| gsxrboy |
 gsxrboy Scooby Slapper
| Ste |
 Ste Not Work Safe
| gsxrboy |
 Posted: 00:15 - 13 Sep 2004 Post subject: |
Ste, this is something that worries me, will it flash at bright headlights? I have to do tests but I am hopeful it will be quick enough.
Do you like the bike it on?? I'll swap you for a good quality pack of cigarettes..... I don't even smoke  |
| Sparks! |
 Sparks! Sir Tart-a-lot
 Posted: 00:19 - 13 Sep 2004 Post subject: |
Do you not have a GSXR?
I don't see how the plate flasher will work fully as the speed camera will already have taken the pic, but I don't know really - Technically it should work as the picture you took the number plate was blanked out, but I didn't think speed cameras were meant to flash?? ____________________ Current Toys: 06 Yamaha WR250F | Nissan 350Z GT | Tech 4 Homes |
| Ste |
 Ste Not Work Safe
 Posted: 00:21 - 13 Sep 2004 Post subject: |
Only one real way to tell if it flashes at headlights behind you, and remember it could also flash when cars behind you go over bumps, as that appears in your mirrors like they're flashing you so if the gadget is set to flash if it detects a certain change in light levels then it could do. Also, does it flash in daylight and is it effective enough? I'd want to be slightly more than "hopeful" if I was going to trust that thing to protect my license when going throuh gatso cameras.
Best way to avoid them getting your plate is to make a device which spins your plate around so it can happily take a picture but it just of the back of the number plate. I had one before and I bought it second hand it was made from an old power valve motor, and hooked up to a switch and wired into the battery, I switch the switch and it spun the plate around, switch it again and it went back again, so you would switch it before you got to the gatso and switch it again after you've gone through the gatso.
Do I like the bike? Don't know, just seen the numberplate from it and it appears much like any other.  |
| Sparks! |
| Ste |
 Ste Not Work Safe
 Posted: 00:30 - 13 Sep 2004 Post subject: |
Says the person with them doing a wheelie in their avatar.  |
| dibbster |
 dibbster Nearly there...
 Posted: 00:31 - 13 Sep 2004 Post subject: |
Surely the unit will respond to a change in light levels, i think this would be hard to set up to work in daylight conditions where you are trying to detect a small change in a large amount. (Needle in haystack type analogy) Also the speed camera flash will be directionalised and the time the light sensor would be within the increased light levels would be relatively short (Due to you moving (presumably at high speed)). This would mean you would need fast electronics.
I am not sure I would trust my licence to such a device and think that leaving your number plate at home maybe a simpler and more reliable solution! ____________________ Suzuki RF 600 - The two wheeled Testarossa (Deceased)
Suzuki GSXR - Now stops on a sixpence; SBK3's
www.bikepics.com/members/dibbster |
| gsxrboy |
 Posted: 00:34 - 13 Sep 2004 Post subject: |
I'm pretty sure it will work at a quick enough speed but as you say it needs to be tested to be sure. My camera is quite a good one but maybe not as good as a gatso...
The bike in picture is a cb350-skip it will burn quite well i think...  |
| G |
 G The Voice of Reason
| Sparks! |
 Posted: 00:51 - 13 Sep 2004 Post subject: |
| Ste |
 Ste Not Work Safe
 Posted: 00:57 - 13 Sep 2004 Post subject: |
And you've never ever done such things on the public roads now have you.
Good thing it was below 30 though as below 30 kids just bounce straight off if you hit them.  |
| mamak |
 mamak Derestricted Danger
 Posted: 11:14 - 13 Sep 2004 Post subject: |
Hi there. I've been to the traffic offices in Johannesburg and have seen them using a PC to clear up over exposure and even bounced flashes from reflective material on license plates. I'm sure the UK traffic police have similar measures.  ____________________ sliding by the seat of my pants. OUCH!!! |
| Sparks! |
 Posted: 11:40 - 13 Sep 2004 Post subject: |
| iCraig |
 iCraig World Chat Champion
| dainesefreak |
 dainesefreak World Chat Champion
| Tarmacsurfer |
 Tarmacsurfer World Chat Champion
 Posted: 13:00 - 13 Sep 2004 Post subject: |
It won't work.
The technique used is called 'negative imaging', basically the police unit flips the image to negative then adjusts the contrast/brightness. This means the plate is then visible and readable. Don't forget, this can also lead to being done for perverting the course of justice  ____________________ I'm immortal. Well, so far. |
| mamak |
| JonB |
 JonB Afraid of Mileage
| iCraig |
 Posted: 14:01 - 13 Sep 2004 Post subject: |
| Wave2k |
 Wave2k G's Stalker
| Andy99 |
 Andy99 Spanner Monkey
| livin_in_sinn |
 livin_in_sinn L Plate Warrior
| hustler |
 hustler Crazy Courier
| mrchips |
 mrchips World Chat Champion
The last post was made 22 years, 45 days ago. Instead of replying here, would creating a new thread be more useful? |
