Anti-Scrote Devices
Nai
PostPosted: 00:01 - 04 Nov 2011    Post subject: Anti-Scrote Devices Reply with quote
After having my bike stolen twice in a couple of weeks I got myself one of them big Oxford chains, chained my bike to a tree, and today found some buggers had a go at my chain.
So, anti scrote devices. I browsed Ebay and saw a cheapy alarm, Cyclone 2 or something. Anyone had one? Any good? Also them brake disk lock things, I assume they are all the same sorta thing, padlock for the disk, any difference between them?
Also, balls to my insurance next year. My street has become so crime ridden my postcode sucks for insurance, and the 2 thefts have cracked my insurance up (bout £50 each despite not claiming :-/ ). Shouldn't have called the police for the secound one considering they did wank all the first time.
Marmalade
PostPosted: 00:05 - 04 Nov 2011    Post subject: Reply with quote
I've hotwired one of my bikes and start it from a hidden switch.
Thieving lowlife can spend as long as they like screwdrivering the lock, it will never ever start Laughing
Oh yeah. The cyclone is very good for the money. Had a few on various bikes.
Plenty of threads here about the cyclone alarms
JoeDougieDoug...
PostPosted: 00:11 - 04 Nov 2011    Post subject: Reply with quote
Twice!? Wow thats bad. Shocked
My friend has one of those 2-way pager alarms for his YZFR125, it has a under-seat sensor so if anyone sits on the bike, it lets the owner know via a pager keyring, and if anyone tries to start the engine, it goes ape shit. They're on ebay for about £50, so not bad.
I personally have attached to a ground anchor on my bike (one Oxford, and one unbranded), The stock steering lock and I'll soon be getting a movement alarm and a new disk lock. If someone wants your bike, they will get it, the trick is to slow them down as much as possible.
Teflon-Mike
tl;dr
PostPosted: 00:21 - 04 Nov 2011    Post subject: Reply with quote
Cyclone is brilliant VFM. Not the most sophisticated alarm, but certainly one of the cheapest for £25 delivered, and does pretty much as much as anything else. Pretty easy to wire too.
Disc locks. Cheapo's can be bent off the disc. So what? They say 'think Twice', they'll never stop the deturmined having a go, of lifting thing in the back of a van. I like the alarmed ones, as they tend to go off if you forget to remove them!
Chain & something to chain to, is the real 'stopper' but again, only slows down the deturmined.
Imobilisers and 'stuff'? well, Cyclone comes with one, if you have it, may as well use it. But its only minor frustration to a tea-leaf. Any-one that can get past disc lock or chain, ent going to be sat where you left it fucking about with wires! They'll be in a dark alley, back of a van or warm lock-up.. in which case working at thier leisure wont take them long to suss it.... if they even bother, and dont just strip the thing for bits.
You'll never make a bike completely thief proof, and get to the level of tracking systems? Well, only any use to get bike back after its 'gone'... would you really WANT it back, then?
Ingah
PostPosted: 01:42 - 04 Nov 2011    Post subject: Reply with quote
Almax 3, cyclone cheapie alarm, Alpha Dot or Datatag sticker (Alpha Dot/Datatag kit optional, but Alpha Dot is cheaper so i'd go for that Very Happy) and then you can relax. A little.
-- Ingah
hellkat
PostPosted: 01:14 - 05 Nov 2011    Post subject: Reply with quote
Instructions, please.
(which I will diligently pass on to my fella to decipher, he's better with electrickery than me) Smile
lllN30lll
PostPosted: 01:17 - 05 Nov 2011    Post subject: Reply with quote
F*ck the oxford chains off for a start, they can be cropped in seconds.
Almax chain and hardy ground anchor Thumbs Up
temeluchus
PostPosted: 01:43 - 05 Nov 2011    Post subject: Reply with quote
I find the best way is to put quite a few security devices on the bike. Chain will be the most obvious to deter a casual thief but for the determined a defence in depth is best.
chain through wheel/forks/frame to something sturdy, disk lock front, u-lock through the rear wheel etc etc. You can buy alarmed disc, U-lock and padlocks. I have a pair of cheap alarm padlocks which I hide on the bike so if its disturbed it makes a racket.
if you are leaving it unattended for a long time, I put the K on its centrestand, tie the centrestand to the front wheel with a cargo strap and remove the rear wheel. Another is to put the bike in first and remove the gear lever. On some bikes its possible to remove the ignitor unit easily enough.
