Gas Gas Rebuild
Bike Chat Forums Index -> Show & Tell Goto page 1, 2, 3, 4, 5, 6, 7  Next
Ichy
PostPosted: 16:18 - 26 Nov 2011    Post subject: Gas Gas Rebuild Reply with quote
I'll start with these.
https://i93.photobucket.com/albums/l41/marki_03/Gas%20Gas/PB260778-1.jpg
https://i93.photobucket.com/albums/l41/marki_03/Gas%20Gas/PB260779-1.jpg
https://i93.photobucket.com/albums/l41/marki_03/Gas%20Gas/PB260780-1.jpg
https://i93.photobucket.com/albums/l41/marki_03/Gas%20Gas/PB260781-1.jpg
I picked up this EC250 from Woll earlier today. The overall condition is better than expected and this 'might' be an easy project to work on over the next few months.
The plan is to first put it all back together and get it running. It definately needs new reeds, a gasket set and possibly a new piston. Once I start building it I should get a good idea of any parts than are missing or need replacing. I'll then strip it back down and start tarting it up. The main task will be cleaning it all, the main frame could use new powdercoat and the loom needs replacing to tidy it up.
Cheers Woll, should be fun.
woll
PostPosted: 20:05 - 26 Nov 2011    Post subject: Reply with quote
Have fun Thumbs Up have to bob up on it when it's going again, be good to see it running again.
N rob it did get loved, up until it broke lol.
The Artist
PostPosted: 21:27 - 26 Nov 2011    Post subject: Reply with quote
You need to buy a bike off Chris next Laughing
Quote Me Happy
PostPosted: 21:29 - 26 Nov 2011    Post subject: Reply with quote
Good luck with it, cracking bikes, looks like it's got some bling yokes Thumbs Up
Ichy
PostPosted: 22:24 - 26 Nov 2011    Post subject: Reply with quote
According to the previous owner it has some special parts on it. Ohlins rear shock, excel rims, billet yokes, and the front forks are 'something' but I don't know what Laughing. Most of this means very little to me to be honest.
reggie
PostPosted: 23:06 - 26 Nov 2011    Post subject: Reply with quote
want a newer swing arm of a 2006 one ?
when the shit hits the fan make sure its facing the other way.
Ichy
PostPosted: 23:42 - 26 Nov 2011    Post subject: Reply with quote
Why? What difference would it make?
Welshd1k
PostPosted: 03:55 - 27 Nov 2011    Post subject: Reply with quote
they all had ohlins and mazurochi forks i thought...
Quote Me Happy
PostPosted: 13:57 - 27 Nov 2011    Post subject: Reply with quote
Up until 2008ish they had Marzocchi forks and Ohlins rear, unless you got the Ohlins fork version.
reggie
PostPosted: 18:23 - 27 Nov 2011    Post subject: Reply with quote
basicaly the same just newer looking only want 10 for it as it taking up room
Quote Me Happy
PostPosted: 08:18 - 28 Nov 2011    Post subject: Reply with quote
One thing I've remembered, there's some parts from other bikes that fit and there's a list here
https://www.gasgasrider.org/html/parts_crossover.html
It came in useful a couple of times.
For spare parts I've used Gas Gas UK but they have sent me the wrong bits before. I used https://www.biketechuk.co.uk/ - very helpful as well, whenever I ordered stuff he always gave me tips on how to go about fitting etc.
Ichy
PostPosted: 13:10 - 28 Nov 2011    Post subject: Reply with quote
Thanks Joe, I've already joined the gasgas forum. Very Happy
What is surprising is the general lack of info and part suppliers. I guess that's the price of having a smallish brand.
I'm weighing up the idea of splitting the cases and changing the main bearings. There doesn't appear to be a problem but it would be good to know that they were right and to also inspect the gearbox. We'll see.
Ichy
PostPosted: 19:06 - 11 Dec 2011    Post subject: Reply with quote
Slow but sure. I decided to strip the engine.
https://i93.photobucket.com/albums/l41/marki_03/Gas%20Gas/PC110799Copy.jpg
Pretty worn out clutch plate.
https://i93.photobucket.com/albums/l41/marki_03/Gas%20Gas/PC110798Copy.jpg
Interesting, a loose crank stopper. I can only assume that it became dislodged when the bike was transported. It looks like it has come into contact with the con rod a few times.
https://i93.photobucket.com/albums/l41/marki_03/Gas%20Gas/PC110801Copy.jpg
I've messed around a bit looking for a reliable spares supplier. Just waiting for the fly wheel puller so I can split the case and check the main bearings.
