Brake lights law. - SORTED
McFlufferson
PostPosted: 23:14 - 03 Nov 2011    Post subject: Brake lights law. - SORTED Reply with quote
So, the brake light works for the front brake, but doesn't work for the back. I understand it might be to do with the rear switch, but if it is it'll take a bit before I can get one right now.
What's the law on this? Do both brake lights have to be working to be legal? I mean, I don't expect I'd get pulled because I'd be using the front anyway most of the time, but do I need to be worried?
Also any tips on what else could be causing it would be useful.
Think that you'll stay loyal to a loving bike? So did I. Only rich men can afford to stay loyal. The poorer of us will whore ourselves out to any two wheeled monstrosity that will take us.
weasley
PostPosted: 23:22 - 03 Nov 2011    Post subject: Reply with quote
It'll fail an MoT like that but unlikely anyone would notice unless you were stopped for something else and the bike given a once over.
Teflon-Mike
tl;dr
PostPosted: 23:30 - 03 Nov 2011    Post subject: Reply with quote
All motorcycles should have brake lamp that iluminates on either front or rear brake operatrion.
Excemptions exist; vehicles with no lights, under 'off-road' adaption; machines built before I think 1982 only have to have one on either front or back.
Are you sure the switrch is 'duff' though. Rear brake switches often sieze from lack of use, and or dont get adjusted.
Common one on drum brake bikes is that they dont get adjusted, brake does, and eventually the spring between pedal & switch is so stretched it never pulls switch far enough to work it.
Bit of prodding, some penatrating oil, WD40 and an old tooth brush, probably find it'll 'fix' with little more than a bit of patient fiddling
Bezzer
PostPosted: 23:34 - 03 Nov 2011    Post subject: Reply with quote
It's pre 1986 that you only need either front or back brake to work the light. From April? '86 you need both to work.
McFlufferson
PostPosted: 23:36 - 03 Nov 2011    Post subject: Reply with quote
Hm. Yeah I don't know if it's duff. I haven't looked. I will take a look tomorrow and fiddle as you suggest. It wouldn't be the stretched spring though then because it's disc brake? It won't be lack of use either. I certainly do use it.
Maybe something's just come loose or.. something. I don't know. I have given the back brake some stick before now and I couldn't really say when it stopped working.
Thanks for the advice.
Ohhh.
It's a 1985 model. : D
Though I do know it did work before, so I should check it out anyway. But that is good to know.
McFlufferson
PostPosted: 14:04 - 04 Nov 2011    Post subject: Reply with quote
Sorted. Turns out it just needed a blast of WD40 and a bit of an adjustment. Thanks a lot for the help.
The last post was made 14 years, 348 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 51.03 Kb
