Wheels for an AR50
palmer
Fiddled Kiddy
PostPosted: 21:32 - 10 Sep 2004    Post subject: Wheels for an AR50 Reply with quote
yep, still doin my little old AR50 up... right little motorbike its turning out to be.. the custom fairing i got made for it kinda shattered , so thats off Sad 120 quid down the drain
anyway... anyone know where to get some cheep wheels from? (smaller than th AR's origional wheels) as the origional wheels look too big, plus id like some fatter tyres, whats the kinda limits for rim/tyre thickness?
at the moment im not sure what size wheels i got, but i got a 3.25 inch tyre on the back, and a 2.75 tyre on the front... on the honda nsr 50, the wheels looks pretty damn fat, those would be perfect... anyone got any guesses as if they would go on without much tampering? and where to get a decent 2nd hand pair?
thanks in advance
Ade067
PostPosted: 21:51 - 10 Sep 2004    Post subject: Reply with quote
The only suggestion I can think of would be to try at a bike breakers,have a look in the yellow pages or something similar and see if theres one in your area.
ZRX61
Victor Meldrew
PostPosted: 22:58 - 10 Sep 2004    Post subject: Reply with quote
Back in the day.....yawn..... when I raced Moped Mayhem our AR50 sported TZR250 wheels... along with myriad other improvements.. such as an extra transfer port machined into the barrel...
palmer
Fiddled Kiddy
PostPosted: 23:03 - 10 Sep 2004    Post subject: Reply with quote
wow, did the wheels go on without any real changes? and what kinda tyres were you using? id love to know more about the ar50 you raced... any info will be greatly appreciated
thanks
ZRX61
Victor Meldrew
PostPosted: 01:07 - 11 Sep 2004    Post subject: Reply with quote
Hell, that was damn near 20 years ago, LOL!
I remember we made up new spacers etc & the rear tire was a 4.10, I think the front was about a 3.60
There is a gap of 1 year, 62 days between these two posts...
GAZZAWAZZA123
PostPosted: 19:15 - 12 Nov 2005    Post subject: BREAKING KAWASAKI AR50 COMPLETE BIKE AND ENGINE Reply with quote
HI IM BREAKING A KAWASAKI AR50 COMPLETE BIKE
IF ANYONE NEEDS PARTS,THEN CONTACT ME AT [email protected] DONT REPLY TO THIS,AS I WONT RECIEVE IT,
I HAVE COMPLETE BIKE. IM IN SCOTLAND AND P+P IS CHEAP
GaZ
PostPosted: 21:41 - 12 Nov 2005    Post subject: Reply with quote
You do know getting smaller wheels will reduce the top speed greatly.
look if you make the wheels 1cm smaller in diameter it reduces the perimeter of the wheel by 3.14cm that means you lose 3.14cm per revolution. Because of the gearing the wheels well not turn any faster to make up that speed in effect the engine is doing the same work but going slower. I don't know how much rpm is at your actual wheel at top speed but whatever it is times it by 3.14 then by how many centimeters you have taken off your wheel then by 60 and divide by 100 that will be by how many kph your top speed goes down by. I reckon it will be quite a lot.
p.s. sorry to get all mathsy
PostPosted: 13:05 - 13 Nov 2005    Post subject: Reply with quote
Changing over wheels is a pain in the backside and expensive unless you are, or are on good terms with a competant machinist.
You will probably need to have new spacers made to get the wheel in the middle. You will also mast likely need a plate making to move the brake calliper to engage with the disc. It is unlikely you will be able to retain the speedo drive.
I recently fitted a different set of wheels in my KLE500. I was using wheels from the same maufacturer and it was still an extensive task that with hindsight, I would never have started (although I am happy with the result).
The wheels and tyres on your bike have been selected by the manufacturer as the best size to use in that chassis, chances are that messing with this will have a negative effect on the handling. Narrower tyres corner faster.
EDIT: Also remember that fitting smaller wheels will reduce the already very little ground clearance on your bike. You may well find that it scrapes its arse along the ground round every corner. It probably wont sit on the sidestand either.
The last post was made 21 years, 9 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 56.18 Kb
