Clutch cable replace help!!
aprilia125jac...
PostPosted: 22:05 - 03 Nov 2011    Post subject: Clutch cable replace help!! Reply with quote
I have a new shape aprilia rs125 an the clutch cable is fooked I have a new one and it is correct but I need to know how to change it? I can get it out from from the lever but where it goes into the gearbox how do I do it? Any "decent" advice would be much appreciated?
Current Ride = 2006 Aprilia Rs125
Previous Ride = 2006 Peugeot Speed fight 2
spyuggy
PostPosted: 14:16 - 04 Nov 2011    Post subject: Reply with quote
On some bikes, you have to remove the clutch casing to get at the lever and nipple, you may have to do this.
Good luck with it.
Treat each day as if it was your last, because one day you will be right.
PostPosted: 14:36 - 04 Nov 2011    Post subject: Reply with quote
Official way is to remove the clutch cover, as mentioned above. Which is a pain in the bum. However it can be done without doing this.
Take off the n/s fairing panel so you have plenty of space.
Disconnect the cable at the lever end.
In the clutch cover there are 2 plastic plugs. Unscrew and remove these (a small coin is ideal to use to unscrew these).
You will hopefully see the clutch arm through the plug towards the edge of the cover. Pull the cable outer from the cover (there are a couple of O rings to seal it, so it will take a bit of force).
You should then have enough free play in the inner cable to push it into the casing a bit and unhook it from the clutch arm.
Once the inner is unhooked you should be able to just pull the entire cable out of the clutch casing.
That's the easy bit.
With the new cable routed from the clutch casing up towards the bars, pull the inner to give you as much cable to play with as possible. The cable probably has a gentle curve in it.
Put the inner cable into the clutch cover. You should see it through the hole for the plastic plug. The idea now is to rotate the cable so it is against the arm, and once there pull it gently out to catch on the hook on the end of the arm.
Once you have done that (if you are luck, first attempt, if you are unlucky you will still be trying half an hour later), keep the inner cable under tension (you don't want it to unhook again), push the outer cable into place in the clutch cover. Then connect up at the lever.
After that adjust the clutch (centre of the clutch cover), replace the plugs and fairing and adjust the cable at the lever.
The last post was made 14 years, 350 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 37.13 Kb
