| 0l0dom0l0 |
 0l0dom0l0 World Chat Champion
 Posted: 22:23 - 05 Dec 2011 Post subject: Anyone know any bikes that use direct injection? |
Just making a project on DI for a uni assignment, want to taylor it to bikes a bit more instead of cars. Anyone know any bikes that use DI?
 ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
Bikes: 2007 Derbi GPR 50, 1998 Yamaha Fazer 600 (written off), 2002 Yamaha Fazer 600, 1994 CBR 600F, 2003 Triumph Daytona 600, Kawasaki ZX6R J1.....Current: 2006 Yamaha FZ6, 1998 Suzuki TL1000R and a Honda VFR 400 NC30. |
| G |
 G The Voice of Reason
 Posted: 22:27 - 05 Dec 2011 Post subject: Re: Anyone know any bikes that use direct injection? |
Bimota V-Due is the only one I can think of off hand.
(Though I believe there was a 'recall' to swap it to carbs due to issues with the direct injection, which may help explain why there haven't been more ).
Oh and that diesel KLR based bike probably does as well. |
| MarJay |
 MarJay But it's British!
| 0l0dom0l0 |
 Posted: 22:48 - 05 Dec 2011 Post subject: Re: Anyone know any bikes that use direct injection? |
| G wrote: | Bimota V-Due is the only one I can think of off hand.
Yeah, I've just been reading. It was swapped back to carbs for a number of reasons but with some more work on the oil injection and things DI in 2 strokes is deffo the way forward. ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
| Frost |
 Frost World Chat Champion
| G |
 Posted: 22:58 - 05 Dec 2011 Post subject: Re: Anyone know any bikes that use direct injection? |
 Posted: 23:16 - 05 Dec 2011 Post subject: |
As I understand it the original V Due had major problems even ignoring the fuel injection. The evo versions with carbs also had substantial mechanical changes.
From what I have heard, the V Due fuel injection relied on the fuel striking the piston to attomise it. But this only work when the piston was in the right place compared to the injected fuel, resulting in a fairly narrow power band. Some have been converted to run the fuel injection in a non direct way and this is meant to work quite well.
| 0l0dom0l0 |
 Posted: 23:26 - 05 Dec 2011 Post subject: |
DI in 4 strokes is a fair way off yet too. Although it offers lots of advantages in terms of fuel economy and emissions, the actual system itself has one major floor.
Don't know if you are aware of the problems, but any blow by from the piston rings causes a positive pressure in the crankcase, which is expelled through the crank case breather, taking oil vapour with it. This the condenses on the inlet valves leading to this:
Found it quite interesting doing a project on it actually, surprised its actually used commercially with a problem as big as that ^^ ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
| 0l0dom0l0 |
 Posted: 23:50 - 05 Dec 2011 Post subject: |
| Kickstart wrote: | Hi
Not sure why direct injection would make that more likely.
Been a fair few direct injection 4 stroke car engines. Think Mitsubishi were the first with one with a modern one on sale in decent quantities.
Keith |
Its not a problem on any other fuelling system as the valves are 'washed' by the fuel coming in. DI injects straight into the cylinder so no fuel to wash the oil off.
It's used on loads of things now. RS4, 135i, 335i to name a couple! ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
 Posted: 23:54 - 05 Dec 2011 Post subject: |
| Wozza |
 Wozza Brolly Dolly
| weasley |
 weasley World Chat Champion
| GeneralXcepti... |
 GeneralXcepti... Nova Slayer
| Teflon-Mike |
 Posted: 14:07 - 06 Dec 2011 Post subject: |
I may be confusing a few different projects here, but some random thoughts that sprung to mind if any use.
1/ ORBITAL - I have a feeling this was project name for a direct injection two stroke, that deliberately 'four-stroked'. It worked on a 'full-fill' principle, so if the throttle was part closed choking fill, it 'hung fire' and waited until there was enough charge in the pot to give a full fill, optimum efficiency burn. Governing the engine by restricting the power strokes rather than the charge in a power stroke. And I have a feeling it was a Honda research piece, but not certain, and sure there was a Yamaha project that was similar.
2/ Indirect-Direct Injection; Circa the same era there was a novel 'exhaust port' injection system, squirting juice into the two stroke exhaust port, on the reverse shock wave of the expansion chamber, just before the port closed. Was supposed to offer all the benefits of direct injection, without the compexity of high pressure injection or in the chamber injection equipment. MAY have been part of the Orbital project.
Norton messed with Injection on the Rotary... did they ever go DI?
Probably all 'old ground' I haven't been following MCN' Scoops' for many many years! But may be some use. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
 Posted: 14:16 - 06 Dec 2011 Post subject: |
Orbital was (maybe is) an Australian company that developed some 2 stroke direct injection systems and tried to licence the technology to various other companies. Heard nothing about them doing anything with missing some power strokes.
About 15 years or so ago there was a batch of Ford Fiestas built (not for sale but for testing purposes) using orbital developed 2 stroke engines. They were very clean running but if I remember rightly what put Ford off progressing further was the limited engine life compared to their conventional 4 stroke engines (from memory the life expectancy of the orbital engines as about 50000 miles).
Don't think Norton did anything about direct injection.
The last post was made 14 years, 276 days ago. Instead of replying here, would creating a new thread be more useful? |
