| chaslam07 |
 chaslam07 Renault 5 Driver
 Posted: 15:38 - 04 Nov 2011 Post subject: Custom Sportsbike |
Can anybody tell me if this can be done, say can i get a frame from one bike, engine of another, lights of another, exhaust of another, electrics of another and get different fairings, i know you will have to modify the frame to hold new engine etc and new mounting points for fairings and lights but can this be done, I am currently stripping down a suzuki gk73a gsxr400 in the show and tell section, but had a bit of a set back today while taking the exhaust of snapped one bolt and broke some casing of the engine where the bolts goes through to, so dont know if that means new part or if you can just weld it back on but had this idea in my head aswell to just do what i want with it rather than restore it, i know itll cost alot more than just to buy one but im in no rush and there wont be any like it around so any advice welcome thanks |
| G |
 G The Voice of Reason
 Posted: 15:46 - 04 Nov 2011 Post subject: Re: Custom Sportsbike |
I'm sure Marjay will be along soon .
The question is 'why'?
Yes it can be done. In days gone by people would stick a mass produced engine in a custom built chassis to improve the handling.
This is how bimota made their living.
Now though, the mass produced chassis are excellent, light and better than most aftermarket ones would be, so no one bothers really.
There are some fairly simple swaps that require only minor modifications. However, even in those cases and in most other cases - it's so much effort that it's not worth it, especially as generally you can just a chassis/engine with it's original counterpart and have a better machine with a lot less work and money spent. |
| chaslam07 |
 Posted: 16:08 - 04 Nov 2011 Post subject: |
Major components vary in difficulty. For example Yamaha are quite good at only changing things that really need changing, so often bits from vaguely similar age Yamahas can be used on other Yamahas.
However the more specialised the bits the less chance / harder it will be.
I presume it is just your engine has had a bit break off where the exhaust bolt goes into the head. Should be repairable, and with the engine out of the frame should be that difficult to find someone to do it.
However if you wanted another different engine then life gets more difficult. The Japanese 400s are fairly small bikes with things fairly well crammed in. Not much space to spare. It is possible another engine could fit in the space if you had the skills / money to fabricate all the engine mounts, but unless there is a particular reason to do so it would be a pain. While other Suzukis might have similar engine mounts, this is far from certain (ie, Suzuki dramatically changed the engine mounts between the late oil cooled and early water cooled GSXRs, despite at first glance the frames looking very similar), and even if they do there is no certainty that other bits will be in a suitable position (ie, a 400 Bandit engine might fit, but I wouldn't be in the slightest bit surprised if the head is different to angle the carbs to fit).
| G |
| chaslam07 |
| Bezzer |
 Bezzer World Chat Champion
| Frost |
 Frost World Chat Champion
The last post was made 14 years, 351 days ago. Instead of replying here, would creating a new thread be more useful? |
