Remove OE graphics without damage to paint?
Suntan Sid
PostPosted: 13:10 - 05 Dec 2011    Post subject: Remove OE graphics without damage to paint? Reply with quote
I have managed to remove the, original, graphics from the side panels of my project bike, with the use of a hairdryer.
Although the stripes have come off they have left behind the glue.
What is the best method of removing the glue, without removing the paint underneath?
White spirit & WD40 made no impression.
I did try a bit of cellulose thinners but I’m worried this is going to take the paint off, underneath the glue.
kerr
PostPosted: 13:30 - 05 Dec 2011    Post subject: Reply with quote
Petrol to take the glue off and t cut colour restorer to get rid of the ghosting, or just use the t cut it will do both, it takes a wile though, you have to rub the glue for a good wile before you can get it all off.
aprilia 125 Af1 Futura >> Suzuki gsxr 600 srad >> J1 zx6r >> cbr 600rr >> Speed Triple
Suntan Sid
PostPosted: 13:58 - 05 Dec 2011    Post subject: Reply with quote
I'll give the petrol a go tonight, cheers! Karma
hazza
PostPosted: 14:04 - 05 Dec 2011    Post subject: Reply with quote
Dont use t-cut it is far too abrasive. What you need is autoglym intensive tar remover. It will take 30 seconds to get that residue off.
delsol
PostPosted: 10:42 - 08 Dec 2011    Post subject: Reply with quote
Stickers, decals, tank pads, debadging glued on items; I have been using this method for years and never a problem.
Hot air gun (or hair dryer) to gently soften the adhesive, peel back the sticker slowly.
You need Carb\Choke cleaner and a couple of clean rags:
Cover any plastics or vinyl etc to protect from overspray.
Spray a small amount of cleaner onto the adhesive residue, gently wipe in a rolling motion with the rag, the adhesive will form into small globule like pieces.
The solvent in the cleaner will flash off very quickly, so keep applying small amounts and the little globules will soon wipe off onto the rag.
There is no need to rub, avoid rubbing altogether, it will take no more than a few minutes to remove all the reside from a tank pad size object.
I have never found the need to use any abrasives such as TCut.
I would avoid trichloroethylene, there are reported links to dementia related (parkinsons disease) illnesses.
https://www.dementiatoday.net/article/common-chemical-and-parkinsons-disease/
In fact most stuff we use in the garage is harmful, but do we bother to read the label, or even know what the hazard symbols mean:
https://www.hse.gov.uk/chip/phrases.htm
PostPosted: 10:48 - 08 Dec 2011    Post subject: Reply with quote
If you can heat the left over bits of adhesive up and start to get them coming up I've found gaffa tape's pretty good and removing it too.
Suntan Sid
PostPosted: 11:32 - 08 Dec 2011    Post subject: Reply with quote
Here's what worked for me, from the other thread:-
Suntan Sid wrote:
Right, I just did, what you're attempting, earlier this evening.
I started another thread about it here:-
https://www.bikechatforums.com/viewtopic.php?t=234762&sid=7207a6b8c1fd821dd75c873072d27332
Here's how it worked out.
Step 1. Get a hairdryer set it to hot and heat up the decal at one end. After 30 seconds or so you should be able to lift an edge and start peeling it off carefully. If it's a long stripe, (it was in my case), peel off a couple inches then apply more heat to the next part of the decal, repeat until you've finished.
Step 2. You will probably be left with all the glue that was holding the decal in place. My first thought was to use cellulose thinners, it did work but I was worried that it would take the paint off underneath. Tried some white spirit, that wouldn't touch it, petrol didn't work either, neither did a "scotchbrite" scourer or nail polish remover.
During lunchtime I bought a can of "Label off Super", from a DIY store, made by a company called "CRC", it came in a small aerosol can and cost about 5 Euro. Sprayed some on the glue and left for a couple of minutes, this melted the glue, however I still had to scrape the glue off with a plastic knife. Wash it afterwards to get rid of any residue.
https://www.bilight.biz/showfoto/480/480/goods/32351/32351_01_108065091258.jpg
Hope that helps!
My 1000th post as well! Cool
delsol
PostPosted: 13:08 - 08 Dec 2011    Post subject: Reply with quote
Vincent said:
If you use the stuff day in day out, or abuse it by sniffing it, then I dare say it could destroy enough brain cells to do you harm.
Using it for 5 minutes to clean off some adhesive won't do any harm whatsoever.
You don't work for Health & Safety do you? Laughing
Hi Vincent,
No, I do not work for Health and Safety, but I do know about occupational exposure limits and maximum exposure levels to hazardous substances.
I only mentioned it because over time it has become obvious to me that in my garage the majority of car care\maintenance products carry hazard warnings.
Aerosols are particularly notable for their ability to disperse their contents widely, and without taking extraordinary precautions it is impossible to avoid potentially harmful exposure through inhalation, ingestion, absorption, injection etc.
I fail to see how you can reasonably comply with the precautions listed on say Dashboard Shine, the label will say do not use in confined spaces!!!; what do they suggest I do?; remove the dashboard and take it outside to apply the stuff.
You say 5 minutes of using (whatever stuff) won’t cause any harm, the problem is that the harm is not always obvious, some people will have an immediate and adverse reaction to a substance (then usually learn to avoid it); others can use the same substance and notice little or no effect.
Simple precautions like using an alternative non-hazardous substance, or at least ensuring the area is well ventilated will overall reduce the cumulative effects (that most often will not produce immediate reaction or sensitisation warnings – so we keep using them oblivious to the potential harm) of the plethora of chemicals we use all the time in the garage.
All I’m saying mate is that there is plenty of stuff in the garage best avoided if you can.
That said; I’m off for a fag now. Rolling Eyes
Cheers,
Delsol
The last post was made 14 years, 308 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 71.82 Kb
