Ktm exc 125 or exc 250f
Diesel
PostPosted: 01:36 - 08 Dec 2011    Post subject: Ktm exc 125 or exc 250f Reply with quote
I am 17 and going to get my bike licence, i live in the uk so have to have a restricted licence for the first 2 year, which is a restricition to a 125 or 33 bhp, i know its anoying but i guess its a good thing in away. i have been riding bikes since i was 5, so not completlly bike illetrate, but i wanted to know which of these bikes would be best to use for onroad and possibly offroad use aswell.
list of pros and cons for the both, also key in money factors etc, as im not flushed with cash,
all replies appreciated
MaybeGuy
PostPosted: 07:19 - 08 Dec 2011    Post subject: Reply with quote
Neither will be good on the road. I'd go for the 4 stroke. Fyi you probably can't actually ride a 33bhp 125 on an a2 because the power to weight ratio is too high.
May as well just fuck off the whole restriction thing. I havn't known anyone be restricted, or be caught for it, even after crashes.
PostPosted: 09:36 - 08 Dec 2011    Post subject: Re: Ktm exc 125 or exc 250f Reply with quote
Both bikes will have to be restricted, or certainly proved to be under the requisite power.
Note that it specifies both a power and power to weight limit. Because these are light bikes, they'll probably come under the power to weight limit even if they are 33hp - though I thought they were generally QUOTED as a bit more, though the 125 at least makes less at the rear wheel according to trail bike mag I think.
(Edit - matt's mentioned that too.)
If you really want to go for a competition race bike and ride it on the road as a get-around bike, go for the 300/530 or similar.
Diesel
PostPosted: 13:44 - 08 Dec 2011    Post subject: Reply with quote
Thanks your replies, i think id be better off going for the 250, and im using it as a run about, and something i can have loads of fun on off and on road, and matt i agree with you i couldnt give a fuck really about the restriction but as long as i can say thats its under 33 bhp ill be fine lol,
i now some people think its a bad idea to get one for the road but its just for a runabout and mainly i will be only on the roads for a short while becasue i have fields and trails that lead to different places close by, so most of my riding will be done on there (offroad) just want one legal so dont have to worry about going on the road to go to somewhere etc.
Supermotard37...
PostPosted: 13:49 - 08 Dec 2011    Post subject: Reply with quote
Well i have a ktm 125 exc on the road as my everyday bike and to be honest its good to have a short blast, on but riding all the time its terrible to just cruise on it hates not being in the power band haha, honestly i wouldnt bother,i used to have a yamaha dt 125x and that was great to ride on the road it was so smooth compared to the ktm plus with my ktm i have to pre-mix at petrol stations wich is a c*nt.
Fuck off..!! "You absolute contraception malfunction"
PostPosted: 13:52 - 08 Dec 2011    Post subject: Reply with quote
Why would you decide to go for the one which needs a fair bit more maintenance and is more highly strung to some degree?
It's possible the 250f will be over 33hp on a dyno.
Diesel
PostPosted: 14:00 - 08 Dec 2011    Post subject: Reply with quote
Can you explain why it will be a bit more maintainence, if i got the 125 i could fix that no prob if anything goes wrong, and can change pistons in them easilly
buy with the 250f i believe that it wont need pistons changes as frequent compared to the 125, but im unsure weather i could do a piston change on a 4 stroke but if not i always have soemone who could do it for free so cost from the P.O.V is minimul
and i always thought 2 bangers were more maintainance than 4, my opinion
PostPosted: 14:13 - 08 Dec 2011    Post subject: Reply with quote
Have you done regular maitenance on 4 stroke competition bikes?
Not only do they need more effort, even if needed less often - due to a lot more moving parts.
But when they go wrong, thanks to that much increased amount of moving parts, it tends to be much worse too.
Diesel
PostPosted: 14:30 - 08 Dec 2011    Post subject: Reply with quote
thank you, the 250 are less likely to go wrong and if thy do then i will have to get it fixed, wont cost me as much cos all i need to do is buy parts then my unlce would fit them, but i belive i could do it myself with him teaching me so want be a problem, thanks for your replies,
and does anyone one now the specification of theses to bike:
top speed of both: ?
bhp for both: ?
power to rate: ?
thank you
PostPosted: 14:51 - 08 Dec 2011    Post subject: Reply with quote
Top speed of both: Depends on gearing, probably about 80-90 with the right gearing and right tyres.
Bhp for both: 25-35hp depending on dyno, year, current state and extra work down.
Power to rate: Power to weight? Depends on the power of course. Weight should be 97-120kg, depending on extras and fuel, etc.
