Helicoil question
jamesrs250
PostPosted: 22:10 - 04 Dec 2011    Post subject: Helicoil question Reply with quote
i need to repair my spark plug thread i have the right size helicoil M10 x 1.00. i need to know what tap size and drill size i would need to use. i have the tool and brerak pin tool from a kit i used before.
ZebraDriver
PostPosted: 22:26 - 04 Dec 2011    Post subject: Reply with quote
Helicoils have a special tap because the size and thread pitch do not match standard engineering stuff. An online search should get you the info you need for both the tap and the drill.
ZD
just did the search for you 10.25mm tap drill and a helicoil tap 4984-10
Fizzer Thou
PostPosted: 22:37 - 04 Dec 2011    Post subject: Reply with quote
Here you go
https://www.ebay.co.uk/itm/Thread-Repair-Kit-Helicoil-Inserts-M10x1-0-/330647454735?pt=UK_Hand_Tools_Equipment&hash=item4cfc1fc40f
Always have a 'Plan B'
jamesrs250
PostPosted: 22:45 - 04 Dec 2011    Post subject: Reply with quote
thanks
i have a m10x1 tap
but only a 10.5mm drill bit
so will have to find a 10.3 bit from a tool shop becuse 10.3 is a bit of a weird size dont think you would find a 10.3 from b&q
Fizzer Thou
PostPosted: 22:50 - 04 Dec 2011    Post subject: Reply with quote
https://www.ebay.co.uk/itm/EXPERT-10-3mm-HSS-TWIST-DRILL-HELICOIL-THREAD-REPAI-/400205902643?pt=UK_Home_Garden_PowerTools_SM&hash=item5d2e217333
jamesrs250
PostPosted: 22:57 - 04 Dec 2011    Post subject: Reply with quote
thanks agen,,, i allready found them on ebay..i just wanted to do it tomorow
jamesrs250
PostPosted: 13:20 - 05 Dec 2011    Post subject: Reply with quote
i have done some more searching and asking people who sell helicoils and alot of them dont know 100% if they are the same tap size as a normal tap or the say they are
one seller who sounds like he knows 100% said
Hi,
Yes they are oversized to allow for the insert. An M10 1.0 helicoil tap has a diameter of 11.3mm
craigT19
Jolly Green Giant
PostPosted: 11:00 - 06 Dec 2011    Post subject: Reply with quote
Hi,
Helicoils are ok but tbh are not particularly suited to a spark plug thread, with the high pressure plus the chance your be taking plugs in and out over time the coil will loosen so its more of a medium term fix. Hellicoils also dont sit flush to the head, if your plug is slightly counter sumk it will sit ontop of the hellicoil altering the plug heigh within the combustion chamber.
Personally i use timeserts, there stronger sit within the current damaged thread and once in perminent. A timesert kit can be an expensive item however, but the kits ive seen all come with the taps and drills your need for that particular timesert
https://www.wurth.co.uk/time-sert.php
https://www.youtube.com/watch?v=pLVDb0xcvMo
Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
Crying or Very sad BCF member pops. sadly missed Crying or Very sad 1945-2003
ZebraDriver
PostPosted: 18:51 - 06 Dec 2011    Post subject: Reply with quote
Perhaps the fact that the tapping drill is bigger than the thread size being used i.e. a 10.25 drill for a 10mm thread should alert you to the fact that the heli-coil insert (and thus the tap) HAS to be bigger than the 10mm plug that you are fitting and that an ordinary M10x1.0 tap is not suitable for use when fitting heli-coils.
Even without the info I gave you you must be able to work out (fairly easily) that the insert must be a bigger diameter than the plug that you are going to fit into it.
Please don't bother asking for info on here if you are not intelligent enough to use what people provide.
bencav
PostPosted: 20:24 - 06 Dec 2011    Post subject: Reply with quote
Touch abrupt dont you think?
I have never used a tap nor insert before so I would have no clue either! And please, lets not get onto the intelligence thing!!!
Try to remeber that the only stupid question is the one you DIDNT ask!!
MickC
PostPosted: 20:27 - 06 Dec 2011    Post subject: Reply with quote
craigT19 wrote:
Hi,
As the gent said timeserts are far better and more reliable and durable. 7 out the 24 cam retaining bolts in my head are done with timeserts (4 of them used to have helicoles, but i found i had to redo them each time i worked on the head)
XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1
Ed Case
PostPosted: 20:30 - 06 Dec 2011    Post subject: Reply with quote
A Helicoil will 'do' for a spark-plug hole reclamation but on recommendation I've had a 'Timecert' fitted in my 250RSA cylinder head. In the past I've had Helicoils come out with the bolt, probably a cock-up when being fitted but nevertheless they did come out. Best of luck whichever you decide upon !.
The last post was made 14 years, 328 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 73.08 Kb
