Info on 1998 r1 usd forks ASAP!!!
steven_191
PostPosted: 14:23 - 05 Dec 2011    Post subject: Info on 1998 r1 usd forks ASAP!!! Reply with quote
Not that ASAP really. eBay auction ending later today and I need to know the diameter of the forks where they fit into the yokes.
I'm sure some clever folk on here know the answer. All help appreciated
Thanks
By the way I'm hoping you say 50mm top and 54mm bottom.
Bezzer
PostPosted: 15:12 - 05 Dec 2011    Post subject: Re: Info on 1998 r1 usd forks ASAP!!! Reply with quote
Go on then I'll say it Mr. Green ....R1 forks are 50/54 .....
up to at least 2002 models (know someone with 02 ones in a slingy) dunno if they changed later or not but 98 will be fine.
steven_191
PostPosted: 16:50 - 05 Dec 2011    Post subject: Reply with quote
Are you saying they are 50/54 or are you doing what I expected someone to do and just say that??
These aren't actually for an r1. It's for a project. Just considering as they're cheaP
Bezzer
PostPosted: 16:54 - 05 Dec 2011    Post subject: Reply with quote
Straight up dude Thumbs Up 02 R1 is 50/54 and I believe they didn't change from the original 98 model.
Fizzer Thou
PostPosted: 16:56 - 05 Dec 2011    Post subject: Reply with quote
I have just checked the fork dimensions on my 2001 R1 and the upper diameter is 50mm and the lower is 55mm.
Always have a 'Plan B'
steven_191
PostPosted: 17:14 - 05 Dec 2011    Post subject: Reply with quote
Amazing. This could work out well then. Now I just need to be sure I can get lighter springs and should all be gravy
Fizzer Thou
PostPosted: 17:20 - 05 Dec 2011    Post subject: Reply with quote
I recently performed an upgrade on a friend's '99 R1 where I installed some 0.95kg springs from K-Tech as the OEM ones are too soft.This,together with new seals and 7.5w fork oil from Motul made a big differance to the handling of his bike using the standard air gap.
steven_191
PostPosted: 20:33 - 05 Dec 2011    Post subject: Reply with quote
I'm hoping for the project to come in at less than 140kg.
I'm going to look for k-tech now. I don't know enough about suspension to be able to make the right decisions on what I need in terms of springs and rates etc. All I know is that when its all together I'm going to weight it. Thumbs Up
Well they do springs between 8.5 - 10.5n which I guess is newtons? Who knows. Hopefully it'll work lol
PostPosted: 22:27 - 05 Dec 2011    Post subject: Reply with quote
I read in a mag somewhere that 1998 R1 forks have loads of extra travel to try to reign in the huge tendency to wheelie of the original R1 and consequently don't give the best handling in the world...
Obviously I'm not speaking from experience but it is something to consider nonetheless.
steven_191
PostPosted: 00:02 - 06 Dec 2011    Post subject: Reply with quote
But they've still got to beat cagivas one side damping and one side rebound with a single spring.
Still, complete front end for £250 I don't think is too bad. Its got those blue spot calipers and everything except a mud guard
steven_191
PostPosted: 13:46 - 11 Dec 2011    Post subject: Reply with quote
Just so you know the r1 forks are definitely 50 and 54mm top and bottom. They slot straight in and bolt up to the cagiva yokes. Unfortunately the width is different so I'll be getting the stems out of each bottom yoke in order to fit the cagiva one into the r1 yoke. Should work out quite nicely.
I'm guessing I'll probably need to weld in a sleeve on the bottom of the stem to fit into the r1 yoke as its generally bigger all around. This should take up the slack.
The last post was made 14 years, 276 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 68.56 Kb
