Bandit adverse handling
hazza
PostPosted: 17:39 - 05 Dec 2011    Post subject: Bandit adverse handling Reply with quote
So On the way home tonight I noticed my bandits handling was shit. If I take my hands of the bars the bike pulls slightly to the right then it starts going left to right after that. With the front wheel in the air the bars do seem to go right slightly easier than to the left. What am I looking at? It's not notchy or anything and I've recently greased the head bearings.
Thanks in advance
Harry
StevRS
PostPosted: 18:05 - 05 Dec 2011    Post subject: Reply with quote
Assuming the head bearings are ok, it sounds like fork or wheel alignment.
MV Agusta Brutale 800 RR, Unfinished 1978 XS250
PostPosted: 18:10 - 05 Dec 2011    Post subject: Reply with quote
..and to add. Check suspension. My old 250 used to weave and all the bearings were ok. It was the knackered rear shock absorbers.
hazza
PostPosted: 12:54 - 06 Dec 2011    Post subject: Reply with quote
Tested it gain this morning, The issue does not present itself at speed. At 20-30 mph i can comfortably sit with my hands on the tank and nothing. It only happens at *low* speed. Mad
PostPosted: 13:03 - 06 Dec 2011    Post subject: Re: Bandit adverse handling Reply with quote
Are you sure you're sat dead straight on the bike?
People will often sit slightly off, which can affect this sort of thing.
hazza
PostPosted: 13:05 - 06 Dec 2011    Post subject: Reply with quote
Reasonably sure. Only thing i could think is that i have renthals on it and non standard bar end weights.
PostPosted: 13:08 - 06 Dec 2011    Post subject: Reply with quote
Wheel alignment is still a good call.
But, if it doesn't happen at 20mph, I wouldn't worry too much personally - bikes are going to be a bit unstable below this anyway.
Happening at low speed but not high is much less concerning.
Walloper
PostPosted: 14:35 - 06 Dec 2011    Post subject: Reply with quote
Tyre pressure/s extremely low.
You have an un-detected broken humerus.
Make sure the streeing is correctly set and front axle bolts etc. are tight.
Bursted front fork seals, no oil, broken springs and cetera.
PostPosted: 14:39 - 06 Dec 2011    Post subject: Reply with quote
Low speed weaving is a symptom of overtight head race bearings.
The last post was made 14 years, 329 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.17 - MySQL Queries: 13 - Page Size: 59.79 Kb
