How to mod Airbox on std rs125 (fp)
stevo123
PostPosted: 08:56 - 11 Sep 2004    Post subject: How to mod Airbox on std rs125 (fp) Reply with quote
Hi, i have read a few posts about modding the inlets on the airbox of the rs. I fancy a go at it as long as i don't need to rejet an stuff. Anyone know the way? ps i will report back about how the bike rides with the grey wire loop under the seat disconnected so the pv opens 300rpm earlier. Happy riding (i'm off to work now) Mad half day though Very Happy !!
Lee_367
PostPosted: 10:39 - 11 Sep 2004    Post subject: Reply with quote
I believe the airbox mod was only of use when using a 34mm carb, not the standard one.
?It?s mercy, compassion, and forgiveness I lack?not rationality.?
PostPosted: 14:36 - 11 Sep 2004    Post subject: Reply with quote
Think that on some bikes half of the "snorkal" which is the airbox intake is blocked up. Probably worth removing this blockage. Keep the snorkal as it is likely that even though this reduces the area into the airbox slightly it also improves air flow.
stevo123
PostPosted: 20:07 - 11 Sep 2004    Post subject: Reply with quote
thanx chaps Very Happy
Big Pete
PostPosted: 15:57 - 13 Sep 2004    Post subject: Reply with quote
If you are moddifying the airbox to get more power you are letting the engine get more air. This means you have to rejet otherwise the engine will run lean resulting in nastyness like holed pistons.
more air=more fuel =more power.
Trust me, I`m an engineer
GarageOfPower.co.uk
The last post was made 21 years, 212 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 44.22 Kb
