aprilia 125 help?clutch dint?(i think)
hadden
PostPosted: 21:12 - 06 Dec 2011    Post subject: aprilia 125 help?clutch dint?(i think) Reply with quote
hi all.started to strip me engine as piston rings knackered a few weeks back.im changing the piston and head but whilst im at it thought i might as well change the bottom end.im gonna be honest when i say i have never split a 2 stroke before.but i simply cant afford to pay someone.anyways got the side casing off which im pretty sure is the clutch side, and i have noticed a dint on the top.(ill add a piccy)is this ment to be there?.also i have seen a bolt just under the clutch which i need to take out to split the engine.does anyone know,before i attempt, does the clutch need to be taken off to get this bolt off???please no nasty comments about me not attempting it.there is no other way.and everyone starts somewhere Very Happy any help will be brill.cheers
red bull gives you wing sting!!!
current:aprilia rs 125
previous:honda c90,honda cm 125,yamaha xt 550,2004 suzuki drz 400.(all used for off road back in the day)and a piagio zip 50cc..oooossssshhhh
PostPosted: 00:16 - 07 Dec 2011    Post subject: Reply with quote
If it is a 122 engine I think the clutch basket comes out easily.
Think you will need to remove it all to split the cases.
Do you have the necessary pullers to put the crankcases back together?
andy_uk
PostPosted: 07:38 - 07 Dec 2011    Post subject: Reply with quote
Yes, it definitely needs removing to split the case... I'm doing mine at the moment..
You'll need a puller for the flywheel (I made one for mine!!) You'll probably find that the crank will stay attached to one side of the case. I made a puller to remove that too, although I don't know how easy it's going to be getting it back in again... Confused
PostPosted: 11:13 - 07 Dec 2011    Post subject: Reply with quote
Problem is that the bodge way to do this is to press the cases together over the crank. Which puts a side load on the main bearings and they will fail after a short while.
A puller is used to pull the crank into the crankcase half .
hadden
PostPosted: 19:02 - 07 Dec 2011    Post subject: Reply with quote
right ok cheers lads.and yes its a 122 engine.only found that out yesterday.is there a massive difference between the 2 engines?
hadden
PostPosted: 19:03 - 07 Dec 2011    Post subject: Reply with quote
and no i dont have the correct pullers either Sad
PostPosted: 19:34 - 07 Dec 2011    Post subject: Reply with quote
Quite a bit. Plenty is shared but plenty of differences (front engine mount is different, 122 has no tacho drive, totally different ignition system, barrel mounts are slightly different).
The last post was made 14 years, 311 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.19 - MySQL Queries: 13 - Page Size: 55.02 Kb
