 - 02 Nov 2011    Post subject: Reply with quote
Could you please let us know where you live in case any of us need to get an electrician in to do some work? I'm sure we'd all like to know you mate is hundreds of miles from us so we can't, unknowingly, call his dad and him in. Wink
Current Bike: Kawasaki Versys
PostPosted: 12:56 - 02 Nov 2011    Post subject: Reply with quote
You will need a meaty transformer.
My large battery charger only just manages it - it has a 120A 'boost' function' for quick charging and jump starting. Even then, it struggles a little with the compressor plugged straight in, but if you have a dead 12v battery in the loop it works fine (presumably helps smooth stuff out etc.)
It's quite possible you'd blow an optimate trying to do it, nowhere near enough currant coming through.
Presuming this is for your bike, why not make some wiring to run it from the bike?
t121anf
PostPosted: 13:12 - 02 Nov 2011    Post subject: Reply with quote
##Paddy## wrote:
From the ad...
must learn to read before posting....
hellbound
PostPosted: 13:32 - 02 Nov 2011    Post subject: Reply with quote
Breed?..I am not sure he should even be allowed out unescorted!
May you always see the road rising up to meet you and your enemies defeated in the mirror behind.
10 pence Short
PostPosted: 13:33 - 02 Nov 2011    Post subject: Reply with quote
https://www.grubreport.com/photos/currants.jpg
Drooling Drooling Laughing
I haven't had a cont all day, drinkstable.
PostPosted: 13:40 - 02 Nov 2011    Post subject: Reply with quote
Exactly, how are all those going to get through the ickle optimate wire?
oldpink
PostPosted: 13:42 - 02 Nov 2011    Post subject: Reply with quote
thats a pretty basic mistake, something you would be told from day 1 on the job
check the voltage and the amp rating before you connect anything
Snodvan
PostPosted: 14:24 - 02 Nov 2011    Post subject: Reply with quote
Brilliant!
One totally screwed Optimate as well. Expensive
Snod
04 (UK Reg) BMW F650cs, but really 02 first Reg in Holland
Im-a-Ridah
PostPosted: 14:28 - 02 Nov 2011    Post subject: Reply with quote
There is no point buying any fancy transformer for £15 to power a small pump when a foot pump can be had from ebay for £5 delivered
https://www.ebay.co.uk/itm/Single-Barrel-Cylinder-Foot-Pump-Air-Inflator-Pressure-Gauge-Car-Bike-Van-Tyres-/150660271693?pt=UK_Sports_Leisure_Cycling_BikePumps_SR&hash=item23140d4e4d
Job done.
Michael47
PostPosted: 14:40 - 02 Nov 2011    Post subject: Reply with quote
Ohh .. so this is why they need to warn people not to dry pets in microwave ovens! Idea
https://3.bp.blogspot.com/_5zcD7Em8zlo/Sf3km7LA8sI/AAAAAAAAApA/tRNDcWjUgac/s400/wacky+warning+label.jpg
johnsmith222
PostPosted: 15:13 - 02 Nov 2011    Post subject: Reply with quote
I fail to see in what way this would be retarded or would fuck my optimate charger?
But thanks for the ripping anyway. Rolling Eyes
https://i14.photobucket.com/albums/a324/david_m213/optimate.jpg
At least I can read. Rolling Eyes
PostPosted: 15:25 - 02 Nov 2011    Post subject: Reply with quote
I'd also presumed you were powering it from the optimate it's self.
The above is exactly what I have on my KTM (though wired in all myself) and it works fine. Think I've got a 10A fuse on there.
johnsmith222
PostPosted: 17:08 - 02 Nov 2011    Post subject: Reply with quote
You may have presumed that I was powering it from the charger, but at least you went about it in a nice way.
Yeah, if I remember right the compressor is 10A max so I'll put a 10A fuse inline and see how it gets on with that.
Thanks again for everyone that helped.
The last post was made 14 years, 359 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 131.29 Kb
