| manox |
 manox L Plate Warrior
| MickC |
 MickC Spanner Monkey
 Posted: 20:32 - 06 Dec 2011 Post subject: Re: Smaller battery for relocation (6v on a cb125j). |
| manox wrote: |
Is it a case of finding a smaller battery with the same voltage and amp per hour capacity?
If anyone can help, i'd be very much appriciative as this subject is doing my bloody nut in! |
In a nut shell Yes! ____________________ XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1 |
| MickC |
 Posted: 20:46 - 06 Dec 2011 Post subject: |
Something just crawled up the back of my mind, does it have a kick start?. If so it is possible to do away with the battery. Here's a link to a page that will give you the general principle:
https://www.porkersusa.com/tech_tip_articles/electrical_run_without_a_battery.html ____________________ XX XXXx
| zombie_dave |
 zombie_dave Borekit Bruiser
| manox |
| zombie_dave |
| robocog |
 robocog Traffic Copper
| manox |
| robocog |
| robocog |
 Posted: 17:48 - 07 Dec 2011 Post subject: |
https://www.bikechatforums.com/viewtopic.php?t=189514&highlight=batteryless
That was my initial post and the susequent discussions
TLDR;
mine is a 1/3 of a Farad and 40V, physically inbetween a can of coke and a small can of redbull in size and /seems/ to work OK so far for my experiments- my project bike is not yet on the road so only has had very limited testing!!!
Regards
Rob ____________________ Needs a bigger garage... |
| Teflon-Mike |
 Posted: 18:42 - 07 Dec 2011 Post subject: |
Battery acts as charge reservoir; capacitor acts as charge damper.
Imagine a capacitor as a spring in a brake line; transmits the force but takes out any shock in the line; where a reservoir would accumulate pressure and let it be used for longer.
I have 6v electric Yamaha DT, and am messing around with a 12v pit bike regulator, to convert to 12v. Generator is supposed to chuck out enough volts, and using both coils, the charge circuit and direct lighting circuit, ought to provide enough amps to keep small 12v battery charged to power 12v lights without the low rev 'drop of' direct lights suffer, while 12v offers more compatability for modern upgrades like LED's to lower power demand and make more juice available; possibly even a PIR headlamp for more light without less amps still.
This may be possible on the CB125 single's generator.
Alternatively; sticking with 6v, knowing 6v systems of old, even with a battery low rev lamp dimming is a pain. Many bikes of the era ran 'direct lights' so they didn't get any top up from the battery so were entirely dependent on genny revs for volts; battery only powered occassional equipment like horn and indicators.
Using a 6v regulator, possibly from an early 6v CB200 Benley, and routing direct light circuit and charge circuit through it to charge a battery to power all equipment, including lights, would be a good move, and make electrics more reliable.
Another alternative, still being toyed with for the DT, is if the genny and pit-bike regulator dont prove good enough to convcert to 12v... going 12v 'low amp' conversion anyway, using LED bulbs for indicators, dash tell-tales, side, tail & stop lamp, and a solid state low consumption indicator flasher, and a 35W PIR headlamp, and running the system 'Total Loss', having two batteries; one on the bike, one on charge in the house!
Lights dont HAVE to be self sufficient....
On a 78 model bike; you also don't HAVE to have indicators, and need only have the brake lamp work of one brake lever.
Two types of battery commonly out there
Standard batteries are wet acid filled. They have to be mounted terminals to the top or the acid sloshes out through vents.
'Sealed' batteries are often wet acid filled, but unvented. These tend not to have the charge/discharge rating of vented batteries, and are not usually reccomended for bikes or cars. Competition bikes and cars often use Sealed 'Gel' batteries that have an acidic gelly (yes basically you make a jelly like you would for a trifle of kids birthday party, but with sulphuric acid rather than water! And fill the battery with it!) More stable, can be mounted in any orientation to suit, and wont slosh acid. But expensive.
For your wants, I would sugest that a sealed, preferably gel-cell battery, of the same or greater amp-hour capacity, would be more suitable. You can find a place to site it to convenience, and tilt it to suit. Meanwhile, need not be bigger than original; external dimensions can be smaller on modern batteries.
If you are not putting heavy charge or discharge rates on the battery; if you have currently a direct lighting system, battery charged by excess genny amps at a trickle to power indies and horn, you probably could get away with a 6v 'sealed' burglar alarm battery; these are fairly cheap on e-bay, but check Maplins for specs and dimensions; they are designed to hawve very long service lifes, typically around ten years, but with very low charge and discharge rates, sat in a box on the side of a house providing independent suply for a lamp and claxon if the alarm goies off and the mains supply is cut. They are commonly de-rated for consumer products; thier life expectancy shortened, exceeding the specified charge and discharge rates, for use in things like car battery 'booster' packs, or kids ride on toys and stuff; Charge rates exponentailly reduce battery life, so double the charge/discharge current, battery life drops by a quarter, BUT, you can go quite a long way before you are down to the one or two years 'life' of a conventional bike battery.
If you want least-fuzz, solution, keeping the electrics 'as standard' but able to put battery where you like; I think this is what I would suggest as most suitable; Burglar Alarm battery in the 3-5Ah capacity range your CB-J battery is likely to be in, probably barely any difference in price to the OE spec wet & vented battery.
Depends how adventurouse you want to get; BUT do have a think about going 12v. With low wattage LED's sucking milli-amps instead of amps, you can make a small capacity 12v battery last a long time, even if you run it 'total loss'; and you have far more scope to start choosing from far more 'standard' 12v equipment, thats often better and or cheaper than whats available in now rarely used 6v components. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| manox |
| Noxious89123 |
 Posted: 22:22 - 07 Dec 2011 Post subject: |
You can get small + light 12v LiPo batteries for race bikes that are much smaller than a normal lead acid battery. Rather pricey though! ____________________
The last post was made 14 years, 311 days ago. Instead of replying here, would creating a new thread be more useful? |
