| Muscle Bike Rider |
 Muscle Bike Rider World Chat Champion
| Moxey |
 Moxey World Chat Champion
 Posted: 18:48 - 05 Nov 2011 Post subject: |
From what I understand if the OEM rubber hoses aren't leaking or frayed in anyway theres no point unless you perhaps plan on taking your divvy as a track bike or the TT .
I think they're supposed to prevent flex in the hose meaning the fluid compresses upon the caliper piston more effieciently or something like that barely noticeable on road use apparently.
(Don't hold me to this though I'm sure someone with more knowlege is bound to come up on this ) ____________________ Current: 02 FZS 1000 & 91 Royal Enfield Bullet 350 Some Bike Pics...
'I was too busy paying attention to pay attention' |
| stonesie |
 stonesie World Chat Champion
 Posted: 18:49 - 05 Nov 2011 Post subject: |
You will get a much firmer, more direct feel. You will be changing your fluid too so that will also help  |
| DrDonnyBrago |
 Posted: 18:57 - 05 Nov 2011 Post subject: Re: Will Braided hoses make any differnce to my bike? |
| A5tra_G wrote: | I'm thinking of fitting some braided hoses to my XJ600s Diversion single disc model, will they make any real noticable difference to braking or are they just longer lasting?
Sorry if this has been asked before but I'm still a newbie as far as being mechanically minded.
Ta,
Paul. |
Your brakes will feel firmer, partly because the lines expand less under pressure and partly because it requires that you change the fluid and bleed it properly. They also look pretty good, cost less than OEM lines and after 10 or so years rubber ones get a bit old and the banjos etc a bit rusty. As for extra power, possibly, if you are currently pulling the brake lever and it is so soft it touches your bar or your other fingers then it could help braking power, if your lever is not this soft then braided lines just make it feel nicer.
Whilst you are at it, with winter on the way it is worth checking the condition of your front caliper, they can usually benefit from a nice clean up, if you are replacing the fluid anyway then you may as well strip it down and do it properly.
As it is just one line, it won't be expensive and with a single disc every little helps . |
| Im-a-Ridah |
 Im-a-Ridah World Chat Champion
| Muscle Bike Rider |
 Posted: 19:24 - 05 Nov 2011 Post subject: |
Thanks guys, got a full set of goodridge for £30 so will fit them next week end, plan on keeping the Divvy for another year so may as well improve what I can for myself plus it might help with the sale when that time comes.  ____________________ Previously Known As A5tra_G
Old Bikes :2010 Kawasaki ER6 F & 2000 Honda VTR Firestorm
Current Bike : XJR1300 |
| DrDonnyBrago |
| Muscle Bike Rider |
 Posted: 22:34 - 05 Nov 2011 Post subject: |
| Slacker24seve... |
 Slacker24seve... World Chat Champion
| iooi |
 iooi Super Spammer
 Posted: 16:14 - 06 Nov 2011 Post subject: |
Difference between rubber hoses in reasonable condition and braided hoses is minimal. If rubber hoses degrade then yes they will give spongy brakes, but that takes ages.
Not that sure on braided hoses being longer lived (rather than just the bike makers being more paranoid).
If the lever is coming back to the bar then there is something seriously wrong. Possible the hoses are shot, but far more likely that there is a load of air in there. If they are OK when not moving, but braking hard when moving result in them coming back further then there is water in the system.
Braided hoses have disadvantages as well. They are easier to damage, and will damage other things more easily, plus they are harder to route to avoid them rubbing on things.
The last post was made 14 years, 309 days ago. Instead of replying here, would creating a new thread be more useful? |