MaybeGuy
PostPosted: 20:12 - 11 Dec 2011    Post subject: Reply with quote
Why do you need to split the casings to check the bearings? Confused
Ichy
PostPosted: 20:20 - 11 Dec 2011    Post subject: Reply with quote
Bad wording.
I want to paint the cases and change the bearing and seals while I have it open. Cost is less than a tenner and it gives me something to do.
reggie
PostPosted: 10:48 - 12 Dec 2011    Post subject: Reply with quote
the main berings are expensive to replace mightaswell replace the rod while your in there what make is the rod
Ichy
PostPosted: 12:02 - 12 Dec 2011    Post subject: Reply with quote
I get the bearing online. Working from the fiche I get a size of 30x72x19. SKF 6306C3 are around £8 +vat. The C4 version is £20.
Not something I'm planning at the moment but the con rod is the same as fitted to the earlier CR250 as is the piston, total cost is around £130 for parts although I would have to get a price for spliting the crank, I think it was around £25 last time.
My budget for the bike is going to be around £300. Doesn't seem a lot but the majority is superficial, more labour intensive. That said, parts are expensive and I've already spent £100 on just the reeds and gaskets. I'll see how it goes.
reggie
PostPosted: 12:53 - 12 Dec 2011    Post subject: Reply with quote
getting the rod pressed in is 75 quid INC THE ROD
seem silly not to do it now as a fullgasket set is over 30 and risk having to do it in the future
Ichy
PostPosted: 13:11 - 12 Dec 2011    Post subject: Reply with quote
You are probably right about the con rod and that's better than I expected, where did you get that price from? The quotes I got for an oem gasket set were around £70+ Shocked . I finally found a copy for £30. I have a lot of gasket paper in the garage so I'll copy a couple of the useful ones just in case.
woll
PostPosted: 20:02 - 12 Dec 2011    Post subject: Reply with quote
Wow can't believe how worn the clutch is. Never has a problem with it Confused
Ichy
PostPosted: 20:16 - 12 Dec 2011    Post subject: Reply with quote
It probably wouldn't have made much difference, I personally feel that you lose some of the feedback with hydraulic clutches.
woll
PostPosted: 21:17 - 12 Dec 2011    Post subject: Reply with quote
Yeh i found it a lot sharper than a cable one.
Ichy
PostPosted: 22:08 - 14 Dec 2011    Post subject: Reply with quote
Clutch cover off. Looking fine in there.
https://i93.photobucket.com/albums/l41/marki_03/Gas%20Gas/PC140823Small.jpg
The puller arrived so off with the bits on the other side.
https://i93.photobucket.com/albums/l41/marki_03/Gas%20Gas/PC140815Small.jpg
I guess this might be the reason for oil on the generator side.
https://i93.photobucket.com/albums/l41/marki_03/Gas%20Gas/PC140812Small.jpg
No play in the crank so I guess it was just not fitted correctly at some point.
All being well I should be able to measure up the barrel, piston, and rings tomorrow to find out if I need to replace anything.
So far the costs are.
£32 gasket set
£11 puller
Parts to replace.
Clutch plate or complete clutch kit £10 - £60
Reed valves £30 - £80
Powervalve bearing - £3
I guess the list is only going to get longer.
Ichy
PostPosted: 14:29 - 15 Dec 2011    Post subject: Reply with quote
Everything measured.
Barrel first. Average is around 66.41 against a spec of 66.38 - 66.5 so that is fine.
https://i93.photobucket.com/albums/l41/marki_03/Gas%20Gas/SDC10982.jpg
Some ovality but nothing significant.
https://i93.photobucket.com/albums/l41/marki_03/Gas%20Gas/cylreport.jpg
Piston next.
https://i93.photobucket.com/albums/l41/marki_03/Gas%20Gas/SDC10985.jpg
it was looking a bit rough so I wasn't surprised that it measured quite a bit undersized. It should be around 66.33mm, but measures on average around 66mm. The limit between bore and piston is only 0.1mm.
Piston rings are good but they will be scrapped since I'll get a piston kit.
The last post was made 14 years, 321 days ago. Instead of replying here, would creating a new thread be more useful?
Page 1 of 7
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 130.63 Kb
