dt 125 2002
shaunt6
PostPosted: 22:53 - 29 Nov 2011    Post subject: dt 125 2002 Reply with quote
hi
if i was to put a full dep exhaust on my dt 125 with a power valve servo would this increase the power if so by how much
thanks shaun
Supermotard37...
PostPosted: 23:01 - 29 Nov 2011    Post subject: Reply with quote
if you put a full dep pipe on your dt it should give you better performance also if you remove the rubber snorkel under the seat and im pretty sure if you earth a wire on the pv servo it lets the engine rev more freely making your weak dt into a bit of a bear, be warned tho it will void your insurance and your licence so dont get caught oh and check your plug colour when you change the pipe to make sure its not running lean and if so id up jet your carb and play with the mixture screws to make it perfect...
Good luck i had a blast when i had a dt !
Fuck off..!! "You absolute contraception malfunction"
dangerousdave
PostPosted: 21:40 - 22 Dec 2011    Post subject: Reply with quote
Have a look at this site - probably everything you'll want to know about DT125's
https://www.dtr125.net/tuningpartsf.htm
1988 Kawasaki KMX 200
Previous: Yamaha YZF1000, ZZR600, KMX200, DT50, KX80, CG125, PF50
dangerousdave
PostPosted: 21:41 - 22 Dec 2011    Post subject: Reply with quote
woll
PostPosted: 22:35 - 22 Dec 2011    Post subject: Reply with quote
If the powervalve is set up right then a full dep system gives the bike a fair bit of power. Take the clock off and remove the reed switch that gives more power. I found removing the snorkle like somebody has already mentioned made f all difference.
The last post was made 14 years, 305 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 44.14 Kb
