Weird problem with my RS125
Rim0r
PostPosted: 16:41 - 11 Sep 2004    Post subject: Weird problem with my RS125 Reply with quote
hi guys, this is my first post here and i'm hoping you guys can solve my problem. I think it might be something to do with the carb but i'm not sure and I don't know how to clean it so before i do anything i'm gonna ask you lot Razz
OK, so heres the problem.
After warming the bike up i take it out for a spin and it will not rev over 9000rpm it coughs and stutters. I then (only once) took it out without warming it and this problem wasn't there. A friend i have spoken to suggested it could be the carb needing cleaning but i'm not sure how to do this. Any advice will be greatly appreicated. Thanks
Rob
PostPosted: 18:49 - 11 Sep 2004    Post subject: Reply with quote
First thing to try is a new spark plug. Give that a go and if that fails it is worth looking further.
How old is the RS125?
MarsBar
PostPosted: 18:54 - 11 Sep 2004    Post subject: Reply with quote
And make sure you get the right one! My NSR had the same problem when I first had it. It was because the previous owner had but a high performance plug in it.
Rim0r
PostPosted: 19:17 - 11 Sep 2004    Post subject: Reply with quote
Ah ok, thanks guys... the RS is a 94 model so its a good 10 years old
What plug do you guys recommend?
Rob
stevo123
PostPosted: 20:15 - 11 Sep 2004    Post subject: Reply with quote
Take the carb off, grab a notebook and pen and set aside a good few hours. Take the carb fuel filter off the side first and clean with petrol. Strip it down slowly taking lots of notes. Clean each part individually. When you just have the carb body left blast any drillings with good ole carb cleaner. Then get a bucket/sink of hot soapy water and clean the body of the carb, an old toothbrush may come in handy here, when your satisfied dry thoroughly and re-assemble it using your drawings. Have fag and/or cuppa (optional). Put back on the bike and check it over. Start her up, give yourself a pat on the back and grin at the great throttle response etc etc. If i don't work carbs prob worn-get a replacement one. Above all take your time and be safe petrol very flammable lol Smile
Lee_367
PostPosted: 21:50 - 11 Sep 2004    Post subject: Reply with quote
It could be the powervalve, does it have one? is it correctly adjusted?
?It?s mercy, compassion, and forgiveness I lack?not rationality.?
PostPosted: 22:35 - 11 Sep 2004    Post subject: Reply with quote
I did have ignition problems with my RS (a 1993 one) that meant it died at about 9500rpm, but it was never fine in that conditipn.
Spark plug is the most likely, and it should be a BR10EG plug.
Also worth cleaning the carb out. The filter in the carb is a bit of a pig to get out without damage on the 34mm carb you have,
alains
PostPosted: 22:52 - 11 Sep 2004    Post subject: Reply with quote
NGK BR10EIX https://www.sparkplugs.co.uk
Rim0r
PostPosted: 18:47 - 14 Sep 2004    Post subject: Reply with quote
ok, i'm gonna see if i can find one tomorrow? failing that i'll have to use my dads card Razz cheers
Rob
alains
PostPosted: 23:30 - 14 Sep 2004    Post subject: Reply with quote
they will send the same day , it takes 3 days to come in france and much cheaper
The last post was made 21 years, 359 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 64.68 Kb