Diesel
PostPosted: 15:23 - 08 Dec 2011    Post subject: Reply with quote
than you for your replies, great help, and turns out the bhp is under but the power to weight is over but its like matt said fuck it, lol
PostPosted: 17:35 - 08 Dec 2011    Post subject: Reply with quote
But if you're going to break the this law, why not go for a bigger and so probably more reliable bike.
By the way, KTM manuals which list service intervals are available for the last ten year's models or so.
MaybeGuy
PostPosted: 18:03 - 08 Dec 2011    Post subject: Reply with quote
I would take the KTM service intervals with a pinch of salt. They're ridiculously often, but that's only really needed if you're flat out racing.
On a 4 stroke, I was doing the oil every 1000 miles, filters every other oil chance, and clearances every other filter change with no bother whatsoever. That was road use with a bit of off road use here and there, a few lanes and tracks.
PostPosted: 19:45 - 08 Dec 2011    Post subject: Reply with quote
They used to life different intervals for 'non-competition use', not sure if they still do. But yes, with most competition bikes you can be a bit more relaxed.
For lots of road use with road style tyre it's definitely worth considering getting a cush drive wheel.
drzsta
PostPosted: 20:09 - 08 Dec 2011    Post subject: Reply with quote
They're is no way I would use the 250f on road, you still need to change the pistons on the 250 which is alot more time consuming than the 125 which is a piece of piss!
Not to mention religious oil and filter changes coupled with regular valve clearance checks 10 - 25 hours, piston check at 60 hours but it's likely you'll have to change the rings before then.
My 250 excf has only got 28 hours on, they're all dirt
What's the point of buying enduro/h&hcompetition bike to use on the road?
reggie
PostPosted: 21:33 - 08 Dec 2011    Post subject: Reply with quote
mat you had a old rfs engined 520 totaly difrent game to the excf250s
imo buy the 2 stroke if passing test mightawell get a 200 sake kinda speed as the 125 but you can plod about on it when needed and it will pull the taller road gears easyer
when the shit hits the fan make sure its facing the other way.
MaybeGuy
PostPosted: 21:46 - 08 Dec 2011    Post subject: Reply with quote
twin cam with shims instead of tappets? I'm aware the engine he's talking about.
people like 4 strokes, people like 2 strokes, fans of either will defend them to the end. Like xbox and ps3.
The way I see it, 4 stroke is easier to live with, and requires more skill to rebuild, and gives more confidence when you know it's been built right.
reggie
PostPosted: 01:05 - 09 Dec 2011    Post subject: Reply with quote
the rfs engines are lower reving i like 4 stroke singles on the road ive had 3 ktms 2003exc525 2008 excf250 and 2002exc400 the best one for the road i thought was the 400 ive tride all of them in sm trim and enduro trim the
525 personaly thought was a boring bike only good for doing realy easy wheelies gentle bike ofroad with corect use of right hand
the 400 was good for ploding round town and more revy and verry smooth just as easy as the 525 to wheelie just harder to get up in higer gears
the 250 was a screamer 12k rpm limiter was good ofroad than on the outhers being lighter probaly just becuse it was newer crap onroad crap in trafic and did not like going below 4000rpm
MaybeGuy
PostPosted: 07:06 - 09 Dec 2011    Post subject: Reply with quote
the 250 most likely revs higher due to its shorter bore and stroke, and with shims, service intervals will be less often than a bike with tappets.
You can't really compare a 250 to a 520 on the road. Yeah, they're pretty gutless in the low revs, but it's a 250.
ben_wheely
PostPosted: 16:56 - 09 Dec 2011    Post subject: Reply with quote
I use my 250f on the road, as a commuter, and laning/offroading on weekends. Its fine imo.
Ive been doing this for around 3 years and only major problem ive had was the bottom end going last year, not a common problem, just one of those things ! It was rather expensive though, but its all fine now.
Work mate has just passed his test and got a exc250f for the same purposes as me. We change our oil circa 500 miles, filter every other time. Hasen't missed a beat (so far). So its hardly the worst thing you could do... I can do an oil and filter change on my Yam in about 15 mins.
i guess the only thing about buying an enduro bike, is not knowing about its previous history. Everyone likes to say 'never been raced' ... but is this the case ??
If you can find a decent one ... then do it Thumbs Up
Rides: '05 Yammy WR290-F
Diesel
PostPosted: 21:02 - 09 Dec 2011    Post subject: Reply with quote
really helpful posts thank you
The last post was made 14 years, 348 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> Offroad & Supermoto All times are GMT
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 113.2 Kb
