| Martay |
 Martay World Chat Champion
 Posted: 00:51 - 02 Nov 2011 Post subject: Sudden lean-ness |
Hi,
My little Honda City Express is the bike in question. It had a top end done by myself ( ) about 300 miles ago. Has been running fine. Oil pump failure caused the blow up, so that got replaced too. Anyways, up until now i have been running with the oil pump set up correctly AND putting a bit of 2t oil in the fuel. I thought this would give the piston time to sort and the oil pump to run properly, also, i forgot to stop putting oil in the petrol!!
Anyways, my friend points out to me the bike will be running horrifically lean, so i drained the tank, and its just running on the oil pump and neat petrol. Only now though, it seems to be running lean. On just petrol, the plug is a really light tan colour, and the engine gets really hot and smells bad. It smokes on cold start up so im sure its getting 2t oil through.
Confused.com! I would have thought i would get it running lean when its getting 2 or 3 times the ammount of oil it was ment too?
If thats makes sense, help!!
Ta ____________________ Eat well, poo hard
Drives: Cavalier 2.0 16v
Rides: Slightly ratted Honda City Express  |
| Bezzer |
 Bezzer World Chat Champion
| Martay |
 Posted: 02:18 - 02 Nov 2011 Post subject: |
Hi,
I understand that. At first when i was running it on oil feed AND premix, it was running normally. I would have expected it to run lean as the premix'd oil was taking the place of fuel. It ran properly and didnt get hot, but smoked excessivly.
Now i have stopped the premix and the bike is set as intended, it is running lean (i think). The sparkplug is coming out light brown in colour, and running extremely hot. The lube is working fine. The pump and pipes were replaced when i rebuilt it. It seems to idle noticeably higher than it used to, but this isnt a real issue.
What would cause an otherwise standard bike to suddenly go from running normally to very hot and, according to the plug colour, lean? ____________________ Eat well, poo hard
| Suntan Sid |
 Suntan Sid World Chat Champion
| jjdugen |
 jjdugen World Chat Champion
The last post was made 14 years, 349 days ago. Instead of replying here, would creating a new thread be more useful? |
