FZR600R Project cheap...
Damon
PostPosted: 22:18 - 04 Dec 2011    Post subject: FZR600R Project cheap... Reply with quote
Hi all,
Got this nice new winter bike and just thought i'd share...
https://a5.sphotos.ak.fbcdn.net/hphotos-ak-ash4/387468_10151021295305497_784455496_22177238_653288414_n.jpg
That's not the exact bike however.
Here's mine, spot the difference Laughing
https://a7.sphotos.ak.fbcdn.net/hphotos-ak-ash4/s720x720/383935_10151021205850497_784455496_22176880_33900947_n.jpg
https://a3.sphotos.ak.fbcdn.net/hphotos-ak-snc7/s720x720/390581_10151021207700497_784455496_22176889_107179078_n.jpg
https://a1.sphotos.ak.fbcdn.net/hphotos-ak-ash4/s720x720/374223_10151021204455497_784455496_22176874_669459881_n.jpg
Should make a nice winter bike Thumbs Up
TimNorwich
PostPosted: 22:21 - 04 Dec 2011    Post subject: Reply with quote
The difference is yours doesnt have the ghey 46 stickers Laughing
How did the rear wheel end up like that? The rest of the bike doesn't look overly crash damaged.
bunglebubs
PostPosted: 23:34 - 04 Dec 2011    Post subject: Reply with quote
Beat me to it Laughing
899 Panigale, K7 GSXR 750
Damon
PostPosted: 15:02 - 05 Dec 2011    Post subject: Reply with quote
Don't worry no number 46 or monster stickers will be fitted Thumbs Up
There is alot more damage than the pictures make out. I will try and get some better pictures today. The guy crashed it, it span around 180 degrees and parked itself in a wall. Swingarm is banana shape too!
Damon
PostPosted: 21:17 - 05 Dec 2011    Post subject: Reply with quote
Here are some more pictures as promised. It's pretty rough...
https://a5.sphotos.ak.fbcdn.net/hphotos-ak-ash4/s720x720/375211_10151025712275497_784455496_22195908_98431674_n.jpg
https://a8.sphotos.ak.fbcdn.net/hphotos-ak-ash4/s720x720/393659_10151025714245497_784455496_22195910_1605649122_n.jpg
It's got an alarm though!
https://a7.sphotos.ak.fbcdn.net/hphotos-ak-ash4/s720x720/379417_10151025719530497_784455496_22195923_1934180420_n.jpg
Today I got the wheel out of the swingarm. The wheel spindle was so banana'd that I had to cut through one leg of the swingarm to even get anything to move. Once off though I stripped the wheel's sprocket and brake disc and salvaged any bushings from the swingarm shock mount.
https://a4.sphotos.ak.fbcdn.net/hphotos-ak-ash4/s720x720/387862_10151025723135497_784455496_22195931_842579932_n.jpg
https://a1.sphotos.ak.fbcdn.net/hphotos-ak-ash4/s720x720/386003_10151025725140497_784455496_22195943_466412091_n.jpg
I then put all the bits onto the new subframe... much better
https://a7.sphotos.ak.fbcdn.net/hphotos-ak-ash4/s720x720/384272_10151025735230497_784455496_22195961_634708608_n.jpg
Also I manage to fix the broken rear wheel. It's amazing what you can do with a bit of T cut...
https://a4.sphotos.ak.fbcdn.net/hphotos-ak-snc7/s720x720/383733_10151025729445497_784455496_22195950_657340960_n.jpg
Umm...
https://a5.sphotos.ak.fbcdn.net/hphotos-ak-snc7/s720x720/387198_10151025732900497_784455496_22195955_1068321567_n.jpg
That's all for today. Waiting for some bits to turn up in the next few days.
Cheers all,
Damon
duzzer
PostPosted: 19:31 - 16 Dec 2011    Post subject: Reply with quote
thats a nice porject for nothing regarless of that wheel Thumbs Up ,
Damon
PostPosted: 21:30 - 18 Dec 2011    Post subject: Reply with quote
Cheers,
Bought some more bits for the bike including an upgraded adjustable rear shock Thumbs Up I hope it fits...
Fitted new bearings to the swingarm and the rear wheel today. Also started stripping the rest of the bike down for cleaning and servicing. I'm just waiting for the rear wheel spindle to arrive and it'll be time to start building it back up.
https://a2.sphotos.ak.fbcdn.net/hphotos-ak-ash4/382908_10151073307475497_784455496_22345460_1950503254_n.jpg
https://a2.sphotos.ak.fbcdn.net/hphotos-ak-ash4/s720x720/390681_10151073311085497_784455496_22345481_672227540_n.jpg
https://a4.sphotos.ak.fbcdn.net/hphotos-ak-ash4/s720x720/382873_10151073313180497_784455496_22345496_496698072_n.jpg
https://a4.sphotos.ak.fbcdn.net/hphotos-ak-ash4/s720x720/394605_10151076631715497_784455496_22364611_567233526_n.jpg
spent so far...
