Battery dead *Fixed*
samold55
PostPosted: 10:54 - 05 Dec 2011    Post subject: Battery dead *Fixed* Reply with quote
I'm new to biking so dont really no much yet but was wondering if I could get a little help. My battery died all of a sudden yesterday and I had to call out the RAC because I couldnt get home. Now when he tested it the battery had dropped from 12 volts to 5. He charged it back up and said half an hour of riding would fully charge it however it didnt. Also I got it working by doing that thing were you run with the bike and kind of jump on it to start it (not sure what it's called) and it started. I then left it running for about an hour and the battery still does not seem to want to work :/.
The bike is 2 years old and has done 3500 miles.
Thanks
Richtea
PostPosted: 11:09 - 05 Dec 2011    Post subject: Reply with quote
I'm certainly no expert, and I'm sure that you'll get a more useful reply from someone else, but it will either be your battery needs replacing or it is not being charged when the engine is running.
I had a similar problem with an old Vespa, let the battery run completely flat once and then whenever I charged it up would only hold its charge for a matter of hours before it went flat again. Got a new battery and problem solved.
I'm presuming that you havent got a kick start on the bike you can use? And running with the bike and jumping on is commonly known as a 'jump start'.
Hopefully you'll solve your problem,
2005 Honda Varadero 125xl > 2005 GS500F > 2007 DRZ400 SM > 600 Bandit & Yamaha YP250
pits
PostPosted: 11:12 - 05 Dec 2011    Post subject: Re: Battery dead Reply with quote
Thanks
Right first off it is called bump starting where you run jump on the bike and let the clutch out, don't do that with a V twin unless you know what you're doing, chances are you will drop it.
Have you got a whaddyamacallit meter little thing with round switch on checks all type of electrical stuff has two wires coming off it, you know what I mean, get the bike started and see what voltage the generator is putting into the battery, not entirely sure what it is on a bike but you want over 12volts going into the battery, chances are though the generator is fine.
Personally I would say your battery has had it, time for a new one, 3,500 miles isn't exactly much in 2 years and if it isn't being use all the time the cold will kill a battery, what you're best off doing is after finding out whether your generator is actually working, plonk a new battery in the bike and buy yourself an Optimate, and keep the bike on charge whenever it isn't being used, this keeps the battery in tip top condition.
Just done exactly the same with my Duke, costly mistake as I should have bought an Optimate back in the summer before the cold killed the battery.
Also be careful when filling up your new battery, the Bosch ones are pretty good to fill up but the one that I had to get for my bike had a slight danger element to it which involved spilling some acid, and as ghey as it sounds if you're filling the new battery with acid, goggles as the acid will destroy your eyes
fatpies
PostPosted: 11:14 - 05 Dec 2011    Post subject: Reply with quote
What is it? Let me guess its a Honda?
My guess is that the regulator rectifiyer is toast, thus causing the battery not to charge and go flat.
Its a quick 5 minute swap for £40-£70.
If the battery goes flat more than 3-4 times then its toast and won't hold a charge.
samold55
PostPosted: 11:29 - 05 Dec 2011    Post subject: Reply with quote
Okay thanks also I forgot to mention the bike was working fine untill it was in the rain for about 9 hours whilst I was in work do you think the water could of damaged anything ?
PostPosted: 11:56 - 05 Dec 2011    Post subject: Reply with quote
It could be the battery, it could be the regulator / rectifier (or possibly even the dyno).
You'll want to get yourself a cheap battery charger (so you can get the battery charged and the bike started) and a multimeter and find out. Don't guess, a charger and a multimeter cost less than a battery or a reg/rec.
With the engine running, you should see 14V+ across the battery terminals. If you're getting 12.5V or less then your reg/rec is shagged. If you're getting 14V+ with the engine running, shut it off, leave it for 20 minutes, and check the voltage. If it's under 12V then your battery is shagged.
What make and model is the bike? Does it do long runs or mostly short commutes? Have you owned it from new and did you fully charge the battery when you first got it? (First thing you should do with any new battery, it's not going to be fully charged when you get it and might never become so if you do short runs).
samold55
PostPosted: 12:02 - 05 Dec 2011    Post subject: Reply with quote
Okay I will do all that were can I get a cheap battery charger an reader from as I will do that first Laughing Also the bike is a chinese sanya 125 I bought it from a owner who had only done 1,300 miles on it. Also because of my new job I do commute quite a bit on it now around an hour of travelling about 5 days a week with a speed of about 30 - 50 mph.
Thanks
PostPosted: 12:13 - 05 Dec 2011    Post subject: Reply with quote
Welcome to winter. This time of year is a killer of batteries. Honda also has a problem with the reg/rec as mentioned above and it is simple to change.
Best thing to do is get a trickle charger and a new battery.
samold55
PostPosted: 12:18 - 05 Dec 2011    Post subject: Reply with quote
Okay thanks everyboy you've been a real help Very Happy Were can I get these charges etc... from I need them asap so a shop would be best.
Thanks again.
pits
PostPosted: 12:34 - 05 Dec 2011    Post subject: Reply with quote
Thanks
You want to hope that it isn't the reg/rec as I would imagine finding parts for it might be hard, to be painfully honest as it is a cheap chinky import I would be surprised if it wasn't coming up to the end of its life already especially if you're commuting, maybe get some ACF50 on it before they salt the roads.
As Rogerborg said pretty much what I did but without the complete mind blank, check it all with a multimeter and go from there.
