Starter motor not engaging sporadically
blade023
PostPosted: 18:55 - 06 Dec 2011    Post subject: Starter motor not engaging sporadically Reply with quote
So I went to get some oil for an oil change, got on the bike and it wouldn't start. I pressed the starter button and heard a click, which sounds like the relay, but no other sound. Got my trusty multi meter out and checked; 12.something volts from the battery. So I decided to bump start it, which was touch and go (or not Razz ) as it's a carbed twin engine so I had to be careful keeping it running as it's been a little cold here lately.
I went round the block and came back onto the car port, and tested the starter (with the engine running) and it turned over fine. So I stopped the engine and tried the starter again; same thing. Putting the bike in gear and rocking it forwards seem to sort it, it started fine. I managed to get to the shop and back ok but got the same thing; to get the starter motor working I put the bike in gear and rocked it forwards, then it started ok.
So does anyone have any ideas about what might be causing this? It's the first time this has happened on this bike, but I had a similar thing with my last bike (125 with a copy of a cg engine.)
Before anyone says it, it's not the subframe. I've had it straightened since I got the bike. Cost me a couple of hundered but was definately worth it as the bike now feels a lot more ambitious and generally less aprehensive about life in general.
Current: VFR800 2008 13.7k and rising rapidly!
Sorn: 2003 FZS1000 30k(ish) looking to sell.
MickC
PostPosted: 20:09 - 06 Dec 2011    Post subject: Reply with quote
From what you say (rocking it in gear) it sounds like the starter motor isn't engaging/disengaging from the engine. Don't know what make or model you have, but try starting with the starter motor clutch assembly. It does seem odd that an oil change (assuming it's the right oil for the engine) would be the cause, were there any starting problems before?.
XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1
blade023
PostPosted: 20:55 - 06 Dec 2011    Post subject: Reply with quote
That makes sense, but I'm wondering what would cause it to happen or what I could do to fix it..
It's a 1996 CB500t, completely forgot to mention that.
I'm not really sure what you're trying to say here Confused
To clarify; I went to start the bike so I could go buy some oil for the change, which I've yet to do. Nothing has changed or been done to the bike since it was last running about 2 days ago, and I wasn't having any problems with it then.
Thanks for the reply, it's given me something to look into. Back to google..
Ed Case
PostPosted: 21:21 - 06 Dec 2011    Post subject: Reply with quote
These starter clutches rely on (usually) three rollers + lightweight springs locking by centrifugal force on a machined 'drum'. It sounds like general wear and tear on all three parts. Best get it seen to promptly because they can be prone to 'jamming' which has been known to quite literally 'explode' the starter motor and cause other peripheral damage.
The last post was made 14 years, 320 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 42.3 Kb
