t piece
blahheed
PostPosted: 21:42 - 02 Nov 2011    Post subject: t piece Reply with quote
where can i get a fuel t piece
6mm either side
8mm in middle
Raffles
PostPosted: 23:07 - 02 Nov 2011    Post subject: Reply with quote
An unequal 6x6x8 ''t'' piece does not seem to be a readily available item. One solution would be to use an 8mm equal ''t'' plus a couple of 8mm to 6mm reducers.
Casper
PostPosted: 05:46 - 03 Nov 2011    Post subject: Reply with quote
Is this the part that sits between carbs? fuel goes in the middle and this part sends it along to either carb/carbs
MickC
PostPosted: 07:54 - 03 Nov 2011    Post subject: Reply with quote
If its for fuel then the sizes should be equal. For example when i removed my AFV i used a 8/8/8 T piece.
If, on the other hand, you are replacing a default part then check the parts fiche for a number for what ever make and model your bike is (giving that info on a post helps a great deal in answering a question)
XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1
The last post was made 14 years, 338 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.09 - MySQL Queries: 13 - Page Size: 38.24 Kb
