| johnsmith222 |
 johnsmith222 World Chat Champion
| fatpies |
 fatpies World Chat Champion
| Mikey3 |
 Mikey3 World Chat Champion
| totalllama82 |
 totalllama82 Crazy Courier
| Howling TerrorOutOfOffice |
| iooi |
 iooi Super Spammer
 Posted: 20:05 - 05 Dec 2011 Post subject: |
I wonder if you have been bleeding the brakes so much that you have knackered a bleed nipple and its not sealing fully.
Try a bit of PTFE tape on the threads.
How old are the lines. Might be worth looking at replacing them if they are over a few years old.
Replace all the seals in the calipers.
As someone else said. Could be master cyl seals that are going. ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| Mikey3 |
 Posted: 10:13 - 06 Dec 2011 Post subject: |
If this is happening over a week or 2 then it is a bit strange. Water boiling giving a spongy lever would probably happen immediately that water got into the system, and would also only change things when the brakes got hot (it would behave just like brake fluid when just trying the brakes cold and not moving).
Worn hoses would do the same and also if the piston seal in the master cylinder is worn (it would just leak to behind the piston which is part of the reservoir).
If the outer seal when on the master cylinder then it would leak fluid, which might drop the level of fluid to cause problems. Same if the diaphragm in the reservoir is missing / damaged.
To me the most likely thing is a very very slightly damaged caliper seal allowing a tiny air leak.
| totalllama82 |
| Walloper |
 Walloper Super Spammer
| iooi |
 iooi Super Spammer
The last post was made 14 years, 329 days ago. Instead of replying here, would creating a new thread be more useful? |