£60 van rent plus fuel to pick the van up
£101 bearings, service kit (plugs, oil, spindles etc)
£30 brake/clutch levers (shortys)
£15 chain adjusters
£35 adjustable shock
Damon
PostPosted: 20:35 - 22 Dec 2011    Post subject: Reply with quote
Spent some more time on it today changing the plugs and flushing out the carbs. The brown coloured gloop that came out of each float bowl doesn't fill with me hope when it comes to starting it. I will give the carbs a proper clean and overhaul as soon as I can get the thing on 2 wheels. Also cleaned the shock mounts and the rear of the bike. It's gleaming now! Thank god for Lidl engine cleaner.
As you can see the spark plugs hadn't be changed in a while...
https://a7.sphotos.ak.fbcdn.net/hphotos-ak-ash4/s720x720/404942_10151090251360497_784455496_22421753_1154031199_n.jpg
Does anyone know where to get thrust washers for the swingarm? Yamaha Europe are closed until the new year and I want to get the bike put together. Once I can get a pair of the washers (cup type things that sit over the swingarm bearings) i'll be much closer to winning!
Saying that, I'm still waiting for the new rear shock to arrive along with the new rear spindle. I got another set of chain adjusters from a FZR 3HE, They are identicle apart from the spindle hole being too small. A 20mm drill bit for the press will sort that out no problem.
Cost so far:
£30 brake/clutch levers (shortys) Cancelled order as they have no stock.
£15 chain adjusters
£15 second set chain adjusters
£8 20mm drill bit
Thanks all,
Damon
EDIT:
Managed to track the shock to my local post office. Will pick it up tomorrow.
Also bought some Thrust washers off a RD350. Apparently they are the same so we will see... At £7 for a pair its worth a gamble to get the build moving
Damon
PostPosted: 21:06 - 23 Dec 2011    Post subject: Reply with quote
After about 30mins queuing up in the cold at the local delivery office I was told I was at the wrong place and that "over the road" is where I needed to be Rolling Eyes So off I pop to the other post office to be told once again I was in the wrong place. Laughing After calling over the manager however a package with my name on it suddenly appeared...
Here is the old shock next to the new adjustable shock. I'm hoping it should give a slightly better setup at the rear of the bike.
https://a8.sphotos.ak.fbcdn.net/hphotos-ak-ash4/390508_10151092747290497_784455496_22431051_1268244663_n.jpg
And here it is test fitted to the bike. Once the swingarm thrust washers arrive it's pretty much all go to get the bike together.
https://a6.sphotos.ak.fbcdn.net/hphotos-ak-snc7/s720x720/382882_10151092750025497_784455496_22431059_1389203132_n.jpg
Thanks,
Damon
0l0dom0l0
PostPosted: 00:43 - 25 Dec 2011    Post subject: Reply with quote
Looking tidy, keep us posted!
Damon
PostPosted: 22:21 - 30 Dec 2011    Post subject: Reply with quote
Been busy today working on the FZR. It now sits on BOTH of its wheels Very Happy The shock feels nice and plush too. It's been a long time since I've had a bike where the seat hasn't been a piece of back protector foam or a thin motox unit. Rolling Eyes
https://a4.sphotos.ak.fbcdn.net/hphotos-ak-snc7/s720x720/378777_10151116253545497_784455496_22552306_774931200_n.jpg
https://a2.sphotos.ak.fbcdn.net/hphotos-ak-snc7/s720x720/400767_10151116255865497_784455496_22552326_1638780378_n.jpg
All 3 brake calipers are completely solid so that is the next thing to tackle on the list. Managed to get a set of EBC pads for the rear for free so that has helped with the build price a tad.
Here she is with the exhaust fitted
https://a1.sphotos.ak.fbcdn.net/hphotos-ak-ash4/401126_10151116258480497_784455496_22552357_215976413_n.jpg
Thanks all,
Damon
Price----
£15 chain adjusters
£8 20mm drill bit
£0 Rear EBC pads
evoboy
PostPosted: 01:10 - 31 Dec 2011    Post subject: Reply with quote
I have a set of front calipers that will fit this. Rebuilt by me and working fine with newish pads in.
Fire us a pm if the ones on it are too far gone Thumbs Up
(I did also have the shock aswell, but nevermind Laughing )
APT Motorcycles
The last post was made 14 years, 291 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 82.52 Kb
