Leaking oil from front suspension - got any advice?
Fallen Angel
Franny the Nanny
PostPosted: 19:31 - 12 Sep 2004    Post subject: Leaking oil from front suspension - got any advice? Reply with quote
Looking for some advice here.
My wee bikes not been used for a few days and tonight when we were down looking at it, Eddie noticed a wee puddle of oil (very slight about the size of a 50p piece) just under the front suspension.
Anyone got any tips where this could be coming from, and how to fix it! Confused
Any advice would be much appreciated!
Cheers in advance! Thumbs Up Karma Thumbs Up
Fran
I have an asshole tolerance level of -10 Twisted Evil
Mr. Green Dance! Mr. Green www.cliqueyclanmcc.co.uk Mr. Green Dance! Mr. Green
www.bebo.com/fallenangelfran
NickD
PostPosted: 19:41 - 12 Sep 2004    Post subject: Reply with quote
Check your fork seals.
I was only doing what it said on my licence officer....
Tear along the dotted line!
Fallen Angel
Franny the Nanny
PostPosted: 19:45 - 12 Sep 2004    Post subject: Reply with quote
That's what Eddie said it might be, only thing is, neither of us are very technical minded!! Embarassed
So, how do we do that?
NickD
PostPosted: 19:53 - 12 Sep 2004    Post subject: Reply with quote
On each fork there's an oil seal where the fork leg goes into the fork bottom. Wipe the fork leg clean just above the seal, then holding the front brake, compress the front suspension a couple of times, and if it leaves a tide mark on your newly cleaned bit, that's your problem.
Fallen Angel
Franny the Nanny
PostPosted: 19:57 - 12 Sep 2004    Post subject: Reply with quote
Cheers mate!
If that is the problem, how easy is it to fix OR how much would it cost to have it fixed by a mechanic?
ZRX61
Victor Meldrew
PostPosted: 19:58 - 12 Sep 2004    Post subject: Reply with quote
Ya sure it's fork oil & not brake fluid leaking from the lines/calipers?
Robby
Dirty Old Man
PostPosted: 19:59 - 12 Sep 2004    Post subject: Reply with quote
They aren't hard to do if you have a little mechanical knowledge. Quite hard the first time, but easier after that.
Otherwise its 2 hours labour in a garage+ about 20 quid parts.
Do not under any circumstances use pattern fork seals.
Fallen Angel
Franny the Nanny
PostPosted: 20:03 - 12 Sep 2004    Post subject: Reply with quote
Robby - Cheers - what's the difference re. pattern seals? Confused
ZRX61 - Can I assume once I do what NKD666 suggested re. the fork seals, if this doesn't seem to be the problem, that we then may have an issue. re. brake fluid? If it is the brake fluid, would I be able to tell from the brake fluid indicator on the handle bars - if it looks like the level has gone down?
NickD
PostPosted: 20:06 - 12 Sep 2004    Post subject: Reply with quote
If you've got a manual, and some means to support the bike while you've got the fork off, it's an easy job even if you're not particularly mechanical (got to start somewhere though). I couldn't tell you about your bike, but a pair of seals for mine were about 20 quid. And I could'nt tell you what it'd cost to have it done, but I would bet it wouldn't be cheap.
Fallen Angel
Franny the Nanny
PostPosted: 20:12 - 12 Sep 2004    Post subject: Reply with quote
Eddie's away down to the garage just now to check the way you suggested Nick!! Thumbs Up
ZRX61
Victor Meldrew
PostPosted: 20:14 - 12 Sep 2004    Post subject: Reply with quote
The fork seals are under a dust cap (the rubber bit you can see) & they just pop up with the twist if a screw driver etc, you'l see a lot of oil under the dust cap if thats the source of the leak.
Brake fluid goes down in the rezzy as the pads are worn away so thats not much of an indication of a leak. Just look at the end of the brake lines where they go into the calipers & see if they are wet.
As the oil (if thats what it is) is already forming a puddle it would indicate the leak could be the drain plug as the bottom of the fork legs (hidden by the axle) as oil won't go up the leg from a blown seal & then down the outside to form a puddle on the ground.
Is there oil/fluid anywhere else apart from on the floor?