MinhDinh
PostPosted: 02:48 - 05 Nov 2011    Post subject: Reply with quote
A sensative alarm with a bike cover works. The cover sort of hides the bike, but also if moved should set the alarm off. A very thick chain or indeed an Almax if it is in budget. Another thing is yourself, and your neighbours. If you can get each other being look outs or just being visible quite often, they probably will start to look else where.
I live in Hackney which has it fair share of thieves and so far it has worked for me. The more measures you take, the more off putting it is for the thieves and surely they will go for the easier bikes in the area.
Hit the G spot. Wink
PostPosted: 04:03 - 05 Nov 2011    Post subject: Reply with quote
Cyclone 2 is great for being sensitive.
Loved mine Thumbs Up
st3v3
PostPosted: 05:17 - 05 Nov 2011    Post subject: Reply with quote
I'd go for anything that gives off an audible warning, thiefs have minutes to crack a chain/padlock, and nobody will question them this day and age.
Get a sirened gadget and let it keep gaurd for you. Thumbs Up
johnsmith222
PostPosted: 07:40 - 05 Nov 2011    Post subject: Reply with quote
Get something you can use when you hear it being nicked too. Think back to when Mr Dunc's bike got nicked by around 10 people. You're not going to have a chance unless you are tooled up.
No chance in hell would I have gone out there to chase 10 people off unarmed.
PostPosted: 11:07 - 05 Nov 2011    Post subject: Reply with quote
"People"? Don't lump us in with those bipedal rats, please.
Ingah
PostPosted: 13:05 - 05 Nov 2011    Post subject: Reply with quote
This is the problem though. What is "reasonable" to have/charge the thugs with? You can't exactly expect to get away with getting a carving knife out the kitchen drawer and running outside...
-- Ingah
st3v3
PostPosted: 15:37 - 05 Nov 2011    Post subject: Reply with quote
A metal bar (i had a 10 tonne trolley jack handle to hand), and a brteaker bar used for undoing car wheel bearing nuts. (with a 30mm socket attached).
Problem is, any more than 3 decent sized people and they can carry it away.
All this focus on chains, almax/oxford etc etc, last night they got thru my PADLOCK in seconds, chain was too thick but as a preventative measure, maybe the padlocks could be improved? This was cut like a knife thru cheese, can't thay make them with an inner material like titanium that's amazingly hard for crops to snip?
PostPosted: 16:28 - 05 Nov 2011    Post subject: Re: Anti-Scrote Devices Reply with quote
The broken, beaten bloody corpse of a chav chained to the bike with a sign that reads "This is number 4. Want to try for no.5?" next to the bike.
temeluchus
PostPosted: 17:41 - 05 Nov 2011    Post subject: Reply with quote
On one estate where I had a load of trouble with twots showing interest in my bike I had a pressure washer hooked up permanently. Gave one or two a damned good wash.
Clanger
Stirrer
PostPosted: 18:27 - 05 Nov 2011    Post subject: Reply with quote
Mild electric charge...like the stuff they use to pen in animals. Wrap it round your bike, and voila, anti-theft device. Thumbs Up
Im-a-Ridah
PostPosted: 19:15 - 05 Nov 2011    Post subject: Reply with quote
What padlock did you use?
gorillaonabik...
PostPosted: 15:42 - 06 Nov 2011    Post subject: Reply with quote
I bought a gorilla lock. It's a wheel clamp cemented into my drive with a spindle to stop the tea leaving b@stards removing the front wheel.
It has worked so far and I'd say it is more effective than a chain / lampost combo. From experience, my opinion is I'd already have had it stolen if it had been chained to a lamp post.
StevRS
PostPosted: 20:16 - 07 Nov 2011    Post subject: Reply with quote
Covers are well underrated as security deterrents.
MV Agusta Brutale 800 RR, Unfinished 1978 XS250
cb1rocket
PostPosted: 23:27 - 07 Nov 2011    Post subject: Reply with quote
doesn't stop them lifting it up for a peek, some even go missing too
The last post was made 14 years, 334 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 119.58 Kb
