How to change gear?
Fifteen15
PostPosted: 01:35 - 09 Nov 2011    Post subject: How to change gear? Reply with quote
When I change gear, I tend to let my grip go on the throttle so it pulls back, then catch it and pull it back again. Obviously it's all done in a split second. Anyway I was watching a YouTube video of someone changing gear and they just 'flicked' their wrist when changing gear. This seems the better way of doing it however I can't get to grips with it.
Is the way I'm doing it a bad habit that I need to stamp out? The only disadvantage I can think of is when I momentarily let go of the throttle, I am effectively riding with one hand for that split second.
"Pain is weakness leaving the body, and blood makes the grass grow faster...but I'll wear my gear anyway"
Matt06
PostPosted: 01:49 - 09 Nov 2011    Post subject: Reply with quote
Are you quite new to riding?
To be honest its just something you will getting better with after more time.
Should learn to blip the throttle with downshifts as well.
Current: MT-10, Bandit, Grom, GPZ500
Previous: YBR125, GSXR400, ZXR400, MT-03, NTV650, R6, z750, ZX6R, MT-09
johnsmith222
PostPosted: 01:54 - 09 Nov 2011    Post subject: Reply with quote
Please don't let go of your handlebar.
Shut throttle - clutch in - click up - release clutch - open throttle.
5150
PostPosted: 09:28 - 09 Nov 2011    Post subject: Reply with quote
Wow, my first post after a lot of lurking!
Try imagining you're wringing out a towel. Your right hand rolls forward while the fingers on your left hand come in on the clutch. Then do it the other way once you've clicked into the next gear. Just keep it all nice and smooth and you'll be fine; the quick wrist-flick comes with practice. Thumbs Up
It's good you're trying to stamp out the habit; if you muck it up and don't pull the clutch in when you let the throttle snap shut, you'll be at risk of locking the back wheel - which could prove a bit nasty, especially on a V-twin.
evoboy
PostPosted: 10:43 - 09 Nov 2011    Post subject: Reply with quote
Just preload the lever with your foot by putting a bit of pressure under it, then roll the throttle forward/shut quickly, or pull the clutch in.
Youll find itll just drop into the next gear.
APT Motorcycles
Dan_Davies
PostPosted: 19:21 - 09 Nov 2011    Post subject: Reply with quote
reading this makes me think i actually dont know which way i do it Embarassed it just happens Shocked
current ride: 07 suzuki sv650s
ex rides : lifan mirage 125
HD
PostPosted: 21:12 - 09 Nov 2011    Post subject: Reply with quote
Surely when you let go, you roll your hand forawrd anyway to grab the throttle, otherwise by the time your in 3rd, your arm would be underneath Laughing
So instead of letting go and grabbing (while you roll your hand forward), keeo hold of it as you roll forward.
HTH Thumbs Up
JoeDougieDoug...
PostPosted: 21:44 - 09 Nov 2011    Post subject: Reply with quote
No, same here! I am really new to biking, but even now its second nature changing gear. I know my changes are pretty slow compared to my friends on their sport bikes, but I never think about it anymore.
GrantT
PostPosted: 10:41 - 10 Nov 2011    Post subject: Reply with quote
This is a good explaination! The speedy flick of the wrist is this just done quickly Smile
Glenben92
PostPosted: 11:33 - 10 Nov 2011    Post subject: Reply with quote
If you're riding a small capacity bike and therefore do most of your acceleration at full throttle, it can be awkward to twist your wrist that far. I think as soon as you move onto something which has more power, the wrist flick will come naturally as it's easier.
I do sometimes do the let go and re-catch myself on the GPZ but only if i'm accelerating at full pelt because i simply can't bend that way. I wouldn't say it's unsafe, just not ideal. Also, try clutchless shifting, might work out a little better for you as the throttle won't have to be FULLY closed for the gears to change
57 Huoniao HN125-8 - Smile, 97 Kawasaki GPZ500S - Very Happy
99 Yamaha FZS 600 - Wink
Mod 2 Passed - 01/10/2010
supZ
PostPosted: 12:15 - 10 Nov 2011    Post subject: Reply with quote
clutchless ftw.
pressure on the pedal (going up the box) and just flick the throttle off and on again. should only take a split second.
you'll find the moment you shut the throttle the gear clicks in and you're already back on the power Smile
only thing remaining is to drop your foot away from the pedal and then put pressure on it again for the next change.
if done correctly even at slow speeds this is the smoothest way of changing gear. and no it doesnt damage the gearbox.
on downshifting however you should use the clutch and try to blip the throttle as well. clutch in, blip/rev, change down release clutch. the act of blipping raises the revs and allows you to slip into gear without upsetting the bike or potentially locking the rear wheel. obviously the moment between blipping, changing and engaging the clutch should be as quick as possible or the revs will just drop to normal again and the blip would have been wasted.
this isnt as required on bikes with slipper clutches but still a good habit to get into
CBR954RR - Daily toy
CBR600RR - Trackbike
Atomic Punk
PostPosted: 14:19 - 10 Nov 2011    Post subject: Reply with quote
Are these posts a windup?
There seems to be a few from the same poster.
I may have lost my way but I'm way ahead of schedule.
fatjames
PostPosted: 14:34 - 10 Nov 2011    Post subject: Reply with quote
Are you on a windup?
Fairies attack This post is not being displayed because the poster is banned. Unhide this post / all posts.
The last post was made 14 years, 83 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 82.58 Kb