ZRX61
Victor Meldrew
PostPosted: 20:20 - 12 Sep 2004    Post subject: Reply with quote
Having a slow day here, the suspense is killing me Smile
Fallen Angel
Franny the Nanny
PostPosted: 20:26 - 12 Sep 2004    Post subject: Reply with quote
Right, apparently, when you push the suspension down and release it, the fork that goes into the bottom section comes back out covered in oil!!! Confused How un-mechanical am I?!?! Embarassed
If it is the seals, which it does seem to be, is this a major problem that needs to be fixed immediately before riding the bike again?
NickD
PostPosted: 20:32 - 12 Sep 2004    Post subject: Reply with quote
Officially yes, but I personally wouldn't have it high on my priority list on a bike of that weight (unless I was taking it for an MOT soon), If it's not losing much oil, just keep it topped up and it'll be ok. Make sure it's not getting on the brake disc though.
ZRX61
Victor Meldrew
PostPosted: 20:36 - 12 Sep 2004    Post subject: Reply with quote
ok, thats the fork seal for sure then.
The only danger is the oil getting on the brake rotor and/or pads which can make stopping a bit of an event. I've had a leaking seal on my ZRX for about 3 months, I just wipe the oil off whenever I ride it. So it's not a *must fix this immediatley* type of thing. If the oil isn't getting on the brakes you can ignore it for a while. I wouldn't bother topping it up, to much hassle & oil level in forks in a fairly critical measurement.
It;s not a difficult thing to fix, but if you're both a bit mechanically inept ya may want someone of the other end of the phone to talk ya thru it.
PostPosted: 21:33 - 12 Sep 2004    Post subject: Reply with quote
Sounds like the seal has gone.
They are not that difficult to change on normal forks. Sounds like it has gone badly from how you have described it so I would suggest changing them soon to avoid the oil getting on the disks.
If you are not happy changing them then support the front of the bike and remove the fork, then take just the fork into a bike shop.
Ian (GPX)
PostPosted: 21:36 - 12 Sep 2004    Post subject: Reply with quote
Should cost around £40 - £60 plus parts to fix that, it cost me £50.00 to have both my forks done on my GPZ400R, took 1 hour 30 mins for the mechanic to do all the work.
Fallen Angel
Franny the Nanny
PostPosted: 00:06 - 13 Sep 2004    Post subject: Reply with quote
Thanks everyone!!
The small leak is at the opposite side to the brake disk, so shouldn't cause too much problems there, but we will definitely keep an eye on it and get it fixed asap.
We have the link to the manual, but it doesn't seem to download for me!!! Confused Confused
Will have a go at downloading it again though, but you've all been a great help. Thumbs Up Thumbs Up
PostPosted: 00:35 - 13 Sep 2004    Post subject: Reply with quote
Cost me £35 plus about £10 for parts to get my fork seals before. It might only be on the side away from the brake disk, but how must are you willing to trust a front tyre to grip the tarmac when it has random drips of oil to contend with? Confused
Better changed sooner rather than later before it gets any worse or causes something slightly bad.
Fallen Angel
Franny the Nanny
PostPosted: 22:45 - 13 Sep 2004    Post subject: Reply with quote
The bike's off the road for a few days anyway now 'cause the fairing's away to get fixed, so once that comes back, or whilst it's away, we'll have a look at the forks, etc. once we get a manual!! Thumbs Up
Rory
PostPosted: 23:05 - 13 Sep 2004    Post subject: Reply with quote
Angel, I would get the seals looked at with a fair amount of priority, as if your seals have gone (and it sounds like they have) it'll put the bike's handling off, possibley by quite a bit. It's entirely possible for oil to leak onto your brake discs, and which it won't stop you braking, it'll make it much more difficult. The difference with my bike once I got new forks seals on (and stiffer suspension, but that's my preference) and clean brake discs was amazing, like a different bike. So hop to it! Thumbs Up [/b]
My Old CBR400RR | Bike Oil FAQ | Petrol FAQ
The last post was made 21 years, 213 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.19 Sec - Server Load: 0.88 - MySQL Queries: 13 - Page Size: 122.32 Kb