PostPosted: 12:45 - 05 Dec 2011    Post subject: Reply with quote
Argos, Halfords, Maplin, any independent motor factor, although you'll get gouged to varying degrees. eBay will provide much cheaper basic items.
I'd suspected a Chinese-branded bike, and I'd bet the battery was never been fully charged on it and suffered sulfation damage early.
You may be able to rescue it with a more expensive smart charger like an OptiMate, but it's a gamble. Your bike will take a generic Yuasa battery (check by dimensions and any marked current rating on it) that a local factor may have in stock. I wouldn't bet on it though, and if they don't you'll likely be cheaper ordering online.
See if you can bump or kick start it now without charging the battery. If you can, and it runs, then your reg/rec is likely OK and it's just the battery that's died.
If you do end up needing a reg/rec then https://www.cmpo.co.uk keep a big stock of Chinese-branded parts. They don't list your bike (that's a bit weird) but if you give them a call then they should be able to sort you out with a reg/rec, they're essentially generic. If you're feeling braver, then a Honda CG125 reg/rec is likely to work, although anything that you buy now is likely to just come out of the same factory as a Chinese-branded one.
samold55
PostPosted: 12:51 - 05 Dec 2011    Post subject: Reply with quote
If you do end up needing a reg/rec then https://www.cmpo.co.uk keep a big stock of Chinese-branded parts. They don't list your bike (that's a bit weird) but if you give them a call then they should be able to sort you out with a reg/rec, they're essentially generic. If you're feeling braver, then a Honda CG125 reg/rec is likely to work, although anyone that you buy now is likely to just come out of the same factory as a Chinese-branded one.
Hi roger thanks again for a great reply the bike does bump start an I am able to ride it normally and like I said earlier I left it on for an hour yesterday to see if it would charge back up an no luck Sad
PostPosted: 12:56 - 05 Dec 2011    Post subject: Reply with quote
OK, then in that case you almost certainly do need a new battery. I'd recommend that you also get a cheap charger and charge it thoroughly before use and then regularly over the winter - if you're going to not be riding for a while then take it inside and tuck it up somewhere warm and cosy. Lead acid batteries get damaged by deep discharging and don't always recover, so keep the new one as fully charged as possible.
samold55
PostPosted: 13:00 - 05 Dec 2011    Post subject: Reply with quote
Okay well I'll get a charger first and try that and I'll try and find a new battery also this might be a stupid question but how do I actually charge it do I need to buy a certain charger for it ?
PostPosted: 14:14 - 05 Dec 2011    Post subject: Reply with quote
Any 12V charger will do, and unless you're going for a proper "smart" charger like an OptiMate then I'd just go for whatever looks cheapest.
However, try to get one with a low minimum charge rating, ideally no more than 500 mA (less than 1A). It sounds perverse to go for less, but small bike batteries can be damaged by a high current designed to recharge a car battery. You're looking for a "trickle charger".
pits
PostPosted: 14:52 - 05 Dec 2011    Post subject: Reply with quote
I think if you're looking to get into bikes and stay with bikes for a long time an OptiMate is probably the better purchase, expensive but they are awfully good, but with a battery on top to buy as well you could be looking up to £100 for both.
blade023
PostPosted: 18:13 - 05 Dec 2011    Post subject: Reply with quote
This. I was in a bike centre a while back and I saw this bulging battery. I asked the guy about it and he said "some noob tried to charge it with a standard car charger." Bike batteries can't take as much charge, so a smart charger or 'trickle' charger is what you need.
Current: VFR800 2008 13.7k and rising rapidly!
Sorn: 2003 FZS1000 30k(ish) looking to sell.
samold55
PostPosted: 20:04 - 05 Dec 2011    Post subject: Reply with quote
Would you say this would be okay ?
https://www.diy.com/diy/jsp/bq/nav.jsp?action=detail&fh_secondid=11387631&fh_location=//catalog01/en_GB/categories%3C{9372016}/categories%3C{9372052}/categories%3C{9822020}/specificationsProductType=chargers___adaptors
Also what amp would it need to be ?
PostPosted: 21:59 - 05 Dec 2011    Post subject: Reply with quote
Absolutely not. That's an 8A charger, you want much lower. Think 2A or less.
I'd go under 1A. You're not in a hurry to over-charge it. If you can wait a couple of days, an Oxford Oximiser 600 (or equivalent) will do a better job for under £20 from eBay, or maybe you can find a stocking nearby.
samold55
PostPosted: 12:26 - 06 Dec 2011    Post subject: Reply with quote
Okay I am going to buy the charger today I just hope it works Laughing
samold55
PostPosted: 15:47 - 06 Dec 2011    Post subject: Reply with quote
Got the charger how long would you say to charge for ?
samold55
PostPosted: 12:25 - 07 Dec 2011    Post subject: Reply with quote
Okay so I charged the battery up and it seems to be working fine let's just hope it dosent die on me again In the meantime though I will order a new battery.
samold55
PostPosted: 18:35 - 08 Dec 2011    Post subject: Reply with quote
Just an update battery got charged for 18 hours and it's holding it's charge Very Happy
Thanks for the help everybody.
Sam
PostPosted: 19:36 - 08 Dec 2011    Post subject: Reply with quote
Glad you got it sorted. When the new one arrives keep it as spare. Charge it up when you need it.
The last post was made 14 years, 345 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 128.59 Kb
